Got Fuel Rails?
I don't see a problem with that. You will need to add a coolant temp sensor under the thermostat housing. The '96-'97 computers had 2, the newer ones only have 1 on the head. That engine should already have the tapped hole there for it. I would use the wiring harness with the '96 computer, and not the harness from the newer truck, not sure if the newer harnesses would even plug into the older computer.
There may be an extra o2 sensor in front of the cat for a total of 4 on the '96-'97 computers, it may throw a code without that o2 sensor, not sure if you care. It will run fine without it, it isn't used for fueling, only the bank 1 and 2 sensor 1 is used for fueling.
If you are interested the computer's are spit like this:
'96-'96: 16229684
'98-'00: 16263494
'01-'02: 12200411
'03-up: something else
You can find more info about what came with what here: http://198.208.187.182/internet/VehiclePartFits.jsp
and here: http://198.208.187.182/internet/Vehicle.jsp
For the most part the '96 and up engines are all pretty much the same. The '01+ stuff had different knock sensors.
UNBANNED BITCHES!!
sikazxj said:
your absolutely more help than "howell is awesome"
:flipoff: :finger:
**mental note.....never try to help sikazxj ever again.....**
if you read the whole post i said i dont think they'd work....and they wont without modifiying it.......
and also if youd call HOWELL they could have told you the correct info hence saying there a great company and they know there stuff.....:ahole:
why do people have to be such dicks...
TnHombre said:
:flipoff: :finger:
Maybe he's following the fine example, that you seem to set a lot of times:rolleyes:
