TIMKEN Vs. NATIONAL - S-10 Forum
View Poll Results: Which bearing (IYO) is superior?
Timken 8 61.54%
National 1 7.69%
Other (post info plz) 2 15.38%
You win with either brand! Go for the best price! 2 15.38%
Voters: 13. You may not vote on this poll
post #1 of 6 Old 11-03-2012, 07:05 PM Thread Starter
Dig Or Die=I Die
12sws27's Avatar
User is: 12sws27 is offline
TIMKEN Vs. NATIONAL
Which one wins? I'm looking at small sealed bearings like alternator bearings.
If there is another brand you find superior, vote "other" and post up info.
1998 GMC Jimmy, 2dr/2wd, 4.3L auto: Wynjammer S/C @8psi, Accel 300+ ign box, Taylor 8mm wires, CFM-Tech tb blade, Trans-Go shift kit w/vette servo, cat delete, Hooker Maxflow muffler, Zexel Torsen LSD, Marine intake, 42lb/hr injectors, aeromotive stealth 340 in-tank pump, racetronix fuel pump wiring harness, AEM UEGO W/B A/F gauge, LS1 E-Fans, self tuned w/HPTuners, best 1/8th mile E.T. so far: 2.26 60' [email protected] <<<6psi.
12sws27 is offline
post #2 of 6 Old 11-04-2012, 12:55 AM
2.2 Extremist
GMC Motorsports's Avatar
User is: GMC Motorsports is offline
Re: TIMKEN Vs. NATIONAL
I'm gonna say I've had great luck Timken bearings. Only issue I'm having right now with anything Timken is my driveshaft carrier bearing but I beleive it is because of the shop that did it pressed it on wrong.
2000 GMC Sonoma SLS
ECSB 2.2L Flex Fuel L43 bored 0.40, 0.20 head shave, 5-Speed, 4.10 gears, Space Blue Metallic, Graphite Int, OBX Header, straight pipe cat delete, Thrush Welded, urethane motor mounts, ZQ8 sway bars, Hurst Short Throw Shifter, ClutchMasters 9lbs flywheel
Other Rides: 09 Canyon 5.3 ZQ8, 05 Duramax, 85 Monte Carlo SS.
post #3 of 6 Old 11-17-2012, 11:26 AM Thread Starter
Dig Or Die=I Die
12sws27's Avatar
I bought timkins. Both brands have the same part number on this particular bearing size, so i'm sure they're made by some one else and sold by both companies.
12sws27 is offline
post #4 of 6 Old 11-17-2012, 12:01 PM
Registered Hoosier
Hoosier Rick's Avatar
I look at where they are made. USA are usually the best quality, then Japanese.
China made bearings are a crap shoot.
1992 rcsb 4.3,at 357,000 miles. Rust in Peace
2002 rcsb, 2.2 at, 289,000miles
1967 C10
2006 Colorado
post #5 of 6 Old 12-09-2012, 09:18 AM
S10 Frame Swapper
3800_Convert's Avatar
User is: 3800_Convert is offline
Send a message via AIM to 3800_Convert
SKF from NAPA. I won't use anything else.
post #6 of 6 Old 12-09-2012, 10:56 AM
User is: frostystones is offline
I've used NTN for over 10 years, never had a problem.
You may post new threads
You may post replies
