ZR2 is an off road package that includes some changes to the frame width causing motor mounts to be in a different location than a standard 4wd.
The ZR5 is a bling package. Nothing in the package is for off road use. No difference in the frame from any other standard 4wd. You just need S10 4wd LS motor mounts. The ZR2 package was never put on the crew cabs.
I think you'll find keeping your present transfer case a lot less trouble than adapting the S10 to accept a full size truck TC. The oil pan is going to be expensive for fitting an LS in with the front differential. The Milodon 31083 pan and oil pump pickup tube is >$600 not including the remote filter kit. I believe there are few cheaper ones out there, but the oil pan and pump tube are no place to be pinching pennies.
An LS into a 4wd crewcab is a big, pricey, time consuming swap. Probably $6K ad 6 months bare minimum. I have an 02 crewcab and yes they are doggey because of their weight (4000 lbs +). If I do swap mine I'm going with a SBC L31 to save both time and money since it will never be fast.
