Project: little engine that could - S-10 Forum
 9Likes
post #1 of 61 Old 06-23-2019, 07:59 PM Thread Starter
New Member
Shane Cary's Avatar
User is: Shane Cary is offline
I have a 2000 Sonoma sls extended cab. 2.2 with 5 speed. Was bone stock and had 85k miles when I bought it from a shop with blown headgasket. Price I paid was for it fixed. 1 year and 2 headgaskets later and it still has a cylinder 1 misfire. Dealer says 0 compression on #1 cylinder and single digit compression on #3. Still got mid 20's mpg with my Harley in the back on my move from Arizona to Pennsylvania. Got fed up trying to fix this engine so I bought another 2.2 to replace it.
Originally i was going to do an ls3/6 speed swap from an SS Camaro. I wanted the truck to sit low but I'm not bagging it. I just wanted a super fast yet street friendly Sonoma. Now I'm doing a built 2.2 turbo and going to crank the boost to achieve my goals. I'm shooting for 400-500whp or 11 seconds in the 1/4. Just depends on what the wallet allows. To help achieve that second part I plan to put the truck on a serious diet yet still retain all safety features in the cab. No roll cages, I'm keeping airbags and steel doors. I am going to replace front clip with a fiberglass piece and the bed sides will be replaced with fiberglass as well. If I ever go full drag race with the truck I may go fiberglass cab and doors but it's no longer street driven then.
Since I'm not home much and the safety directors friend owns a junkyard I decided to get another 2.2 to drop in for now. $350 for the 2.2 with all accessories and they pulled it and brought it to my house. Engine ran when pulled and had 99k on it.
Needs cleaning and a new valve cover gasket.
Since buying the truck I had the headgasket done again and 4 new tires put on. Then the radiator started leaking.
Got that replaced and then the slave cylinder went out on the clutch. Its internal so the transmission had to come out. I wasn't home when it happened so I had my son put it in the shop. 1500 later I had all new clutch components. New slave cylinder, pressure plate, clutch, throw out bearing and clutch master cylinder. I didnt want any surprises for another 50 or 100 thousand miles.
After that was sorted I had the windows tinted and my son installed an old system I had laying around. I had a set of 10" kicker comp VR's and my son had a set of components with crossover and tweeters along with a 300 watt kicker amp. I then replaced the 300 watt amp with a 1200.1 kicker amp. Just last week I installed a set of 4x10 Memphis speakers in the extended cab and bought a 4x70 watt amp to drive all the components and 4x10s. System sounds completely balanced now.
Last week we also painted and installed a steel roll pan to replace the bent factory bumper. I had a 4/6 drop and bell tech shocks for all 4 corners. We installed shocks and all 4 springs. We didnt install the rest because c-notch wasn't in yet. I may replace front arms with UMI upper and lower tubular arms. Ball joints are showing age and I dont want to replace ball joints twice if I go with those tubular arms. Saves 8 pounds I believe.
My steering is worn out and pump is leaking. I'm considering a manual rack and pinion swap at the same time. That saves 35 pounds from the front and replaces the rag joints with a cv joint.
I'm bouncing around between the outside and engine at the same time. Engine is good for now but the outside of the truck looks a little plain so I'm dressing it up a bit. Shaving tailgate handle and installing a billet grill when I get home. Pulling the bed to install c-notch and paint frame with por15 to prevent rust. While bed is off I'm taking measurements to fab a carrier bearing crossover that moves bearing up 1 inch. Gives me a little more ground clearance when I finish lowering it.
After lowering but before the roll pan:
superj likes this.
post #2 of 61 Old 06-23-2019, 08:11 PM Thread Starter
New Member
Shane Cary's Avatar
This build will take a long time since I have work on my Harley I want to do and a trip to Italy in October. That's why I'm doing the small stuff now. Using my bonuses to build the Sonoma.
