1988 S10 Instrument Cluster Removal
134 Views 4 Replies 3 Participants Last post by  msdibble
I am attempting to remove my instrument cluster on my 1988 S10 (See Pic).
I don't know how to get around the HVAC panel in order to access the bolts on the dash & instrument cluster.
Any ideas or suggestions on how I can get around the HVAC panel in order to access dash/cluster bolts?
There are no Youtube vids on it.
Gear shift Motor vehicle Vehicle Automotive design Car
Thanks
Unhook the electrical switches , and the clips on vacuum and the cable for the slider controls. Clip on cable as well Uses a 7mm retainer screw as i recall. Its tight but has to be done to get the bezel off.
Machine Toy Gas Electronic component Plastic
The HVAC panel has to come completely out like Brawndo said. It is a PITA to get everything back on when going back in.
Reactions: 1
I was afraid of that!
Thanks to all for the replies!!
More and more I'm inclined to just operate without the upshift light. Not as if I ever really used it anyway.
Just for grins I mounted a little 2" tachometer over in the driver-side corner of the dash (using velcro in the event I want to get rid of with no damage).
I've found that with this 2.5L 4 cyl, my max RPM's are 1900 at 75 mph. Speedo only goes to 80...LOL!!
Reactions: 1
