Bumper is loose - S-10 Forum
post #1 of 6 Old 03-01-2019, 07:37 PM Thread Starter
Tedster's Avatar
User is: Tedster is offline
Bumper is loose
HI all, I recently bought a 2001 Sonoma 4x4 V6 and I noticed the front bumper is pretty loose, moves up and down. Where does it fasten? On the sides or in the middle?
Also I noticed that on the front wheel fenders, the bottom of the fender is closer to the top of the tire on the passengers side than it is on the drivers side. (see attached pic) Whats up with that? lol. Its about an inch difference. One shock is worse than the other? Both front struts seem nice and stiff.
Thanks all.
2001 GMC Sonoma V6
Tedster is offline
post #2 of 6 Old 03-01-2019, 08:53 PM
Racer-X's Avatar
User is: Racer-X is offline
Re: Bumper is loose
The bumper is held on by socket head torx bolts (T50 or bigger IIRC). They are under the grill and/or the headlights, at the end of the frame rails. You have to remove the grill (and maybe the headlights) to get to them all.
Your wheel gap difference is either a dead (seized) shock absorber holding one side up, or the other side collapsed/dead letting it sag, or possibly the torsion bars are misadjusted, or maybe one of the torsion bars is rusted out/damage. More inspection is needed. You really need to look at the torsion bars and the control arms and see what the positions/angles of the control arms are. It would be best to compare those angles to a known good condition truck.
Racer-X is offline
post #3 of 6 Old 03-03-2019, 10:07 PM Thread Starter
Tedster's Avatar
Re: Bumper is loose
So in this area is where it attaches?
2001 GMC Sonoma V6
Tedster is offline
post #4 of 6 Old 03-03-2019, 10:13 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Bumper is loose
Take a look under the front end at the frame horns. There are bolts there.Then look at the sides of the bumper and you will see a bracket on each side that bolts up where the radiator supports on either side are.
Apple Red 96 SS
post #5 of 6 Old 03-03-2019, 10:41 PM
I'm super serial
manbearpig's Avatar
Re: Bumper is loose
Is the bumper loose, or just the cover? The cover just slips on and is secured with plastic push rivets at the top of the license plate frame and round pegs at the bottoms of the fenders.
post #6 of 6 Old 03-03-2019, 11:01 PM Thread Starter
Tedster's Avatar
Re: Bumper is loose
Oh yes sorry I didn't clarify, just the plastic cover is loose. Thanks.
2001 GMC Sonoma V6
Tedster is offline
Similar Threads
1997 Rear Bumper Swap tie_fytr Exterior / Paint 2 12-28-2018 11:00 PM
Help an old man get a rear bumper zachlc S10 / Sonoma 6 02-22-2018 09:58 PM
Bumper rubs on my grille aguy Exterior / Paint 1 12-22-2016 05:41 PM
ZR2 front bumper skin question D'mon ZR2 - BlaZeR2 - Highrider 10 08-01-2016 08:17 PM
rear bumper end? extension? Tim6152 S10 / Sonoma 5 06-07-2016 09:33 PM