Immediate to do list includes rest of 4/6 drop including carrier bearing crossover bar, tubular a arms, rack and pinion swap, 18x8 front rims with 235/35 tires and 18x9.5 with 285/35 tires, tailgate handle relocate and smooth tailgate, billet front grill. Replace mirrors with smaller ones painted to match truck. Then I'm going to dive into the other 2.2 and disassemble it and send to machine shop to have everything cleaned and inspected. Head will be replaced with patriot head with 2mm oversize valves, springs rated to 7500 rpm and titanium retainers. Suppose to flow 220 cfm when they are done. Since I'm trying to get as much power as possible from the 2.2 I may opt for the stroker kit from ccw. I hope to have the engine completed by Christmas and then install it along with the turbo kit and MegaSquirt3 over the new year. I'm taking December and January off if possible to do this.
superj likes this.
post #3 of 61 Old 06-23-2019, 10:12 PM
New Member
lilbowtie's Avatar
User is: lilbowtie is offline
Re: Project: little engine that could
Be watching your progress - have fun with it ! Did a similar build.
post #4 of 61 Old 06-23-2019, 11:20 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
I suggest doing a search for 2.2 turbo on the forum.
There is (or was) a forum member who did a super custom turbo build (and I mean immaculate) on his 2nd gen 2.2. I followed the build and all of his posts.
The sad part: He never could get it dialed in. And he tried very hard - to say the least.
It would not run correctly no matter what he did (to expected performance).
If you are really familiar with turbos, set up and MOST IMPORTANTLY - tuning, then you may have good success.
I hang at a tuner shop (when I'm back in Baton Rouge) and have watched many many many guys set up turbos on Hondas with readily available kits (or most of a kit)
and they still have tons of work getting them to run correctly.
Not trying to piss on your parade, but it's not just "Oh, I think I'll bolt on a turbo and go fast".
Another consideration, the 2.2 isn't a particularly stout engine. They will sign off if you force feed them too much.
Think you had trouble with head gaskets?
Wait until you run 10 - 12 pounds of boost.
goes2fast likes this.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #5 of 61 Old 06-23-2019, 11:28 PM
Boozebag
Mad Max's Avatar
https://www.s10forum.com/forum/f105/...14/index2.html
S10 addiction:
Mad Max is offline
post #6 of 61 Old 06-24-2019, 04:43 AM Thread Starter
New Member
Shane Cary's Avatar
I turbo a stock 2.0 dodge and got 300 wheel hp. I used ms2 as a standalone computer back before tuner studio. We used megatune back then and had to set EVERY value in the VE. If I can get pics off of photobucket and back on this phone I will show what I did with that car. 300whp on a 2300 pound car made for a rocket on wheels.
I have experienced the troubles of turbos on engines not built for them. The weak point in the 2.0 dodges is actually the rod bolts. Using arpu rod bolts for a ls engine on the stock rods is enough to safely run 350 ish hp before the rods and pistons become the problem.
I've been doing research for a while now on the 2.2 engine. I admit I havent figured everything out but I'm still reseaching
superj likes this.
post #7 of 61 Old 06-24-2019, 06:44 AM
Boozebag
Mad Max's Avatar
Ok... Again, being on this forum for a short time I have seen many posts about turbos and how individuals are going to leap tall buildings in a single bound...
Not tying to say you don't have the background, but after a while - if you hang around here long enough...
You'ii see what I mean.
I wish you good luck if you pull this off.
Many have tried, some win
meh, you know the rest.
S10 addiction:
Mad Max is offline
post #8 of 61 Old 06-24-2019, 08:00 AM
Been there Done it
oldeerslayer's Avatar
Not to put words into his mouth , but I think what Mad Max is trying tell you is that for enough money and usually after enough time anything is possible, but it's rarely an easy route. It's also possible the only part of the original truck left will be the radiator cap. Unless you got a new one of those, too.
What I'd suggest is that if the 2.2 S10 is that far from what you really want, sell it and buy a truck that is what you want. It'll be reliable, probably less money in the long run, and save you a lot of grief.
You can stick a cattle prod up a pigs butt and it'll run really fast and then drop over dead. If you want a race horse, buy a race horse. But then don't try hauling a motorcyle on it. For that get a wagon and a draft horse.
post #9 of 61 Old 06-24-2019, 08:43 AM Thread Starter
New Member
Shane Cary's Avatar
I get what you both are saying. That is partially why I'm doing cosmetic things while building the engine. I found out a long time ago not to jump in head first.
