Header paint - S-10 Forum
View Poll Results: Header paint
High heat silver 1 33.33%
No paint, natural SS 1 33.33%
Other color 1 33.33%
Voters: 3. You may not vote on this poll
 12Likes
  • 4 Post By Rhotpursuit
  • 2 Post By Racer-X
  • 1 Post By goes2fast
  • 3 Post By 98Sonosls
  • 2 Post By Racer-X
post #1 of 15 Old 12-01-2018, 09:38 PM Thread Starter
94_Foe_Doe's Avatar
User is: 94_Foe_Doe is offline
Header paint
Opinions wanted:
SS Hooker Headers, paint High heat silver, other color, or leave natural SS?
post #2 of 15 Old 12-01-2018, 09:39 PM Thread Starter
94_Foe_Doe's Avatar
Re: Header paint
Wasn't sure where to post this, engine or paint. Paint related, so I stuck it in here.
post #3 of 15 Old 12-02-2018, 12:11 AM
Nick Dean's Avatar
User is: Nick Dean is offline
Re: Header paint
if there was a chrome heat paint id go for that. if not silver would prolly look good
post #4 of 15 Old 12-02-2018, 12:41 AM
B4U Task Force
Rhotpursuit's Avatar
Re: Header paint
If they're stainless...why paint them at all?
Apple Red 96 SS
post #5 of 15 Old 12-02-2018, 12:42 AM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Re: Header paint
Leave em'.
TelAmeriCorp
post #6 of 15 Old 12-02-2018, 05:04 AM
94 4x4,01 Blazer
Jayhawke's Avatar
User is: Jayhawke is offline
Re: Header paint
if going with headers to save weight- have you thought about the increased underhood heat- color should be- glass wrap heat tape.
32yrs of wrenching- 8 for Uncle Sam and the rest at various Garages.A bit of knowledge on everything from 2cyc Weedeaters to Jet turbines,with Civil Engineering and Computer As/Repair as a kicker.
Jayhawke is offline
post #7 of 15 Old 12-02-2018, 08:37 AM Thread Starter
94_Foe_Doe's Avatar
Re: Header paint
This was my original thought.
post #8 of 15 Old 12-02-2018, 08:58 AM
Racer-X's Avatar
User is: Racer-X is offline
Re: Header paint
Let me fix that for you.
if going with headers to save weight- have you thought about the increased underhood heat- color should be- glass wrap heat tape thermal barrier coating in your choice of color.
And when talking to the coating people, make sure they do the inside of the tubes. Actually, thermal barrier coating on the inside of the tubes, and natural stainless on the outside would be my choice.
98Sonosls and goes2fast like this.
Racer-X is offline
post #9 of 15 Old 12-02-2018, 12:28 PM
Old Fart
goes2fast's Avatar
User is: goes2fast is online now
Re: Header paint
In my experience header paint does not last, a waste of time and money. Thermal coating is the only way to go, keeps the heat down, especially when you do inside, and out, and when done right, lasts forever.
98Sonosls likes this.
Too Much Horsepower is ALMOST ENOUGH!
"I have a car-sickness. I need to be checked into the HENRY Ford Clinic." -Tim "The Tool Man" Taylor
post #10 of 15 Old 12-17-2018, 12:52 AM
2003 standard cab LS
MidnightBlue's Avatar
User is: MidnightBlue is offline
Re: Header paint
Originally Posted by 94_Foe_Doe View Post
Opinions wanted:
My vote goes for the natural stainless steel finish.
post #11 of 15 Old 12-17-2018, 12:33 PM
LS3 Cruisin'
98Sonosls's Avatar
User is: 98Sonosls is offline
Re: Header paint
I started with just painted black stainless steel headers, under hood heat was pretty high, and I melted wiring loom on a few spots, and burned a silicone spark plug boot, I also had issues with the brake line running to the passenger caliper picking up a lot of radiant heat.
I ended up having the headers thermal coated inside and out, dropped header temps 250-300 degrees. You can touch the headers a few minutes after engine shut-off now, before you needed like 45min+ before you could touch'em. The engine bay is wayyy cooler now and nearby looms and hoses are not warm at all.
I don't think I'd ever do non-thermal coated headers on a project vehicle again. It cost me as much to have the headers thermal coated as it did to buy them in the first place, but worth every penny imo.
I thought I was going to have to upgrade my rad fans (I have dual 12" spal currently) or get a cowl hood/put some louvres in, but now the hi mode barely ever comes on.
chevymec, 94_Foe_Doe and goes2fast like this.
post #12 of 15 Old 01-09-2019, 10:07 AM Thread Starter
94_Foe_Doe's Avatar
Re: Header paint
Okay, about to pull the trigger on sending my headers to Jet-Hot to get coated. Any other companies better, less expensive? They quote $300 to coat inside and out. Anyone have experience with them? They seem to be about the most popular one for coating. Looking for advice. Thanks!!
post #13 of 15 Old 01-09-2019, 11:49 AM
Racer-X's Avatar
Re: Header paint
It's been several years since I used them, but definitely worth the price, even though the price is high.
Racer-X is offline
post #14 of 15 Old 01-10-2019, 03:31 PM Thread Starter
94_Foe_Doe's Avatar
Re: Header paint
What kind of coating and who did/have you used?
post #15 of 15 Old 01-10-2019, 04:25 PM
LS3 Cruisin'
98Sonosls's Avatar
Re: Header paint
Used a company local to me up here in the cold north... Fireball Coatings. Exterior are ceramic coated, interior XMC coated, which is some kind of 3 layer composite ceramic sprayed in.
Its worth noting that they're just a small hole in the wall shop, they don't actually manufacture any of the chemical compounds used, ergo its probably from the same or similar supplier as places like Jet Hot get their material from. The info is pretty hush hush, but no doubt its just some 3M, Dupont, or other chemical company making the stuff and shipping it in 5gal pails. Probably has some random trade name with a number on it no different than bulk industrial coatings, powder coat etc.
