Ordering Replacement Grille 1998 S10 Base Model - S-10 Forum
 2Likes
  • 1 Post By manbearpig
  • 1 Post By Mostizzle
post #1 of 11 Old 04-19-2019, 06:26 PM Thread Starter
User is: tie_fytr is offline
Hi Guys,
I am doing a 1998+ grille/headlight/bumper swap with my 1997 S10 and I just wanted to know what grille to go with if I'm looking to go with an OEM 1998+ base model with light metallic pewter paint look? I was checking out the grilles on LMC truck and not sure if I should get the dark grey grille and buy the additional chrome molding or get the light grey grille grille with the chrome molding. Looking to do a 1998+ OEM base model so which would I chose? Thanks.
http://www.lmctruck.com/icatalog/cst/full.aspx?Page=82
tie_fytr is offline
post #2 of 11 Old 04-19-2019, 06:46 PM
I'm super serial
manbearpig's Avatar
Re: Ordering Replacement Grille 1998 S10 Base Model
#5 looks to be the base model grill. Unpainted gray with chrome strip.
tie_fytr likes this.
post #3 of 11 Old 04-19-2019, 07:06 PM Thread Starter
Thanks so much for the feedback!
Sent from my SM-G900V using Tapatalk
tie_fytr is offline
post #4 of 11 Old 04-20-2019, 12:46 AM
oldeerslayer's Avatar
Don't forget to get the hardware kit and a center emblem.
I have the red SS one on my 98 ZR2. Technically it's not an SS but with the 6.2L V8 I think it's super sporty.
You'll also need a 98 up radiator support to attach it to.
If you do a search there's a post with the headlight wiring diagram. You might want to do the quad high beam mod at the same time.
post #5 of 11 Old 04-20-2019, 02:40 AM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Those aftermarket grilles are junky. Honestly you'd be better off with a used OEM piece. Even if it takes a little hunting and fixing up once you find one it'll be worth it.
BravadaX likes this.
TelAmeriCorp
post #6 of 11 Old 04-20-2019, 02:46 AM
B4U Task Force
Rhotpursuit's Avatar
Been there, done that...Mo's right.
Apple Red 96 SS
post #7 of 11 Old 04-20-2019, 03:07 AM
Harley's Avatar
User is: Harley is offline
They're also super plentiful in the junkyards. Especially if you plan to paint it anyway.
Harley is offline
post #8 of 11 Old 04-20-2019, 06:47 AM
I'll make it 4 of us that would recommend used OEM first. Plus they'll come with the clips and bowtie. Just be sure to prep it properly before painting.
Anyone have any recommendations short of taking it to a professional body shop. Last 2 I did peeled. Think it was the insane humidity we had here last summer.
Been 8 months and most of southern WI is still dealing with flooding that started last summer.
post #9 of 11 Old 04-20-2019, 08:32 AM
94 4x4,01 Blazer
Jayhawke's Avatar
User is: Jayhawke is offline
reccommend a base coat of Krylon for plastic- then your final color in auto paint- the Krylon will stick better to the plastic and give you a good base- and agree w/ the four wise men above- aftermarket is NOT the way to go- never fit right and most are just plain funky .
32yrs of wrenching- 8 for Uncle Sam and the rest at various Garages.A bit of knowledge on everything from 2cyc Weedeaters to Jet turbines,with Civil Engineering and Computer As/Repair as a kicker.
Jayhawke is offline
post #10 of 11 Old 04-20-2019, 08:24 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Agreed. Aftermarket grilles look terrible and are instantly noticeable. The bowtie fits IN a stock grille. An aftermarket grille the bowtie goes on the grille...
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #11 of 11 Old 04-23-2019, 11:19 PM Thread Starter
I ordered an 1998+ OEM grille, chrome strip and emblem. Thanks everyone for the push and advice.
tie_fytr is offline
Similar Threads
Can't find Intake Manifold for 1998 s10 2.2L. Any advise? CobbCountyEagle 2.2L - 2nd gen 4-banging 4 01-28-2019 08:54 PM
80 model Dana 44 Corvette rear diff in a S10? Dgoodwin72 Transmission & Rearend 10 01-25-2019 12:58 AM
1998 s10 dieing cody mofield S10 / Sonoma 1 12-12-2017 07:14 PM
2001 S10 V6 4.3 liter wont start after fuel pump replacement!!! robbieholtz 262ci Forum (4.3) 6 05-30-2016 04:25 PM
1998 s10 Mirror JacobRiela Exterior / Paint 0 05-30-2016 12:33 PM