Since I have 2 engines I'm slowly building up one while doing little things to the truck itself. That way I dont get discouraged. I'm also away from home for 2 weeks at a time. Every time I get home I have little tasks to complete so I always achieve some sense of accomplishment
superj likes this.
post #10 of 61 Old 06-25-2019, 01:28 AM
Boozebag
Mad Max's Avatar
Along the lines of small engines...
I have built a few Pontiac 2.5s - the Iron Duke - just for a laugh.
Installed Chevy 350 pistons (direct fit) balanced, big cam, large intake valves with porting, Mallory distributor wit an MSD box, headers, 390 4 barrel, custom fitted 6" Chevy I beam rods,
BUT - the one big difference - the Iron Duke is based on many GM parts that fit other engines.
The Tutu is not based on V8 parts, it's all metric Voodoo. So, in order to find different pistons that will withstand pressure... N/A - or custom made.
Chevy forged small block slugs go right into a Duke block with a Shite ton of different combinations of compression/stroke/bore. The big end of the 2.5 rods is 2.0 and... so is the early 327 and 283. The SBC rods are wider at the big end, so they have to be shaved, but that's easy.
The point I'm trying to make, while it is a ton of fun to make something puny go fast, the aftermarket support should be there, or you will empty your wallet pronto.
I have seen aftermarket turbo manifolds for the 2.2 on ebay, and "DIY" turbo pipe kits.
That's the easy part - sort of. Fabbing the correct fitting tubes and intercooler is the next trick.
The last an ultra important... tuning.
You HAVE to have a dyno (some will say a street tune is ok) but I completely disagree. The dyno will give you the most complete readings through the power band to re tune your fuel and ignition maps.
Ok, I'm sorry for the dissertation, but these are just a few of the considerations you will encounter.
S10 addiction:
Mad Max is offline
post #11 of 61 Old 06-25-2019, 08:47 AM Thread Starter
New Member
Shane Cary's Avatar
You are absolutely correct. I use megasquirt which is a standalone computer to control everything including boost when I use the cyclone electronic boost solenoid. I street tune to get it running and then to a dyno. In Arizona i used Amp performance which builds high hp Fords but they know their stuff when it comes to dyno tuning.
I should stress this is a street truck so the power and track number is just a secondary goal. Primary goal is a clean looking yet fast 2.2. I may never keep up with zl1 camaros or z06 corvettes but if if can destroy a Honda or 2 then I'm ok with that
superj likes this.
post #12 of 61 Old 06-25-2019, 11:52 AM Thread Starter
New Member
Shane Cary's Avatar
I should be home tomorrow or Thursday. First thing I need to do is installed the tailgate handle relocate kit so my safety director can smooth and primer the tailgate. I may have him paint it but the bed needs a few dents removed from where the bumper was pushed into it and the shop that did the head gasket managed to put a scratch down the entire passenger side of the bed when it rubbed the lift. So painting the tailgate may wait for a bit.
The bed needs to come off so I can paint the frame with por15 after I install the c-notch. I'm holding off on the carrier bearing crossmember since I'm not installing the rest of the lowering kit this weekend. I'm ordering the tubular control arms from umi Friday and will be gone again before they arrive.
Next time I'm home I will install the arms and rest of the lowering kit along with the carrier bearing crossmember. That's the plan anyway for the 2 days I'm home
post #13 of 61 Old 06-25-2019, 09:41 PM
time to get cereal
manbearpig's Avatar
The center support bearing (carrier bearing is in the diff) crossmember is fun to remove. Hope you have an oxyacetylene torch. I'm guessing you have the raised one? I have one too, but I hardly ever hit with the stock one even since I've lowered it more.
post #14 of 61 Old 06-25-2019, 10:43 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
They're referred to as carrier bearings as well.
Don't be discouraged. There's been a couple guys on here in my time with boosted 2.2's that made pretty good reliable power.
manbearpig likes this.
post #15 of 61 Old 06-25-2019, 10:49 PM Thread Starter
New Member
Shane Cary's Avatar
I do have a torch. I know I may not have to move the center support up an inch but I'm preparing myself in case.
