The Gears of War truck - S-10 Forum
post #1 of 154 Old 09-06-2011, 04:56 AM Thread Starter
DOT COM
Hamstar's Avatar
User is: Hamstar is offline
Lightbulb The Gears of War truck
From time to time I paint my truck, the last couple of times it was a Halo based theme.
This new version is a bit more than just a rattle can paintjob, I’m going with Gears of War this time.
The only thing I've gone into this knowing is that I want to change out the bed of the truck because of extreme rust and use damage, that I want to put HUGE obnoxious headlamps in it, and I want to paint it with a Gears of War theme.
Let the adventure begin.
First was bed selection.
My wife picked out a Ford bed to go on a Chevy truck.
Specifically a bed from a Green 1999 Ford Ranger XLT
After a time, I extracted the truck bed goodness and got it home
After offloading the bed by myself I had to clean up all of the glass in the back... I never thought I would vacuum a lawn!
Trying to remove the truck bed turned out to be a lot trickier than I imagined.
I don't accept this answer, and propose my own.
After taking it to the frame
The frame needs sub structure to support the new bed
Next it needs a deck, because I have future plans for this truck that go beyond the scope of a pickup, so while I have it apart, I'm doing the work now.
I tried to marry the bed to the truck by myself and as a result I damaged the right rear quarter
If you get angry enough, and you're willing to sacrifice materials, you can get the bed of the truck on the back (it's sitting on blocks on the deck in this shot)
Next was a modification of the fuel neck, remember this was a Ford going on a Chevy
So lines had to be made
I still need a tailgate and tail lights... luckily eBay was a great resource for tail lights.
Attaching the bed snapped bit after bit, and at $20 a pop... it was getting to be a pain around the 5th bit
I had to create a wire harness to adapt Chevy lights to Ford plugs
hacking up the front of the truck was the next obstacle
After hacking up an aftermarket billet grill, I then had to get it to work with some really cool obnoxious headlamps
There was some cutting of the back base to get the grill to mount, with lots of custom mounts.
I had to make the grill in two sides
It took a bit to get them to merge, and even more to wire everything up
The final cuts with the new harness in place
testing
Both in place
Fully together
Now if you're asking yourself "what does this modification have to do with Gears of War?"... then you don't play much
See it now?
Hamstar is offline
post #2 of 154 Old 09-06-2011, 04:58 AM Thread Starter
DOT COM
Hamstar's Avatar
Re: The Gears of War truck
With the grill and lights in place it's time to clean up my sloppy lines
I bought a strip of aluminum, cut it, and then with a pair of pliars bent it up to match the profile of the grill.
I just eyeballed it, and for some reason beyond my control... it turned out perfect the very first time.
That was not part of the plan.... usually it's 2-3 attempts.... tons of materials wasted, at least a bit of blood from some new wound in the creation followed by some choice words and dancing around to get it right.
I'm not sure happened here, but apparently I punched my "got it right the first time" card, and it will never happen again.
In the meantime... bumper in place here is the new front of the truck
I've had a lot of complaints that I put all that work into putting the bed on the back... and went all MySpace photo angle with it and never actually showed the thing... so here you go, this is the truck intact
Now for however long its going to take to get the body prepped for paint.
I suspect a week.
We're getting to the paint phase of the mod, and while I would love beyond gumdrop dreams and unicorn wishes to repair the body & remove damage like this
then have a professional looking paintjob... the truth is, I simply don't have the resources, and if I did I would use them to improve the quality of our life by paying off bills.
It's a harsh reality, but I accept my station in life and I'm content to try not to live beyond my means.
That being said I did mud up the right quarter that I damaged trying to He-Man the bed on by myself.
Now I don't claim to be all that and a side of fries with Bondo... as a matter of fact I wouldn't even qualify my skills as passable.
I can however lay claim that I can sculpt in Bondo like nobody's business, and I'm hoping to tap into that skill set and pull this repair off.
for now being a work night all I can do is mud this sucker up, and cover it with primer in it's boogered up/unsanded state.
The picture is flattering... I promise you it looks like crap in real life
The other side however took the prime just fine... bear in mind this is a first coat.
Time is not my buddy today so all I could really do is hit the drivers side up to the Locust Eyes grill
As you can see that chewy body rott is still there, and later on when the paintjob looks amazing, this is where the rust is going to flake it off at as it has done time and time again
I still have a ton to do as you can see.
I started cleaning away on the passenger side when a large chunk of the body just fell off!
I know I know, quality.
At this point the body really is a lost cause and I have no clue how to get it back to normal without throwing an obscene amount of money (which I don't have) at it.
