Rust on underside - S-10 Forum
 1Likes
  • 1 Post By code_red63366
post #1 of 5 Old 02-19-2019, 03:39 AM Thread Starter
TranceAmerica's Avatar
User is: TranceAmerica is offline
Rust on underside
Hey all, I got some rust starting under the body of this truck, whats the best and easiest way to stop it from continuing to grow? I was thinking maybe just sand it a little and spray some rustoleum rattle can & on the spots maybe prime it first?
Thanks.
post #2 of 5 Old 02-19-2019, 07:01 AM
oldeerslayer's Avatar
Re: Rust on underside
It's best to use a rust converter first. After washing (preferably with a pressure washer) and allowing it to dry, knock off any flaky stuff and spray or brush on. Let the rust converter dry then apply a coat of paint. On an S10 getting it inside the rocker panels, cab corners, and rear wheel arches can be difficult, but that's where it is needed most.
I think Permatex rust treatment is the best value. There are many others like Rust-oleum rust converter and Eastwood rust encapsulator. They all actually dissolve the rust and turn it into a protective coating which should have a top coat applied to it.
I find Eastwood over priced and feel Rust-oleum tends to make their paints a cheaply as they can get away with. That's why I went with the middle priced Permatex. They come in varying sizes and brush on or spray cans.
My first use of it was on a snow plow blade which had to be painted every spring. The paint always seem to come off the first or second use each year because I was spraying over rust by spring. The rust converter, then paint holds up much longer. I refinished an old blade I no longer use years ago and it still looks good with no rust reappearing.
post #3 of 5 Old 02-19-2019, 08:17 AM
Racer-X's Avatar
User is: Racer-X is offline
Use a wire brush (wire brush cup on a drill, wire brush wheel on a die grinder) to remove as much of the loss rust as possible first. If there's rust deep in pitting, you might want to apply "rust converter" to chemically treat that rust.
After that, you can use a phospohric acid solution (10% or so) to etch away what's left and prep it for paint.
Rustoleum paint is good.
There's a rust sealing coating called "Rust Seal" from KBS Coatings that's also excellent, but it's expensive. They also sell a kit with cleaner/degreaser (similar to any other cleaner/degreaser on the market), a "Rust Blast" etching solution (which is just a 10% solution of phosphoric acid, premixed) and the Rust Seal coating.
Another well known rust treatment is POR-15. Used as directed, it's excellent. It's more of a coating/primer and really needs a top coat/seal to complete the job. A lot of people use it as the only treatment/coating, but it's not designed as a weather resistant final finish, it's more of a rust coating primer.
Racer-X is offline
post #4 of 5 Old 02-19-2019, 09:05 AM
94 4x4,01 Blazer
Jayhawke's Avatar
User is: Jayhawke is offline
wash/degrease- dry- prime with rust converter- areas that get hit with wheel throw- undercoat with a rubberized- the seal everything with a semi or if you prefer glossy color of choice.Most go for black, but have seen underpainting to go with or contrast with the body paint job- even seen one truck undershot completely with Silverline galvi roof paint..... too damn shiney
32yrs of wrenching- 8 for Uncle Sam and the rest at various Garages.A bit of knowledge on everything from 2cyc Weedeaters to Jet turbines,with Civil Engineering and Computer As/Repair as a kicker.
Jayhawke is offline
post #5 of 5 Old 03-18-2019, 09:01 PM
code_red63366's Avatar
User is: code_red63366 is offline
Thanks.
Where exactly on the underside is the rust? Cab corners? Rockers? Firewall? Frame? Cab mounts? Fender wells?...etc... some places there's tricks to reaching behind them...and some places not so much. Fluid film slows down the rust or will for now but it will not go away or fix itself until the rust is cut out of the truck and replaced with good sheet metal.
manbearpig likes this.
Mike...... 2001 S10 2.2, Flex fuel, 5 speed, base model, all stock
2nd vehicle.......2003 Ford Excursion, 5.4, gas, 4 wheel drive, all stock
Similar Threads
Rust! Rust! Rust! zuczis S10 / Sonoma 11 02-17-2018 12:18 AM
Salt belt secret to getting rust off frame BackwoodsPatriot Exterior / Paint 3 11-02-2017 03:50 PM
Rust Prevention BlazerJP Exterior / Paint 26 09-29-2017 02:19 PM
Any experience with Blackstar rust converter? Groundhogwhacka Exterior / Paint 1 09-19-2016 09:01 PM
1985 s10 Blazer, 2wd, Rust FREE Project, $500 Georgia KennyC Trucks For Sale 4 07-18-2016 11:07 AM
