Economical Paint - S-10 Forum
 1Likes
  • 1 Post By dime-dozen
post #1 of 15 Old 03-05-2019, 04:27 PM Thread Starter
EZA
New Member
User is: EZA is offline
Economical Paint
Will be doing some chassis, rear end painting etc. and will need about a quart of black paint. Something that can be thinned for spraying. I want something economical not overpriced.
EZA is offline
post #2 of 15 Old 03-05-2019, 04:46 PM
New Member
User is: dime-dozen is offline
Re: Economical Paint
Use the rustoleum pro series semi gloss black.
I use a hardener with it and its pretty good and cheap.
thin it 10%.
About $10 a qt at the box stores
remember the key to a good paint job is good prep.
post #3 of 15 Old 03-05-2019, 05:08 PM Thread Starter
EZA
New Member
thin it 10%.
Thin with mineral spirits or does Rustoleum take a special thinner?
EZA is offline
post #4 of 15 Old 03-05-2019, 06:26 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
https://www.summitracing.com/parts/r...xoC7MkQAvD_BwE
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #5 of 15 Old 03-05-2019, 06:49 PM Thread Starter
EZA
New Member
I did a search and acetone seems to be recommended for thinning though mineral spirits can be used for clean up.
EZA is offline
post #6 of 15 Old 03-05-2019, 06:51 PM
New Member
thats what I use
use enamel hardener
otherwise it takes days for it to cure
EZA likes this.
post #7 of 15 Old 03-06-2019, 03:59 PM
User is: Rocky X is offline
I need someone to economically paint my whole truck... I can't spray to save my life! I can do bodywork all day long, I can bondo or weld your ******* shut (if you don't walk too fast) but paint, nope!
Rocky X is offline
post #8 of 15 Old 03-06-2019, 05:28 PM Thread Starter
EZA
New Member
Well, I've never painted a complete vehicle, the actual spraying is something that takes practice to master. The real work is in the prep. I think I have some automotive white I can practice with before I paint mine.
EZA is offline
post #9 of 15 Old 03-06-2019, 05:49 PM
Boozebag
Mad Max's Avatar
Solid colors are easy to spray. As long as you go with the manufacturer's instructions, the process isn't terribly difficult.
When you run into differing weather conditions, that's when it becomes a little trickier.
Hot weather will cause quick flash off = paint dries too fast and can dull.
Cold weather will cause paint to run = faster reducer and don't mud on the paint.
Clear coat is also fairly easy to apply. Apply a 1st tack coat, then double pass 2 to 3 more coats.
Most clear coats are 2 part. In other words, they don't use a reducer. I have had to add reducer in some cases when the clear doesn't "flow". Usually on the last coats.
Poly metallic paints are another story. Zebra stripes are common - if you don't know how to apply the metallic paint. Generally speaking, you have to "dust" it on. Keep your gun away from the panels. It takes more paint and time to apply.
Hope this helps.
Confucius say: Paint spray make magic...
S10 addiction:
Mad Max is offline
post #10 of 15 Old 03-06-2019, 06:36 PM Thread Starter
EZA
New Member
So what type of paint is easiest for the novice to do at home...no spray booth but a big compressor and HVLP gun.
EZA is offline
post #11 of 15 Old 03-06-2019, 07:44 PM
New Member
depends on what youre trying to paint
chassis parts is a good place to start
semi gloss black enamel is about the most forgiving
heck the factory even had runs in it,and alot of the stuff was dipped.
Just for kicks try this
5 gallon bucket almost full of clean water.
pour about a half inch of rustoleum very slowly on top of the water.
Very carefully push the part youre painting thru the paint going slow and steady to get complete coverage.
once its completely coated quickly pull it out and hang to dry.
post #12 of 15 Old 03-07-2019, 08:27 PM Thread Starter
EZA
New Member
I see two problems. First, that rear-end won't fit in a five-gallon bucket. Second, when I was young and fifteen lbs heavier I could have lifted the rear-end but not risking an injury at my age. LOL
EZA is offline
post #13 of 15 Old 03-07-2019, 08:33 PM
New Member
factory doesnt "dip" large parts...Well some do.Ive seen videos of heavy equipment being totally submersed.
Im sure you ll have something smaller to paint.
post #14 of 15 Old 03-07-2019, 08:40 PM Thread Starter
EZA
New Member
LoL...my attempt at humor. Interesting concept can't say I've ever heard of it before.
EZA is offline
post #15 of 15 Old 03-08-2019, 08:04 PM
New Member
https://www.pacline.com/solutions/pa...tems/dip-line/
just to give you an idea of how its done on a large scale
Similar Threads
Considering urethane paint for respray OldDogTrickShow Exterior / Paint 15 06-20-2018 07:46 PM
Touch-Up Paint & More at RockAuto.com! RockAuto RockAuto 0 04-12-2018 02:31 PM
Best Paint? tyreln Exterior / Paint 1 03-24-2018 08:24 PM
Vortec Intake Paint webkruzer S10 / S15 0 01-19-2017 08:19 PM
I want to paint my s10 jrumberger23 Exterior / Paint 11 06-07-2016 05:50 PM
You may post new threads
You may post replies
