Hi folks. In an effort to light a fire under my ***, I’ve decided to create my own build thread after about 7 years.
As the title says, I’ve got an ‘87 2WD Blazer I’m swapping. Years back I
was much more active on this site and with the truck. I had completed a 2.8 to 4.3 swap in 2002. A few years later I did a LB9 swap. That only lasted about a year before I spun a bearing in the motor. I found a L98 and ran that for quite a few years. I was never happy with that 350. The TPI, while torquey, was never really scratched the itch for me.
In about 2015 I picked up a LQ4 with about 118k on it I think, but I honestly can’t remember anymore. I had a 4L80E core rebuilt, bought a H3 oil pan, CPW poly mounts, and Stainless Works long tubes. Then I bought a house with a nice two car garage, put it all in and nothing fit. I got married, and that’s more or less where the trail went cold.
Here’s where she sat a couple years ago collecting dust, and getting buried behind varying piles of home improvement building materials. At one point it was completely blocked by plywood.
Playing with wires.
Motor in.
I always had plans of doing some kind of power adder, but over the years as the project sat stalled, I could never come up with a plan. As such, nothing really ever got done. Although I never tried, I’m pretty sure with the truck accessories and 145A alternator, the hood would not have closed.
Enter 2021. I changed the front end to LS3 water pump and a Corvette bracket. I plan on using the Holley low mount A/C with a Sanden 7176 compressor.
On the suggestion of @Harley, I picked up a 2004 Grand Am cooling stack and that really helped out fitting everything. The air intake, upper radiator hose and alternator were all fighting for the same space.
So here I am today, playing with my pile of spaghetti under the hood. I’ve more or less nailed down where everything is going to live. Note: Check out the 5+ years of dust buildup here from the last group of pics.
The P59 PCM will fit nicely under the battery tray, and that will really help clean up the wiring. Coolant expansion chamber is from a Chevy Cruise. Power steering reservoir is from a Pontiac G6. I used Airaid UBI pieces for the intake. Used the Loc-Tite brand super glue the interwebs says and it’s pretty solid. Once the motor position is finalized, the straight to 90 elbow will get glued and it will all be smoothed and painted.
I’m at the point now where I think I just need to hear it run. I’m not too concerned right now with fitment of everything, but I’m going to complete the wiring, plumb the fuel lines and hit some sort of milestone in this project.
Playing with wires.
Motor in.
