161 - 180 of 189 Posts
Boozebag
Serious progress!
Seats look amazing too and they are MOPAR issue...
Keep it in the family :p
Head Lifeguard
Discussion Starter · #163 ·
Not pretty, but pretty solid. Got to fill the relief cuts, seam seal, then spray on the Raptor Liner. Once I get the driver pan buttoned up I should be able to make short work of the underside prep for spray liner.
Automotive tire Wood Art Tire Trunk
Water Liquid Automotive tire Fluid Gas
Eye Water Liquid Automotive tire Hood
Automotive tire Tire Vehicle Automotive exterior Gas
Boozebag
I forgot that you changed the rear assembly. Anti wrap is appropriate.
I have a few S10s with similar traction control
I aso have a '68 Camaro 12 bolt with the same "traction control" bar.
Head Lifeguard
Discussion Starter · #167 ·
The Caltrac type bars I have on my S10 made a world of difference. With these I need to check the rear axle arc on the leaf springs and figure out the best mounting positions for the bars.
Head Lifeguard
Discussion Starter · #169 ·
Wrapping up the driver side floor pan. Need to pick up some brushable seam sealer so I can prime, scuff, and spray on the Raptor liner. After that sound proofing.
I’m itching to see what the dash and seats are going to look like, so that’s got me working knocking out this boring stuff. I also need to shoot the firewall and inner fenders body color.
Head Lifeguard
Discussion Starter · #170 ·
Going to pick up seam sealer tomorrow. Looks like I’m going to have to patch a small portion of the driver side rear foot well. At least behind the back seat is in great shape.
Vehicle Automotive tire Motor vehicle Fixture Composite material
Wood Wall Material property Engineering Freezing
Hood Automotive tire Road surface Wood Automotive exterior
Automotive tire Hood Automotive lighting Motor vehicle Automotive design
Head Lifeguard
Discussion Starter · #171 ·
Picked up seam sealer along with a lifetime supply of acid brushes (paint store only sells bulk). Worked on the car 9:30 am to 4:30 pm, no lunch and just a break to drink some iced tea. Patched driver rear floor, filled in relief seams on trunk patch, seam sealed the floor patches and trunk. Waited an hour, primered over the seam seal, scuffed up the floor, swept and shop vac’d the area, wiped down the floor, masked off bolt holes, pedals and dimmer switch, went to town with the Raptor Liner.
Time for a cold, carbonated, adult beverage.
Grey Wall Wood Rectangle Gas
Road surface Grey Asphalt Paint Wood
Water Hood Window Automotive tire Wood
Automotive tire Grey Line Wood Tints and shades
Automotive tire Grey Rim Freezing Water
Automotive tire Hood Motor vehicle Road surface Automotive exterior
Automotive tire Motor vehicle Automotive lighting Hood Automotive design
Hood Automotive tire Automotive lighting Window Vehicle
Automotive tire Road surface Wood Asphalt Grey
Automotive tire Road surface Grey Wood Asphalt
Are those front floors going to be rigid enough without any bead rolling?
Head Lifeguard
Discussion Starter · #174 · (Edited)
Yeah, they are plug welded to the subframe, rocker, and this crossmember brace, like the factory pans.
Wood Automotive exterior Gas Composite material Tints and shades
Gratuitous mock up shot. The dash and steering wheel are going to be the icing on the cake.
Vehicle Automotive design Car Motor vehicle Car seat cover
Boozebag
Looking totally smooth!
I've seen that raptor liner on some 4x4 rigs, it looks pretty brutal.
I am guessing it takes a specific spray gun sort of like the old 3M Schutz guns(?)
Reactions: Bennsb
Head Lifeguard
Discussion Starter · #177 · (Edited)
Thanks!
And that’s exactly how it's applied, with a Schutz gun. I bought the kit with the gun when I built my Firebird and sprayed the underside and wheel wells. It’s held up phenomenally.
I really like stuff, 12-18” away at 70-80 psi and it’s almost like spraying drywall. The bottles are partially filled and you can pour the hardener to the indented line, close the cap and shake, then twist on the Schutz gun and spray until you run out. I used two bottles for what I got done today with two coats. Clean up is easy, I run a little acetone through spraying into a rag then wipe down the pickup tube with it. Then I pour a little more acetone in a container and blow it through a few blasts until it sprays clean.
Nickel Household hardware Composite material Gun accessory Metal
Liquid Bottle Fluid Drink Alcoholic beverage
Boozebag
EXCELLENT!!
Thanks for the info. I'll be using the stuff on some of my projects.
I had a '71 Nova SS that I did the engine compartment in Zolotone (Automotive trunk paint) There was no such thing as Raptor back then...
Anyway, the stuff was water soluble (which I didn't realize) and rain messed up some of the paint. I had to do the areas over and seal it with semi gloss clear.
The car was Hunter Green metallic and the Zolotone had blue-green and grey flecks in it. It look outrageous. A few of my friends copied the process on their rigs.
Too bad you couldn't source a 340 'Cuda Trans Am engine.
Those trips and air cleaner look crazy.
Head Lifeguard
Discussion Starter · #179 ·
At work there is a mother and son who are there all the time. After talking with them for a few years we started to talk cars when I was building my Firebird. She told me about her 340 Six Pack Challenger T/A that she has had since high school at the farm in Tennessee.
She finally trailered it to Florida and you are right, so cool.
Tire Wheel Vehicle Car Hood
Motor vehicle Automotive lighting Vehicle Automotive tire Hood
