1 - 20 of 23 Posts
i wanna put a 1/2 drop on my X. can i use 3" springs & 2" blocks? will i need anything else to mak it work like new shocks or something? does anybody have pics of a 1/2 drop on an X?
Deadbeat
spring and blocks should work...i'm not real sure what size springs u'll need...and your stock shocks will work fine with that mild of a spring drop and mounting distance with block wont change.....why not go 2/3? looks pretty sweet on a x :)
Deadbeat
not really sure....i have a 2/3 and i rub the frame when i have the wheel at full tilt and the flare (which i trimed out) when i hit a really big bump like a speed bump and i'm going to fast...thats with the stock 235/55/16's....you might get a lil rubbing doing u-turns and a lil on the fender but probably not to severe at all....those tires are a lil wider but arent as tall so you should be ok....i'm not sure tho....
stock these trucks are 1.5 drop
on teh customers trucks ive done and replace zq8 with 2 inch drop belltech springs front comes down .5 to .75 more
3 inch drop springs 1.5 to 1.75 more
if you want it 1 inch more in front jsut go wtih the 2 inch drop springs with 3 inch drop springs might be to low up to you. rear 2 inch block is fine
here is a x i did 3 inch springs and 3 inch blocks
www.geocities.com/lawsons00xtreme
245 45 17 with 4.5 bs on a17x8 will fit no rubbing but i would get like 17x9.5 rear with 5.5 bs 275 40 17
xtreme nutcase
i will be doing the same thing to my truck in the next couple of weeks or so. do you guys have the part number for this:
3" coil
2" angle blocks
i just wanna make sure i get the right stuff. last time i did it on my other truck they give the wrong size u-bolts.
and also, i've got an xcab, do i have to get the angled blocks?
thanks guys.
xtreme nutcase
thanks tony.
what about the 2" angled blocks...does anybody know the part number.
xtreme nutcase
just got my 3"coilspring (bel 4225), and a 1" tall bumpstop. but they'll have to order the 2" angled blocks (bel 6102) from belltech. problem is it takes 3 1/2 weeks to get it. i'm a little disappionted, coz i was planning on dropping it this long weekend. this is the problem about living in canada.
it was cheap though, cost me about $190cdn for everything. it's about $120us.
Deadbeat
DOHH! < homer voice > ,..........that sucks........
xtreme nutcase
98 SS ON NOS said:
4225 nooooooooooooo wrong one bel 4227 is for the v6
are you sure about that?
that's what i thought too, but the guy in the counter says i need the 4225. i'll give him a call tommorow... i even told him i got the v6 xcab.
yep, 4225 is for the 4 banger
xtreme nutcase
you guys wont believe this. i phoned the guy this morning and he said "sorry man, what you actually need is the BEL 4228."
wtf! from what i know this is for the blazer. so i told hinm i want the BEL4227. so he said " oh yeah you're right, there is a little footnote in the bottom of the cattalog."
good thing i knew the right part number or i would have been screwed... thanks.
1 - 20 of 23 Posts
