Weatherstrip on sides of windshield - S-10 Forum
post #1 of 15 Old 02-16-2019, 08:10 AM Thread Starter
TranceAmerica's Avatar
User is: TranceAmerica is offline
Hey guys, I've got water coming into my cab on the door not the roof top area but the angle going down towards the side mirror. I can't tell which seal that's causing it. How do can I tell is there a test method? My drip edge on top of the door was loose but I put a new one and it didn't fix it. I'm thinking it might be the stripping along the windshield that meets the door it has wear rubs but nothing looks damaged. 03 ls.
post #2 of 15 Old 02-16-2019, 11:49 AM
oldeerslayer's Avatar
Re: Weatherstrip on sides of windshield
Are you hinges sagging and not sealing the door properly?
post #3 of 15 Old 02-16-2019, 01:17 PM Thread Starter
I'm not sure, how would I tell if they were? I noticed a difference in the door reveal where it meets the fender, the top has a bigger gap then the bottom and another thing when I open the door it always wants to close back on me, like someone had over extended the opening on it before.
post #4 of 15 Old 02-16-2019, 01:28 PM
B4U Task Force
Rhotpursuit's Avatar
Open the door, pull up on the handle. If the door moves up, the pins are bad. You can see them move if they are bad.
Apple Red 96 SS
post #5 of 15 Old 02-16-2019, 02:50 PM Thread Starter
Ok pulled up on it, it stayed solid though with the truck bouncing up and down.
post #6 of 15 Old 02-16-2019, 02:59 PM
B4U Task Force
It's probably the short gaskets that go from the door jamb to the beltline. LMC truck...Right at $80 for the pair shipped. Doing it on the Blazer this weekend. They suggest getting the sealer (Loc-Tite) The factory doesn't use sealer...just the double sided tape. The LMC gaskets come with the tape installed.
Apple Red 96 SS
post #7 of 15 Old 02-16-2019, 03:06 PM Thread Starter
The one on the door itself? Yeah I bought that tube of loctite adhesive with a lmc order before but I'm not sure if was the right stripping, I ended up going to an junkyard and getting this one in the pic and putting it but it still leaks.
post #8 of 15 Old 02-16-2019, 03:42 PM
B4U Task Force
Number 16...
http://www.lmctruck.com/icatalog/cst/full.aspx?Page=38
Apple Red 96 SS
post #9 of 15 Old 02-16-2019, 03:54 PM Thread Starter
Ahhhh, I kinda suspected it might be that one too, thanks.
post #10 of 15 Old 02-16-2019, 03:56 PM
B4U Task Force
I've only pulled it back a couple of inches. It's a safe bet you're going to need a 3M adhesive removal wheel to get the tape off.
I've already replaced the one that goes all of the way around the door. Got it a
Rockauto...I have to lean into closing the door....very stiff. I'll probably get another set from LMC.
Apple Red 96 SS
post #11 of 15 Old 02-18-2019, 03:48 AM Thread Starter
3m removal wheel? For a grinder?
Maybe some penetrating lubricant or silicone lubricant or even just oil will soften it up or it might just be too big unless you can place it back further in, rock auto definitely seemed to only have that one that goes around the door and that was about all i saw for selection.
Lmc had the best selection & thanks for that too, I actually ordered the wrong one accidently Im not sure if I can use it yet I havent checked, walmart actually has an all purpose black interior exterior
silicon adhesive sealant for 3$ that might work just as good as that loctite, I threw mine away from Lmc now I need it again lol!
post #12 of 15 Old 02-18-2019, 08:17 AM
User is: dime-dozen is offline
use the dollar bill test or baby powder
close door with a dollar bill in between gasket and body
if it pulls easy theres a gap
Another trick is to sprinkle baby powder on gasket,carefully close door,wet down,look for spots the powder is gone.
for larger vehicles we rigged up a blower to pressurize the cabin and sprayed the outside with foam soap.
This will find a roof leak in an RV in an instant.
post #13 of 15 Old 02-18-2019, 12:35 PM Thread Starter
Ahh, thanks.
post #14 of 15 Old 02-18-2019, 01:45 PM
B4U Task Force
He already has water coming in...it leaks.
Apple Red 96 SS
post #15 of 15 Old 02-27-2019, 07:52 PM
and he doesnt know exactly where
Similar Threads
Lower windshield gasket? kameirocco Exterior / Paint 5 07-06-2018 01:23 PM
Windshield trim ? VeroWing S10 / Sonoma 9 02-05-2018 03:23 PM
Windshield wipers not fully working Evil Jesus Blazer / Jimmy / Bravada 3 08-19-2016 12:11 AM
Windshield defroster/defogger uses A/C only?? Slowpokester S10 / Sonoma 7 07-11-2016 04:11 PM
