1 - 1 of 1 Posts
So I've seen multiple posts about this same problem, but they all seem to have a much simpler answer that I have already ruled out, such as the VSS or the brake fuse.
But mine is more complicated, in have checked the VSS, it works, I have checked both of the connections from the VSS up to the vehicle speed buffer, they both function, I have checked the output wires from the vehicle speed buffer, they all work, I have checked those same wires right before they enter the ECM, they both work, I have swapped the ECM entirely, nothing changed, I have tried every fuse, none were blown and all had good power.
What am I missing? I am 100% stumped I have no idea where even to look next.
This is my daily driver. Any help will be massively appreciated, thanks.
1 - 1 of 1 Posts