I appreciate what I've got, I just wish I could do more.
That being said I figured the bed needed a little "charm" to match the front... yes I know it's weird to want to distress the back to match flaws on the front but it just didn't look right.
So that corner I bondoed the hell out of... I textured to look like body rott.
Yes... I really felt like that was worth a couple of hours when it would have been faster to sand it smooth to match the body. We all have our quirks, I like uniformity even in my chaos.
So time to hit the beast with a sloppy coat of Ruddy brown
Now I bought a little silver paint
and started going happy go nuts on the body as a base... I mean I picked a base coat of silver that is just as gawd-awful as the headlights, I mean I hit gold on crappy silver
Oh yes, I'm digging the streaks, this thing screams "Ghetto Fabulous!"
I've had a design locked in my head since day one... before day one actually... either way I has plans.
I started with the taping
remember this is a reversal, so the silver is not the actual paintjob... there has to be some black in there
The reveal
I liked the idea of a little cog gear, but I wanted it to give the taper down... so I used my logo, but I think I'm going to remove it and use that space for a bit more design and less plugging the site.
This isnt done, and that logo wont be so pronounced later
Add in a Crimson... but not too crazy
Lets get the grill and bumper in there
There is still more to do with the paintjob
Hamstar is offline
post #3 of 154 Old 09-06-2011, 06:30 AM
Need to DO WORK son
Innis's Avatar
User is: Innis is offline
wow i dont know what to say......
2001 S10 Bagged - Just need to DO WORK!
Innis is offline
post #4 of 154 Old 09-06-2011, 08:41 AM
phoxxxey's Avatar
User is: phoxxxey is offline
phoxxxey is offline
post #5 of 154 Old 09-06-2011, 08:49 AM
Compliance!
koeberle04's Avatar
User is: koeberle04 is offline
jesus christ does this actually get driven?
Neil
2000 - S10 - 2.2 - Vin 5 Flex - RCSB - Auto - 130k
post #6 of 154 Old 09-06-2011, 08:57 AM
austinsatterfield's Avatar
User is: austinsatterfield is offline
Why?
94 S-10, 2.2 5speed D/d
89 S-10, 383/th350 AFR 195 heads, eagle crank and rods, Dome 11.5:1 pistons, Howards Soild Ft .543 .562, roller rockers, airgap intake, Holley 750 DP, Mallory ignition, and 3.73 Best is 6.89 @ 98.84mph and droping
88 S10, 2.5 speed old D/d
post #7 of 154 Old 09-06-2011, 09:45 AM Thread Starter
DOT COM
Hamstar's Avatar
It's my winter beater, it gets driven quite a bit, it's used for hauling both in the back, in the trailer I made for it, and it used to be setup for hauling cars... specifically a Tracker I bought for my wife that broke down enough to necessitate a custom tow package
Hamstar is offline
post #8 of 154 Old 09-06-2011, 09:49 AM Thread Starter
DOT COM
Hamstar's Avatar
Originally Posted by austinsatterfield View Post
Why?
Why not?
The body on the truck is shot to hell... I mean falling off in large chunks, so I wanted to "wash" it
The first two paintjobs were Halo keeping in theme with the wash, I thought it would be fun to hack up the truck and get all happy go nuts with it.
This is actually pretty tame compared to what I've done to vehicles in the past.
Hamstar is offline
post #9 of 154 Old 09-06-2011, 10:26 AM
<>Severed TIES<>
The SGT's Avatar
User is: The SGT is offline
hmmm....
Project 91 s10 laid on 24s---https://www.s10forum.com/forum/f30/pr...nistan-468996/
Hooies Fab Shop facebook page
http://www.facebook.com/?ref=home#!/...fabshop/photos
<>Severed TIES<> ky chapter
The SGT is offline
post #10 of 154 Old 09-06-2011, 10:36 AM
Need to DO WORK son
Innis's Avatar
Ok so this is more of ajoke than anything? like this isnt your pride and joy kinda truck is it? its just a winter beater your having fun with?
