Discussion Starter #1 (Edited by Moderator)
I am looking for 1993 S10 2.8L Clutch Hydraulics options.
I am transplanting the complete drivetrain (engine, 5 spd trans, driveshaft and rear axle, also using the steering column and pedal assembly) to a 1958 Volvo 444.
I will need to replace all the hydraulics because they are weeping fluid at both ends.
I have been studying the parts availability on Rockauto and found that 1992-93 are different. For some reason they don't offer 92-93 repair kits for the cylinders.
I found some of these use a more conventional screw-in hose (like a brake hose). Is this more desirable than the type used on my 93 ?
My Volvo firewall will be different than the S10 so I have some freedom of choice here.
Do all the 2.8 L slave and master cylinder have the same bores?
Looking for some of you to chime in and give some of your knowledge to help me make the best pick.
I attached a pic of the 1958 Volvo 444 I am starting with and a Photoshop rendering of my fenderless goal.
the new guy
the 92 system in my son's truck doesn't let the line unscrew from the slave. its kind of a pain in the butt because the bleed nipple is right where the line points and uses a tiny allen wrench instead of a regular 8mm or whatever size wrench
time to get cereal
Pretty sure '93 got the much improved world class T5, don't know if that changed the hydraulics or not...
the new guy
is there a non world class t5? whats the difference? like I think our 92 has a t5 but I don't know about this world class stuff?
