1988 Chevy S-10 (Standard-Cab Long-Bed, 2.8L V6 w/ 700R4 & 4x4)
Hi everyone! I just recently bought a 1988 S-10 with a locked up 2.8L V6 and a 700R4 in it as my first vehicle. I've stripped out the drivetrain, torn the engine down, and found that it was a bottom-end oiling failure that killed it. Connecting rod 2 had let go completely and stopped up the engine, rod 5 was not far behind, and the 2nd main bearing was also completely smoked. The top end (camshaft, lifters, rockers, etc) of the engine seems completely fine.
I'm looking to rebuild the engine and upgrade it while I'm in here. I'm trying to put MPFI on it (out of something like a Firebird that had this same engine) and also prepare the engine for probably having a turbo added later for more torque without more revs (money won't let me set the turbo up now).
1. Do y'all have any suggestions of what vehicle(s) have the best/most compatible donor engine for me to pull and kitbash together with mine to repair/rebuild/upgrade it? Thus far I'm thinking something with the LB8 or LH0 engines, which means 85-92 Camaro/Firebird or 90-92 Cutlass Ciera S.
2. Anybody have a specific brand/part number for a rebuild kit (gaskets, seals, o-rings, etc) that they've had good luck with?
3. Also, I'm thinking I'll probably need forged pistons to take the extra force and heat from the turbo, do y'all think I will and if so do you have a good source that I could get them from?
4. If anybody else has done what I'm trying to do with the turbo, do you have any specific recommendations for what turbo and intercooler work well in this application?
Thank you so much in advance for your help!