Innis is offline
post #11 of 154 Old 09-06-2011, 10:51 AM
I SHIT BRICKS
OneLowSdime's Avatar
User is: OneLowSdime is offline
Send a message via AIM to OneLowSdime Send a message via Yahoo to OneLowSdime
i hope its just somthin hes havin fun with lol looks like hes doin it as cheap as possible so hopfully its not somethihng hes tryin to be proud of lol
post #12 of 154 Old 09-06-2011, 10:54 AM
4 bangin and love it
squareterror's Avatar
User is: squareterror is offline
i love he syas he has no money. why not pay the bills, rather than spend the few hundred in bed, bondo, paint, tape and all the misc shit? then play later, once you've got the money
95 Civic coupe-RHD swapped, b16a/y21, bordeux red/captiva blue, dumped on 17's, just a daily/family car
03 QX4-litteraly bone stock. Wife's daily, and im not allowed to touch it.lol
93 Del Sol SI-FF time attack/daily build in progress. we'll see what all happens as it goes.lol
post #13 of 154 Old 09-06-2011, 11:04 AM
RQCustoms's Avatar
User is: RQCustoms is offline
this is WAAYYY beyond retarded!! please tell us you're just ****ing with us! my dog left a pile of shit out front that looks nicer than that.
post #14 of 154 Old 09-06-2011, 12:06 PM
PAGING DR. FAGGOT!
doored454's Avatar
User is: doored454 is offline
Send a message via AIM to doored454
Um. Could have at least moved the bed down 4-5" to meet the body lines. That grille/headlights makes me want to punch babies.
SEAN
90 454SS - Bagged and layin door on 22's
93 Chevy 3500 dually - bagged on purple 19s
02 Chevy 3500 dually - edge programmer, stacks...needs to get laid the f*ck out
95 Honda Civic - slammed slow daily
04 Subaru WRX - 3" turbo back exhaust, carbon fiber goodies, slammed on coilovers, stanced on candy teal Borbet type A's
post #15 of 154 Old 09-06-2011, 01:18 PM
This is doo doo baby!
wildman ss's Avatar
pics of other vehicles?
Classy Chassy
wildman ss is offline
post #16 of 154 Old 09-06-2011, 01:23 PM
Need to DO WORK son
Innis's Avatar
hahaha epic!!!
that grille on a normal day is hideous...but when you cut it up and make it look even worse i dont know what to say
Innis is offline
post #17 of 154 Old 09-06-2011, 01:30 PM
Heavy Metal Junkie
rusty10690's Avatar
User is: rusty10690 is offline
anybody else notice the punisher logo painted on his trash dumpster?
and i would defintly be filing complaints if you were my neigbor, spray painting shit outside like that, if seen 1 spec of overspray on my shit, id call the fu#$ing cops
PSN Name= Gopple
post #18 of 154 Old 09-06-2011, 01:38 PM
needs a cheeseburger
tohoopty's Avatar
User is: tohoopty is offline
it looked better before.now its a driving abortion
tohoopty is offline
post #19 of 154 Old 09-06-2011, 02:02 PM
almost ready to v8 swap
631deadhook's Avatar
User is: 631deadhook is offline
speechless and no thats not a good thing lol
post #20 of 154 Old 09-06-2011, 02:24 PM
RQCustoms's Avatar
this.
post #21 of 154 Old 09-06-2011, 04:08 PM
Wondersmith
StirFrey's Avatar
User is: StirFrey is offline
i forgot how brutal some of you are lol
It isn't a death wish. It's about living.
-95 Noma (see thread >) - 2.2 5-speed https://www.s10forum.com/forum/f30/pr...sinoma-433674/
StirFrey is offline
post #22 of 154 Old 09-06-2011, 04:24 PM
1st Gen Crew Cab Cult
layNrkr's Avatar
User is: layNrkr is offline
Send a message via Yahoo to layNrkr
huge pile of shit..
2000 Acura TL Hydroholics 2/6
73 Datsun 620
92 S10 crew cab
layNrkr is offline
post #23 of 154 Old 09-06-2011, 05:09 PM
User is: ross_freier is offline
the rattle can paintjob didnt turn out half ass bad, i give u points for something different, i'd never drive it, but its different, headlights are ugly as **** and the box is just buggin me, but its ur beater so giver
Projects:
00 Sonoma project, project is dead scrapping the truck
99 Jimmy, Can't get rid of my jimmy yet.
92 gmc suburban daily finaly arrived, small repairs to daily soon
Team Asshole pushing the limits of sound
post #24 of 154 Old 09-06-2011, 05:33 PM
RQCustoms's Avatar
it turned out FULL ass bad, whatever that means.
post #25 of 154 Old 09-06-2011, 05:41 PM
Ridin' on Twankies
colbye32's Avatar
User is: colbye32 is offline
Send a message via AIM to colbye32 Send a message via Yahoo to colbye32
ill give you 50 bucks for it.
Ill drive from georgia right now.
00' Noma, bagged, 20's, heat/ac, multicolor - Zq3-Specialty Road Head Package
colbye32 is offline
post #26 of 154 Old 09-06-2011, 05:47 PM
User is: Hokie_PhD is offline
I agree and I always have something to say.
