My fuel tank guage goes crazy, goes up and down, empty to full, then actual fuel level, and some time sticks at half i think, any ideas what this could be?
Sometimes I'm mean...alot
Try using the search function...there are literally hundreds of post on this subject.
Local Tech
Almost every s10 ive had or fixed with that problem turned out being a broken or severed wire in the harness.... Usually along the frame around the area of the driver's door, or within a foot or 2 back.... If i recall correctly, its a purple wire. And yea, it literally is you and every other s10 owner lol... Mine works, but my old beater was the same way
2000 noma highrider
i had this VERY issue in my sonoma and turned out to be a bad sending unit. I went to the junkyard and go a sending unit and swapped out the sending unit part. My fuel pump was only 6 months old and im not dropping 200 plus for the whole assembly:D
Thanks ill check it out
i saw what you did there!
purple wire is correct
this is a really common issue
if not a bad wiring connector somewhere then the sneding module unit is bad
new ones are $$$$$
but you could tyr a good used one if you can get one dirt cheap but its alot of labor to replace it in a non-pickup
so its your call as to what you want to gamble
if its that bad of a problem for you
personally since its not a pickup and is harder to drop the tank than on a pickup i would probably just live with it until the pump dies and warrants the cost its gonna be to buy a new module
which are around 250 to 350 bucks for these trucks
in which is one main reason why i wont own a 94 or newer truck
parts are too damn expensive for them
i stick with first gen where parts are free or basically free
and i have to agree with rage this is a common topic theres thousand sof posts on this issue if you search real quick then youll find hundreds of posts on this exact issue
also all over the internet, use a google search
have fun
terrible. take a lap.
i didnt ask for a smart ass remark, dont bother posting unless u helping tool.
Same can be said for you. Don't bother posting if you can't HELP yourself out and search first. Common sense says someone has had this problem before, genius, or should I say tool?
So, I'm a "tool" huh? Well, at least I know how to use the search function and rarely need to ask any questions because of it.
I will gaurentee this... I won't bother posting on anything you every ask for here again. your loss!
