Hello, first post on this forum. I've been having a problem. I was driving the other day and it seemed like all of a sudden I had no gears, almost like the clutch was not disengaging. The clutch fluid was full but I noticed the master/slave cylinder hadn't been replaced in a while. I bought a replacement prefilled kit and they look exactly the same but for some reason I'm having trouble installing the slave cylinder into the side of the transmission. Almost like the fork it's pushing against isn't going far enough back. I can't seem to get the slave cylinder installed. Should I need to pry the transmission fork back to install the slave cylinder or is there an internal problem with the transmission?
