Hopefully someone can answer this for my, cuz I feel like a total idiot. Everywhere I"VE looked I cant find anything over 3/3 for an 04 X......anyone know of a combination of parts I can throw together to acheive a 5/6 static drop. Are any of the parts from the S-10 p/u compatible with the Blazer?
I wanna try to drop 5/6 and tuck 20's into it, I know I may have to roll the fenders a little to get it done as well as a few other problems I'm sure will pop up as its installed. Just wanna know if the parts are out there to do it.
your gonna have to do a hell of a roll job with 20's, i know its doable though. i rub with stock rims and a 2/3 drop. as for anything else you might need, a pinion angle readjustment, front alignment, maybe balljoints, maybe tierods. youll needa cut out bumpstops unless you like a bumpy ass ride, mine is pretty bad with just the 2/3.
Ok, so I finally found a company that claims they have a 5/6 that will fit an 04 Blazer....anyone ever heard of Canuck Motorsports? I guess they use SpringTech and DJM products. Any input on this? I'm thinkin I might have to say screw rollin 20's and may opt for 18's instead on some lo-pros
retardicon
2 inch drop spindles with 3 inch drop coils up front, 3 inch drop leafs and 3 inch blocks in the back should get you where you want.
you might have to notch the rear.. but honestly the ride will be terrible.
I did a 2/3 (spindles and blocks) on my 02 xtreme and with my 20's, and big speaker box, the ride is ok.
better stock up on front airdams if you're going that low...
Premium Member
BTW.. make sure you get spindles for a 98-up Blazer. They are different than the Pickups and 97 and older Blazers.
The phone is ringingg
Thats cool i also bought an 03 blazer xtreme and want to do a 5/6 drop on it, i found all the parts needed at stylintrucks.com 2''spidlas 3''coils 3''leafs & 3''blocks,. But i wanted to see some pics off blazer xtremes with such drop, if you have them post them up everyone wants to see a slammed blazer X..