Once the tubular arms arrive I will install the drop spindles and rear blocks to finish the lowering kit. I will know then what I need to do with the center support crossover
post #16 of 61 Old 06-25-2019, 10:56 PM
time to get cereal
manbearpig's Avatar
I would just buy or make a spacer. Way easier than moving the crossmember.
https://jagsthatrun.com/collections/...ylinder-and-v8
post #17 of 61 Old 06-25-2019, 10:59 PM Thread Starter
New Member
Shane Cary's Avatar
I know on my tractor trailer they are called carrier bearings. Figured that was the appropriate term.
I'm not discouraged easily. I know it would be faster and maybe easier to just swap an ls engine into it but I have a spare 2.2 and everyone swaps a v8 into these trucks. I just wanted to be different and at the same time see what the 2.2 is capable of. The rotating assembly I'm looking at has a power rating of either 600 hp or 900 hp depending on which rods I get. Not that I will reach that point but who knows. I know what 400 hp in a 2300 pound front wheel drive car is capable of. If I can get the same results with this truck I will be happy for a while
superj likes this.
post #18 of 61 Old 06-25-2019, 11:08 PM Thread Starter
New Member
Shane Cary's Avatar
I saw that kit. From what I recall the ends of the crossmember drop an inch or so below the frame. Not that I need the ground clearance but seeing the bar drop below the frame annoys me. It's my OCD
post #19 of 61 Old 06-25-2019, 11:08 PM
Chopper! Sic balls!
Mostizzle's Avatar
I have the JTR spacer on my truck. I have an early 2nd gen though so it doesn't have the xmember that hangs down.
post #20 of 61 Old 06-25-2019, 11:13 PM
time to get cereal
manbearpig's Avatar
Oh, I thought you had a custom crossmember. I bought one a long time ago that's just a piece of square tubing with plates welded to the ends.
https://www.airassisted.ca/s10-carri...ossmember.html
post #21 of 61 Old 06-25-2019, 11:24 PM
Boozebag
Mad Max's Avatar
I just found this when I went back to photobucket.
I was always interested in making small stuff go fast.
Here's an example...
Built it in 2012 and it's still sitting on an engine stand.
Should go pretty good in a first gen short box...
S10 addiction:
Mad Max is offline
post #22 of 61 Old 06-25-2019, 11:39 PM Thread Starter
New Member
Shane Cary's Avatar
I was going to build the same thing they sell. $110 isnt a bad price given the fact that it saves me time fabricating it
post #23 of 61 Old 06-25-2019, 11:43 PM Thread Starter
New Member
Shane Cary's Avatar
I have a machinist friend who makes box intakes for Dodge neons. He custom made a Weber carb setup for the 2.0 and 2.4 dodge engines. 4 individual carbs for a 4 cylinder with polished bells on top. Looks like something from the 60's. I will try to find a pic.
post #24 of 61 Old 06-26-2019, 09:11 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Put a timing chain,front seal,rear main,and oil pan gasket on that 2.2 engine before you install it. Ive done a lot of 2.2 S10 engine replacements...every used 2.2 Iíve opened up needed at the very least a tensioner.
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #25 of 61 Old 06-27-2019, 03:40 AM Thread Starter
New Member
Shane Cary's Avatar
Originally Posted by BravadaX View Post
Put a timing chain,front seal,rear main,and oil pan gasket on that 2.2 engine before you install it. Ive done a lot of 2.2 S10 engine replacements...every used 2.2 I’ve opened up needed at the very least a tensioner.
I didnt even think about the timing chain. I was going to replace the gaskets and seal. Except head gasket.
I'm not sure how long I will be home. At least 2 days. So I will get the seals but engine wont be going in this time I'm home. Next time I'm home I will take a week off to get some work done on the truck. I'm just doing little things this time.
post #26 of 61 Old 06-27-2019, 07:26 PM
time to get cereal
manbearpig's Avatar
You'll definitely want a better head gasket for the turbo engine, especially if you're pushing it to 400+ HP. ARP studs and Cometic or similar head gasket would be a must.
post #27 of 61 Old 06-27-2019, 08:54 PM
Old Fart
goes2fast's Avatar
User is: goes2fast is offline
Have you thought about swapping in a JDM SR20-DET? A much stronger engine that is designed to be turbocharged so would be much more reliable for what your goals are. Another option if you want to keep it GM would be the turbo engine form a Solstice which would give you a nice 6-speed manual as well. I can understand wanting to smoke the Honduh boys, I haven't been able to find any willing to take on my VW though. I went to the track last night to play a little, a Steeda Mustang got me by .14 and the next run I was up against a C5 Corvette and got him by over a second. Lines in staging were long and it was almost my bed time so I went home after that. Killing V8s with a 2.0 4 banger is fun.
