1 - 2 of 2 Posts
My truck, a manual, has the fill and check plug in the tranny itself. As it is out of fluid, I am taking action to restore and refill.
I want to put the front wheels on 'macho' ramps. Should i add more/less/same amount of fluid to account for the 6' tilt in the truck?
I usually insert a clear vinyl hose in the fill/check hole while it's on the ramp, then roll it back down onto level ground and fill it with the truck level.
Do you know where the lube leaked out? Have you fixed the leaks? Those things don't just "use" lube. It goes somewhere, and refilling won't fix the leak. It just throws more lube out the leak(s).
1 - 2 of 2 Posts