As for the Ranger bed.... what was wrong with that truck? other than the ugly green color it looked pretty decent. I know this is the S10 forum but it seems criminal to chop up a good truck unless the other side was damaged.
My project with my 16 year old son:
https://www.s10forum.com/forum/f30/pr...er-son-476654/
post #27 of 154 Old 09-06-2011, 06:01 PM
littledevil4802's Avatar
User is: littledevil4802 is offline
Send a message via AIM to littledevil4802
I would rock it as a farm truck or a woods beater. I kinda like the headlights the more i look at them
92 reg. cab-lowered 5/4-sold
95 std cab- bagged about to be bodied
www.airedup.com
post #28 of 154 Old 09-06-2011, 06:40 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
i think it looks awesome! i really like what you did with the crazy silver spray paint and bondo! keep up the great work bro.
TelAmeriCorp
post #29 of 154 Old 09-06-2011, 06:52 PM
DOOR'D FOR HER PLEASURE!
Slappy McNasty's Avatar
User is: Slappy McNasty is offline
well, at least the economy is benefiting from his spray paint buying. have fun with it man, just ...................... i dunno man, just have fun with it
post #30 of 154 Old 09-06-2011, 07:33 PM
YAIMLOW's Avatar
User is: YAIMLOW is offline
bahahahhahaa new sig! and ya... agreed... heaven forbid im in a nursery and see this set up again, i will go on a baby punching tangent...
[Project] - SPRKSHO - https://www.s10forum.com/forum/f30/pr...7/#post7337405
1985 S10, Shaved Everything, Custom 4 Link, 3.5" BD Layin' Rocker On 20's, Built 350
1988 S10, Shaved Everything, Front Bagged, much more to come
Quote: Originally Posted by ridensolow
anybody can thro big rims under a lift, cut and tuck em THEN your custom
YAIMLOW is offline
post #31 of 154 Old 09-06-2011, 07:57 PM
Electrical Mod
deathphoenix99's Avatar
It'd look better if the bed was down to match the body lines, but otherwise, it's not that bad. I've definitely seen worse and I'd rock it.
post #32 of 154 Old 09-06-2011, 08:03 PM
9" strait pipes...
hi_im_sean's Avatar
User is: hi_im_sean is offline
the worst part is that he has more replies in one day than most build threads get in a month
post #33 of 154 Old 09-06-2011, 08:08 PM
96blazer's Avatar
User is: 96blazer is offline
And the work is about the same quality of about 1/4 of the build threads.
96blazer is offline
post #34 of 154 Old 09-06-2011, 08:09 PM
no bags here
tretiak's Avatar
User is: tretiak is offline
wtf?
2001 Blazer Xtreme
project: clean and simple < getting bagged and ls swapped
exceeding limits nepa chapter president
Originally Posted by MotorNut123 View Post
I actually should've used concrete on my fender. That way i could decorate it like pottery
you can actually really weld aluminum to steel lol friction welding
tretiak is offline
post #35 of 154 Old 09-06-2011, 08:25 PM
Check your ground
556mm's Avatar
User is: 556mm is offline
Sure you would.
556mm is offline
post #36 of 154 Old 09-06-2011, 08:31 PM
I scrape i rub i lean
10below's Avatar
User is: 10below is offline
MY name is randy but you have to call me nighthawk.
10below is offline
post #37 of 154 Old 09-06-2011, 09:40 PM
selfmade__brandon
slownoma63's Avatar
User is: slownoma63 is offline
sweet baby jesus. That thing got hit with a bag of wtf. this is just assenine (sp?)
@selfmade_fab @selfmade__brandon
post #38 of 154 Old 09-06-2011, 10:26 PM
User is: Seamus is offline
Honestly, it looked pretty BA before.......
Also, I should point out that i knew this was gonna be a cluster f*** when you start it with, "My wife picked out...."
Seamus is offline
post #39 of 154 Old 09-06-2011, 10:38 PM
Need to DO WORK son
Innis's Avatar
Ok, I saw this thread again and something came to mind, this is kind of an old school s10forum memory, but does anyone remember from a few years back the kid name "icedragon" or whatever? This thread is epic just like all of his hahahaha
Innis is offline
post #40 of 154 Old 09-06-2011, 11:03 PM
Chopper! Sic balls!
Mostizzle's Avatar
ah yes, icedragon. that dude was chock full 0' fail. lol
https://www.s10forum.com/forum/member.php?u=60107
search his posts/threads for mass lolz.
