I believe it was bed swapped before my time as well as the grill and headlamps were changed. I have the original grill and square headlights. It has RPO code B4U so it is a real ss. 👍🏻Is it a real SS? There wasn't a stepside offered in 1994 so we know it's not stock, not to mention the grill and headlamps.
LOLlots of your finest maple syrups
Many big buckets of Loonies! Is the market up there as crazy and inflated as here in the US?Hi guys, just curious, what would a 1994 s10 ss step side with no rust and 130,000 kms (not miles) be worth in CAD?? Cheers and thanks for the input View attachment 361553
Yes, crazy up hereMany big buckets of Loonies! Is the market up there as crazy and inflated as here in the US?
ThanksNot wild about the wheels, but that's a nice looking truck.
I’m not too sure if I can tell between the two, I was told the old core support didn't have the provisions for the new style headlight but when the newer core support came out for the newer style of headlight they kept all the exact same mounting points and provisions for the old set up aswell. The PO said I’d be good to swap headlights and grill without an issue. Just pull grill and one headlight and hold up the old stuff to core support you should see all the mounting points. I see the mounting points and all but not sure how they mount. I also need to re wire.Do you also have the radiator support for the original headlights?
Ask $10k and see if you get any offers.
Yes sir there is holes in rocker and along the side. I took the side skirts off that the PO had on before. Plan is to either fill them, weld them, plug them, or put the skirts back on. Haven’t decided yet.Are those dozens of holes I see in the rockers and bed? Did it have Xtreme stuff on it?
Interior is pretty original. Has added cb, planning to put subs in. Other then that pretty clean. No rips. Upgraded radio.Still got those ZQ8 wheels. I think they look better.
Don't want to be argumentative, but the 94 support sure looks different to me.
Between the body holes, the wheels, the core support, wiring and the K&N CAI I'd be more in the $5K range. Needs a lot to bring it back to an SS.
What's the interior had done to it? Amps, sub woofer box?
These are aftermarketA 94 SS wouldn't have those wheels, it would have the same wheels as an LS.
