2001 ZR2 Blazer trip odometer inop - S-10 Forum
post #1 of 5 Old 01-10-2019, 09:48 AM Thread Starter
now-in-Texas's Avatar
User is: now-in-Texas is offline
I've owned this vehicle for over 5 years and the trip odometer has never worked correctly. I was told by the previous owner that the gauge cluster was changed at some point. The miles count up as they should but reset every time the vehicle is restarted. No problems with any gauges and no dash lights are on.
post #2 of 5 Old 01-10-2019, 06:40 PM
User is: dime-dozen is offline
Re: 2001 ZR2 Blazer trip odometer inop
sounds like a keep alive circuit has been compromised.
Is the regular odometer ok and doesnt reset?
theres an eeprom that stores info
look and see if its had any pins removed
radios have something similar and you remove pin 8 on that to circumvent the power to that chip
post #3 of 5 Old 01-11-2019, 06:48 AM Thread Starter
Everything else functions as it should including the regular odometer. Where am I looking for said EEPROM and pin 8?
post #4 of 5 Old 01-11-2019, 01:38 PM
that was in reference to radios that use the VIN to id
memory is an 8 pin chip
would imagine that the same style is used in the trip odo
post #5 of 5 Old 01-11-2019, 04:16 PM
oldeerslayer's Avatar
Easiest fix would be to just pickup another cluster from a pic and pull. Easy in and out. Just be sure you get one with or without tach, automatic or stick, and floor or column shift to match yours. IIRC all suv's had floor shift and very few trucks. Best if it's the SAME year.
