Does anyone know the Cfm rating at .400 in lift on int & exh?
What size are the valves?:rolleyes:
I don't know if this will help, but you may want to check other sites for the flow of the vortec 350. The heads are basically the same minus 2cyl. Info on the 350 is more readily available.
Mud Dummy
HEADS: Casting No. 12557113. 96+
LIFT: INT. FLOW EXH. FLOW
0.050" 31.4 26.8
0.100 62.0 51.1
0.200 126.6 97.5
0.300 178.5 131.4
0.400 220.6 146.6
0.500 225.1 154.4
0.600 219.2 154.0
Bog Hog1
Thanks alot for the info:thumbup: Where do you find this stuff
i have been looking but can't seem to find the tech stuff like
this?
Mud Dummy
I spend a lot of time on the web, a while back a guy was selling these heads on ebay and he enclosed a comparison of two different heads he had flow tested. I'm in the process of trying to decide on what heads to use myself. If they made an aluminum manifold I would go with the new heads but the Marine Manifold for those heads is cast iron and about $400 so I'm going to hold out.
