Replaced valve cover gasket ,rear main oil seal oil pan gasket in good shape. Still leaking pretty good. Does the dip stick tube have an o ring at the block
Anyone know it? I've tried searching on here and google but haven't been able to find a listing that confirms it. Annoying little leak that I want address. Basically the grommet that goes where the oil fill tube enters the block.
dad had the same problem with his truck and we found out the dipstick tube was loose. someone took it out to change the clutch and forgot to tighten it.
