Status
Not open for further replies.
First Rate Primate
Can someone with an '86 tell me were the ignition coil gets mounted? I'm in the process of putting a 2.5 back together and can't figure out where the coil mounts. Pics would be great. Thanks.
Here's the engine I'm working on:
First Rate Primate
Thanks for the reply. That's the newer generation 2.5 (1987 and up).
1986 used a different intake and throttle body. The coil mounts differently.
As a side-note, 1986 was the last year for V belts. They went to serpentine belts in 1987.
new to this forum so sorry if I put this in the wrong place. I need to adjust dist to set timing and I cannot for the life of me get a wrench on the bolt to loosen the dist holddown. It is 2.5 with air. Must be a trick to be able to get hand down there under the intake and around the a/c hoses. Is it better to get to it from underneath the truck.
Status
