Traded for this vehicle recently and am troubleshooting this problem with no luck so far. The bulbs are good and through research I have found all the ground locations, but have yet to examine and/or clean them. This truck has over 300K miles and some things are just wore out on it, (they will be what I check first though). From what I've found on this truck so far I'm leaning towards either the neutral safety switch on the trans or the switch on the lower steering column, (both of which can cause this issue correct?). I guess right now I am looking for confirmation that both of these switches can cause this issue and to see if anyone else who had this problem out there may have any ideas on where to start first.
Thanks in advance for any help!