TelAmeriCorp
post #41 of 154 Old 09-06-2011, 11:03 PM
mitch55's Avatar
User is: mitch55 is offline
1 cut the box off have it as a flat bed
2 put the box back on upside down
3 take the ford truck box to the scrap metal
4 leave the truck there and take the money and buy a new video game
mitch55 is offline
post #42 of 154 Old 09-06-2011, 11:07 PM
Wondersmith
StirFrey's Avatar
the bed and the 2 piece grille are what bug me the most.... the bed needs to be lowered. its interesting tho..... as long as you are having fun with it its all good, just make damn sure if your ever in my neck of the woods you dont start spray painting anything near my truck....
StirFrey is offline
post #43 of 154 Old 09-06-2011, 11:11 PM
Gun Totin Redneck
944v8indfw's Avatar
User is: 944v8indfw is offline
aaahhhhh yeah
post #44 of 154 Old 09-06-2011, 11:15 PM
Passwordistaco
Back_N_Black's Avatar
User is: Back_N_Black is offline
wowwwww cool i guess. idk why you would do it but who am i to ask lol
[/SIGPIC]Michael _ @Passwordistaco511_
<a href=https://www.s10forum.com/forum/f30/project-nightmare-dressed-like-a-daydream-688786/ target=_blank>www.s10forum.com/forum/f30/project-nightmare-dressed-like-a-daydream-688786/</a>
https://www.s10forum.com/forum/f30/pr...ydream-688786/
post #45 of 154 Old 09-06-2011, 11:59 PM
black92 4.3's Avatar
User is: black92 4.3 is offline
y u no fix it right
1992 4.3 ex cab s10 SOLD.
now 1996 ex cab 4.3. cai, magnaflow with cutout, 33mm front swaybar, hellwig rear sway bar, 2/3 drop , GM roll pan, camaro RS rims, center console shifter, blazer front
1998 trans am bolt ons with cam SOLD
1995 camaro- full exhaust, intake, gears, spray.
post #46 of 154 Old 09-07-2011, 12:23 AM Thread Starter
DOT COM
Hamstar's Avatar
The truck is every bit a winter beater.
It’s main function is to be-bop around in the winter snow, load down with materials from Homedepot, help friends move (the “friend with truck” scenario), and to just have fun with.
This truck actually is my pride and joy (more joy than anything else)… I wanted a cheap vehicle that goes from A to B, and something I could tinker with, that’s what I have.
I can’t afford to go out and spend a ton of money in materials, I don’t own a garage, and I am very grateful for what I do have.
I make no apologies for it.
For those of you who have actual shops and/or garages where you can work on your vehicles, good for you! One day I hope to be in your ranks (I really do).
For the rest of us who live paycheck to paycheck and would still like to tinker with the rust buckets we love…
Today I started with more taping... I know it's a lot of effort for a paint job that is going to fall apart before the first snow... but it's all about the fun.
Now here's where it gets a bit weird.
I repainted it silver, but then I added in shading... then the part that wont make sense at this point will be the color shade.
The lines of color in the silver and black are very deliberate.
As some have already figured out, the truck was never intended to be silver
So to let this cure overnight before the next step... here's where we stand
Here's a better look at the shading
And the COG line
I hope that the weather holds up this week, I’m looking forward to shooting the actual color to it tomorrow if at all possible.
Hamstar is offline
post #47 of 154 Old 09-07-2011, 12:52 AM
Registered Asshole
sdime99's Avatar
User is: sdime99 is offline
Holy pile of sh!t Batman!!!!........I'm just curious do you still have the NON pressure treated wood under the bed?
99 bagged s10 extreme
02 stock blazer extreme
sdime99 is offline
post #48 of 154 Old 09-07-2011, 02:43 AM
Super Saiyan User
Dragonball98312's Avatar
User is: Dragonball98312 is offline
Right on guy, do what you want. I think its ugly as shit but its 100% your own. I totally respect that. Ive always liked ranger step side beds on first gens. I hope to do that someday as well
89 S10 2.5 5 speed 2wd
post #49 of 154 Old 09-07-2011, 11:18 AM
Gun Totin Redneck
944v8indfw's Avatar
I love low buck beater builds if this is in fact what it was ment to be.
post #50 of 154 Old 09-07-2011, 11:43 AM
Need to DO WORK son
Innis's Avatar
Wow thank god someone knows!!
Oh and now that i know for sure it is a 100% beater than thats fine, i will admit, i would never think someone could mask off and make a paint job with that kind of fading in a backyard with rattle cans, so good on that
just lower the bed!!
Innis is offline
