Rear glass - S-10 Forum
 1Likes
  • 1 Post By Jayhawke
post #1 of 7 Old 05-14-2019, 11:16 AM Thread Starter
User is: Ozarkpugs is offline
Rear glass
My 2002 s10 pickup rear windshield sliders are gone but the Glass is good , can I get a hardware kit or do I need a whole new glass ?
Sent from my Moto E (4) using Tapatalk
post #2 of 7 Old 05-14-2019, 12:48 PM
User is: kevinp1335 is offline
Re: Rear glass
The seal around my 94 is dried out and cracked (but my glass is good), so I looked around at one point and gave up. Seems you can only get the whole window. LMC Truck has them for our models for $300. If you find out different, let me know.
post #3 of 7 Old 05-14-2019, 01:14 PM
New Member
User is: dime-dozen is offline
Re: Rear glass
is it factory or aftermarket?
post #4 of 7 Old 05-14-2019, 03:05 PM Thread Starter
Re: Rear glass
Factory , someone broke it breaking into the trunk according to original owner . I'm thinking about putting a straight glass in because being a crew cab I'll never be opening it anyway .
post #5 of 7 Old 05-14-2019, 03:29 PM
94 4x4,01 Blazer
User is: Jayhawke is offline
Re: Rear glass
use a piece of plexiglass- it won't break jagged like regular glass- and if you want real glass- pay the $$$ and get TEMPERED SAFTY Glass- it shatters into tiny cubes- the top rail is a little deeper than the bottom- slide up and the drop into lower rail- measure from top to just below top of bottom
Jayhawke is offline
post #6 of 7 Old 05-14-2019, 03:44 PM Thread Starter
Re: Rear glass
The glass is not broken ,all the glass and latch are there it's the slide track that is gone
post #7 of 7 Old 05-15-2019, 12:21 PM
94 4x4,01 Blazer
Re: Rear glass
poster edge- plastic edge for holding a poster and a piece of plexi- or some thin small hardware store hose-split and slide on edge of glass then look in the metal section for a u shaped piece of channel stock
RangerWeaver likes this.
Jayhawke is offline
Similar Threads
Rear window glass Jimmy-in-a-Jimmy Blazer / Jimmy / Bravada 5 01-22-2019 02:46 PM
98 and newer 8.5 s10 rear z11weaver Transmission & Rearend 17 12-12-2018 08:35 PM
Blazer Disc Rear End Adam Ross Exterior / Paint 9 06-23-2018 08:01 AM
rear side glass leaks 2nd gen 2 dr losixxx-nt Blazer / Bravada / Jimmy / Envoy 2 06-19-2016 07:55 PM
You may post new threads
You may post replies
