So an eagle eye Mopar owner spotted my forward mount caliper job, guess the ‘73-76 a-bodies were meant for a rear mount position. (I’ll check the numbers to see which caliper has an even part number (right) and which is odd (left) to verify.) Either way, mounting calipers to the rear will eliminate sway bar mount clearance issues and the hard brake lines are routed to the back of the a-arms. The ‘69 Camaro braided brake lines look like they’ll be better suited for a rear mount position as well.
Got new lower 1962,1973-76 Dart ball joints on the way, I’ll swap the spindles and calipers when I install those.
Massaged the radiator support and got the larger 22” B-body radiator to fit. I have minimal clearance from the electric fan to the water pump nipple mount for the clutch fan. I might cut/grind off 1/8” for clearance. Once the radiator’s bolted in place I can connect the trans cooler lines.
I need to make a list of all these small things so I can cross them off. I’m hoping to get it moving under its own power soon.
On a positive note, my son just turned 14 and is finally off his Toyota Corolla kick. He mentioned driving the Firebird to High School to impress the ladies. I told him he could take the S-10, and he told me, “No offense Dad, but your truck is not going to impress anyone.” I said, “Exactly, which is why I might let you drive the S-10 to prom.”
