Does anyone make a one inch drop spindle for an s-truck? Or is a 2" spindle the smallest spindle they make. Also does a 2" spindle really give you a full two inches of drop if you install on a truck with a stock zq8 front spring?
true, no 1" drop spindles.NCHEVYHEVN3 said:Nope no 1 inch dropped spindles. There is 2 and 3 inch. If u put it on a zq8 front than u will have a total of 3.5 of drop.
do you have a 2.2? if you do you might have gotten the 6cyl spring, they ride a little higher because of the extra weight of the 4.3fake02zq8 said:So it is true that the factory front ZQ8 spring only gives you a total of 1.5 inches of drop. I originally installed these springs with a two inch block in the rear only to find the ass end of the truck sitting lower than the front after the drop was complate. Forcing me to have to swap the rear block to a 1 inch to get the truck to sit right. Also would adding the two inch spindle affect the factory ride quality, if so how much? I want it to ride like a factory truck, just sit lower. Thanks again for the info.
