Hi, I came to a dead end with this. P1404 EGR Closed Position. Stuff I've done to this.
I've tested EGR Checked OMH between pin A and E and I show just under 9 OMHS, (specs. between 8 to 9 OMHS). I do have 12 volts on pin E. I back probed Pin C and reads .9 volts (specs between .6 to .9 volts). I took EGR off and pushed pin in and that to is with in specs.
I would reset light, blazer will run about 40mi. then check engine light back on.
Intake is not plugged. I had it apart and was hot tanked.
wondering if EGR may still be the problem. maybe the solenoid in EGR if it has one is slowly going out? Anyone run across this issue in the past?
Any help would greatly be appreciated
