door hinge parts for 2nd gen - S-10 Forum
 1Likes
  • 1 Post By oldeerslayer
post #1 of 17 Old 01-26-2019, 10:24 AM Thread Starter
User is: dime-dozen is offline
anyone know if they sell the detent roller pin?
Im guessing it would be the same right and left
also could use the GM part numbers for the door pins,
I have plenty of bushings(GM sells a package of 25)
post #2 of 17 Old 01-26-2019, 10:33 AM
94 4x4,01 Blazer
Jayhawke's Avatar
User is: Jayhawke is offline
Re: door hinge parts for 2nd gen
hey d-d- quickly start calling local gm dealers- mine up here is frozen arse land is starting to PHASE OUT ALL S-10 PARTS... some i do think the main warehouse is running out of our parts....
32yrs of wrenching- 8 for Uncle Sam and the rest at various Garages.A bit of knowledge on everything from 2cyc Weedeaters to Jet turbines,with Civil Engineering and Computer As/Repair as a kicker.
Jayhawke is offline
post #3 of 17 Old 01-26-2019, 12:41 PM Thread Starter
yea Im amazed at all the stuff that goes in the dumpster
My son worked at a Pontiac/GMC dealer and parts dept cleaned house,old stuff went in dumpster.
They also closed the body shop so let him have a few items.
Not much call for Aztec fenders,Vibe bumpers etc. Still in the GM boxes.
post #4 of 17 Old 01-26-2019, 02:56 PM
oldeerslayer's Avatar
The roller is part of a 3 piece assembly. The upper pin pressed into the door hinge and a lower roller and pin pressed into the upper pin.
The roller fits all S10's - 1982-04 Chevy S10 Pickup Front Lower Driver or Passenger Side General Motors OEM #20058035.
The big long pin which may or may not need replacing (only if it's bent) is #14030534. Rock auto has them.
The lower pin is the stumbling block. Can't find them anywhere. I'd go to a junk yard and knock one out, which will destroy the roller, but those you can buy.
3rd gen Camaro ones are available, but they fit 1st gens. Since the rollers are all the the same it might work. Care to be the guinea pig?
https://www.hawksmotorsports.com/bus...r-bushing-pin/
post #5 of 17 Old 01-26-2019, 03:42 PM
https://www.s10forum.com/forum/f137/...-toast-765026/
Part numbers are in post 5. Still available from some dealers.
Genuine GM 14030534 Door Hinge Stop Pin, Front
Genuine GM 20058035 Door Check Link Roller
GM 20262500 PIN
https://www.wholesalegmpartsonline.c...roduct=2810955
Amazon has the little pins
https://www.amazon.com/General-Motor.../dp/B002AGIGMG
jayyk31 likes this.
post #6 of 17 Old 01-26-2019, 07:52 PM Thread Starter
I have the lower pin that looks like a bullet
as far as Im concerned those are not re useable
it looks like the detent roller pin ending in 534 is the one I want
Im using my own improved roller so hopefully it wont ever need done again.
Yes the roller was bad so some PO bent the **** thing and pulled the spring out.
I think its staked(crimped) in there so may need some careful surgery to remove the old one.
wow $6 each? I think I paid about $1 ea but had to buy pack of 10
But that pin is used in a lot of GMs,I should get another pack of 10.
post #7 of 17 Old 01-26-2019, 08:14 PM Thread Starter
and I dont know why I didnt look on RA since they dont carry that Dorman crap anymore.
post #8 of 17 Old 01-26-2019, 10:01 PM
The discount dealers get around $15 for each piece. Around $45 for the set.
$55 to 60 at your local stealership.
post #9 of 17 Old 01-26-2019, 10:40 PM Thread Starter
just bought 4 sets of GM door pins(8 total)$25
maybe the bid I made on detent roller pin will come thru
so I can rebuild this one.
post #10 of 17 Old 01-27-2019, 03:52 PM
Post Whore
chevymec's Avatar
User is: chevymec is offline
I know you can buy the entire pic assembly from Napa, I wonder if you could just disassemble it?
1997 SS---Built and Blown... almost
My build thread... https://www.s10forum.com/forum/f30/pr...ecs-ss-513887/
chevymec is offline
post #11 of 17 Old 01-27-2019, 05:00 PM Thread Starter
I would rather stick to GM parts on this one.
I see Dorman sells the complete thing(roller ,roller pin,and big pin. for $12.
Im betting the NAPA one is just a rebranded Dorman,but thanks for mentioning
post #12 of 17 Old 01-27-2019, 08:32 PM
jayyk31's Avatar
User is: jayyk31 is offline
Buy it from GM or GM NOS on ebay. I bought mine from the dealer last year. Gm used same theu sifferent platforms too.
-NEW DAILY. '86 Blazer 54k miles!!!
https://www.s10forum.com/forum/f20/my-new-gem-815417/
'92 EXTENDED Cab 408 LSx t56 Magnum!!!
Build thread-
https://www.s10forum.com/forum/f213/l...56-n-a-665850/
-2000 RCSB 2.2 5 speed.... SOLD!!!
jayyk31 is offline
post #13 of 17 Old 01-27-2019, 08:35 PM
jayyk31's Avatar
Ist gen lower small pins are the same as 2nd gens. Bought a set from the dealer for my 92.
And ive seen them NOS gM on ebay.
Build thread-
jayyk31 is offline
post #14 of 17 Old 01-28-2019, 12:22 AM
I looked at Dorman's listings, are you sure they were the correct ones for an S10 and not a fullsize or some other model?
When I did mine one lesson I learned the hard way is it's easiest to cut the old big pin into pieces and knock it out in pieces. If you pound too hard on it you can bend the hinge. And when you pound the new pin up into the hinge, do it before installing the lower little pin and roller and protect the end of the big pin. Don't hit it directly with the hammer. Or use a brass or plastic hammer. That big pin seems to be cold rolled steel and the end is easy to mushroom. Which will make getting the small pin in very difficult if not impossible.
You'll also need a new spring for the arm if the old one is gone and a door spring compressor. They're cheap on ebay.
And grease the living crap out of everything before, during, and after installation. I used waterproof wheel bearing grease.
post #15 of 17 Old 01-28-2019, 05:31 PM Thread Starter
ok thanks
over the years Ive made a science out of door pins,bushings,hinge rebuilds.
Many of the older GMs used the same set up,just a little variation of parts.
Ive made a few specialized tools to removal and install .
Was doing so many at one time that I made a caddy for my floor jack to hold and position doors,
so they dont have to be disconnected,just never have had the need to replace the complete roller pin assembly.
post #16 of 17 Old 01-29-2019, 12:48 AM
It's rare. I had one where the spring had fallen out and the PO had slammed the door and bent the bottom of the big pin. Fortunately I was able to straighten the arm (lever, follower, whatever) with a BFH.
It's a common occurrence when the hinge pins get real loose, but most people have enough sense to fold the lever out of the way.
post #17 of 17 Old 01-31-2019, 05:53 PM Thread Starter
common sense? youre giving people too much credit
