Fix roll pan or replace - S-10 Forum
post #1 of 2 Old 02-25-2019, 08:40 AM Thread Starter
User is: Carp0331 is offline
So I just picked up a 01 blazer x and the previous owner notched the roll pan to fit a hitch. I removed the hitch and I’m left with a good 1” seam on both sides. Should I just fiberglass the back side and bondo the front? If I replaced it who sales on identical to this or one that will work. I’m not sure if the dimensions compared to a regular s10. Also where can I find the xtreme end caps as I would like to modify them to fit or get some for the shaved sides. Thanks!
Carp0331 is offline
post #2 of 2 Old 02-25-2019, 03:32 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Re: Fix roll pan or replace
A couple companies used to offer 3pc roll pan kits for the Xtreme Blazer....
I'm not sure if there's still some out there or not.
TelAmeriCorp
Similar Threads
83 S10 2.8 broken engine removal/swap, fix or replace Yowakawaka 60v6 Forum (2.8/3.4) 33 03-27-2019 11:49 PM
Roll pan GJSZ51 Wanted, to Buy 0 11-27-2017 09:57 PM
Roll Pan?! DESTROYERRACER S10 / S15 1 03-05-2017 08:30 PM
Anyone make a compound curve roll pan anymore? TuckaBlaze Off-Topic 0 07-26-2016 03:50 PM
Roll Pan for Jimmy Baxter.paul89 Exterior / Paint 0 06-20-2016 09:45 PM
