1 - 12 of 12 Posts
· time to get cereal
If you want the manual your truck would've come with from the factory, you need a 96-97 NV1500. I would recommend a T5 from a 94-95 though.
I am in NC. Best to buy new- clutch kit, flywheel, master cylinder, slave cylinder. S10 warehouse on ebay is where i got my pedals and computer. You need a 2in metal hole saw for firewall, it has a dimple i think super easy just dont drill through more then the first layer of metal. The floor is stamped out for the shifter start small work up to the best fit. Should be a plug under dash for clutch safety switch but you may have to wire in reverse sensor on transmission. Rear gear ratios are diff so be aware of speedo being off.
1 - 12 of 12 Posts
