Exhaust bolt removal tip - S-10 Forum
post #1 of 3 Old 04-20-2019, 08:16 PM Thread Starter
EZA
User is: EZA is offline
Some of you may already know of this but in case some of you don't here it is: I was trying to remove the two 14 mm bolts the hold the exhaust crossover pipe on my 95 2.2 (soon to be an L33) and of course they didn't want to bugle even with my 20v impact driver. Of course, I soak them with Blaster over a couple of days and finally got one out. The other required using a swivel socket at an acute angle which is not ideal. So I applied heat as most would do in a stubborn situation even to the point of glowing red but alas to no avail. Then I recalled a tip I had never tried, bring the bolt/nut to a glow and then quench immediately with water. I used a cheap spray bottle with the adjustable nozzle set on jet to cool it quickly. I had to do this twice and added a shot of WD, unscrewing it a fraction of a turn and then back it up and repeat until it broke loose and unscrewed. If you run into a really stubborn rusted bolt try the heat/water method it works!
EZA is offline
post #2 of 3 Old 04-24-2019, 09:26 PM
User is: dime-dozen is online now
Re: Exhaust bolt removal tip
get it red hot,let it cool a little and rub candle wax on the exposed threads
the heat will melt the wax and it will wick up the threads,lubricating them.
I keep an old candle next to the work bench just for that.
post #3 of 3 Old 04-24-2019, 09:33 PM
I'm super serial
manbearpig's Avatar
Also, in my experience you can't beat air tools. I only use my electric impact at the junkyard.
Similar Threads
Are there any "off the shelf" full dual exhaust setups for the 2WD S10 pickup? Racer-X 262ci Forum (4.3) 29 02-20-2019 07:55 PM
01 S10 Starter bolt Phope1127 S10 / S15 2 09-14-2018 09:01 AM
EGR valve bolt thread seymourj98 S10 / S15 11 01-19-2018 05:06 PM
How do you get the bolt out of the positive battery cable? Racer-X Electrical / Lighting 3 08-29-2017 07:58 PM
seat bolt removal firestorm31 S10 / Sonoma 4 09-01-2016 04:00 PM
