I'm starting a 1991 project truck it is super clean and almost zero rust. The truck has already converted over to a v8 set but has a ton of unused wiring in the engine. Is there someone that has a wiring delete diagram and a idea of what wiring has to stay... I have removed wiring harness from engine bay picture lol.
Thanks Dave
I've never seen a wiring delete diagram. Probably because everyone does their swap their own way. If you do start cutting wires, leave enough to solder back together and shrink wrap, just in case you make a mistake. If you cut it right next to the connector you're SOL.
This book will probably help:
Are you saying the wiring from 82 to 93 is all the same? Is it from a Chilton book. They're the only ones I know of that think so.
