I don't know much about this mod but what is the benefits from it and where can you get it from? How to install?
Thanks
Thanks
:bs: I run a 160* stat with no problemsBlazerLT said:180 won't create any problems.
Now if you dropped a 160 in there, then you will get some major carbon buildup.
This will work with an 02 even though it says 01?HenryJ said:Cooler temps, allowing for a denser air charge, reduced operating temps lower chances of detonation allowing more advance to be used.
Jet has the 180* stat.
Installation instructions- Low temp thermostat from the S-10 & Sonoma Crew Cab website
How do u know if u have carbon buildup or not? Plus would it make a difference where u lived? Like if I put in a 160* thermo in alaska then that would cause problems but in Florida it would be just fine.NJTy180 said::bs: I run a 160* stat with no problems![]()
the easiest way is to check the plugs but also by the fact that performance of my truck far exceeds that of one that was loaded up with carbon and crap :chicken:NCHEVYHEVN3 said:How do u know if u have carbon buildup or not? Plus would it make a difference where u lived? Like if I put in a 160* thermo in alaska then that would cause problems but in Florida it would be just fine.
Didn't even think to look at the plugs.NJTy180 said:the easiest way is to check the plugs but also by the fact that performance of my truck far exceeds that of one that was loaded up with carbon and crap :chicken:
Seeing you are using a 160 stat in a turbocharged Typhoon, you will be running a little hotter than the rest of us anyways.NJTy180 said::bs: I run a 160* stat with no problems![]()
yeah, i suppose, but i also see that the computers are a little less forgiving than they are in the SyTys, which is why I havent bothered to comment anymore on this.BlazerLT said:Seeing you are using a 160 stat in a turbocharged Typhoon, you will be running a little hotter than the rest of us anyways.
Please keep in mind that I was talking about normal 4.3L's where people notice a drastic decrease in mileage seeing the engine is dumping more fuel into the engine to get it up to temperature.
This leads to the carbon buildup.
