whats up people, i read a bunch of stuff about this and its all over the place. Please help.
2 new lines. one to drvers side wheel one to pas side wheel.
4 new calipers 4 new rotors 4 new pads 2 new rubber hoses to front calipers
what i did:
abs bleed with auto bleed on a snap on zeus computer, bench bled master cylinder. all 4 calipers have been bled and has a steady stream of fluid to them. no leaks.
when cars off and you pump the pedal the pressure holds tight. turn it on pedal hits floor. i checked the vacuum hose for leaks notthing and disconnected the hose to the booster shoved a ratchet in there to test it and it was all good. i dont think its the booster, but who knows
I literally have zero brakes.
is it possible to have air in he abs module although it was auto bled? is a proportional valve an issue? how do i check it and what am i missing I'm shot wasted a whole weekend screwing around with it. i'm over it.
03 GMC Sonoma SLS & 04 Chevrolet Blazer Ls
Did you replace the master cylinder? It could be bad and leaking out the back and filling up your brake booster full of fluid. And for the ABS bleed I would at least do it 2 or 3times One time does not get all the air out.
i did both and it just didn''t make sense to me. I was thinking about it and i definitely rushed through it and im starting to think i might have reversed the calipers in the front. im going to look today and at the back ones that were done by the prev owner
