I’m doing a 4/6 drop on a 1992 s10 with spindles and springs in the front and leafs and blocks in the back and all new street performance shocks. Will I need to install a notch at this point? This will be my first time doing any of this!
Moved to 2wd Droppin'.
With a 6" drop in the back...I'm thinking so. I was hitting the bump stops pretty regularly with 3" blocks on top of ZQ8 rear springs. I got away with just removing the stops and brackets.
time to get cereal
I'm 6.5" in rear without a notch... bumpstop brackets gone of course. I have bolt-in notches I will be installing eventually. The axle doesn't hit the frame unless I turn really hard from a stop with a lot of throttle.