Too Much Horsepower is ALMOST ENOUGH!
"I have a car-sickness. I need to be checked into the HENRY Ford Clinic." -Tim "The Tool Man" Taylor
post #28 of 61 Old 06-27-2019, 10:44 PM Thread Starter
New Member
Shane Cary's Avatar
<a href="https://postimg.cc/sMLXFW5w" target="_blank"><img src="https://i.postimg.cc/sMLXFW5w/20190627-075556.jpg" alt="20190627-075556"/></a>
Hope I chose the right link this time. That should be a picture of the roll pan installed
post #29 of 61 Old 06-27-2019, 10:47 PM
time to get cereal
manbearpig's Avatar
HTML won't work. What is the point of hiding your license plate? I've always wondered why people do this.
post #30 of 61 Old 06-27-2019, 10:57 PM Thread Starter
New Member
Shane Cary's Avatar
Ok I got home later than planned and had to hit up a couple of junk yards. I want an envoy front bumper. I found a white one but build date is 03/01 or maybe it was 03/02.
Anyway I need to get the bed off tomorrow so I can cut the bump stop mounts off and coat the frame in por15 or something similar. Today i had some spare time after the junk yard so I installed the billet grill
Before:
<a href="https://postimg.cc/S2FxRpT9" target="_blank"><img src="https://i.postimg.cc/S2FxRpT9/20190627-165527.jpg" alt="20190627-165527"/></a>
After:
<a href="https://postimg.cc/7JXHKJx1" target="_blank"><img src="https://i.postimg.cc/7JXHKJx1/20190627-200219.jpg" alt="20190627-200219"/></a>
<a href="https://postimg.cc/SJqDBT4N" target="_blank"><img src="https://i.postimg.cc/SJqDBT4N/20190627-200232.jpg" alt="20190627-200232"/></a>
The grill was meant to be mounted from the back side. After spending the time to set it up like that I ended up not liking it. I fabbed some new brackets and mounted it further out.
post #31 of 61 Old 06-27-2019, 11:02 PM Thread Starter
New Member
Shane Cary's Avatar
Honestly I dont know who is capable of seeing what I post online. I dont want someone being able to locate my truck based on just my tag
post #32 of 61 Old 06-27-2019, 11:11 PM Thread Starter
New Member
Shane Cary's Avatar
Ok so here is the before:
After:
post #33 of 61 Old 06-27-2019, 11:15 PM
time to get cereal
manbearpig's Avatar
Looks good.
post #34 of 61 Old 06-27-2019, 11:18 PM
B4U Task Force
Rhotpursuit's Avatar
Nope...Hot Link For Forum is what you want.
Apple Red 96 SS
post #35 of 61 Old 06-27-2019, 11:22 PM Thread Starter
New Member
Shane Cary's Avatar
Thank you.
My boss is doing my tailgate handle relocate tomorrow and will have it primed Saturday. I'm holding off on painting it for now. I need to get a few dents removed from where the bumper was pushed into the bed. Plan is to have entire bed painted all at once
post #36 of 61 Old 06-28-2019, 01:25 PM Thread Starter
New Member
Shane Cary's Avatar
Is it the 01 and older envoy bumper that fits the Sonoma?
I cant find one anywhere and I'm not liking the aftermarket bumpers available
post #37 of 61 Old 06-28-2019, 03:02 PM
New Member
Harley's Avatar
User is: Harley is offline
https://en.m.wikipedia.org/wiki/GMC_Envoy
1998-00 Envoy is the S10 version.
I have one in Portland, OR. It's not white.
Harley is offline
post #38 of 61 Old 06-28-2019, 04:17 PM
time to get cereal
manbearpig's Avatar
There's a fully painted bumper cover that came on 98+ Sonomas as well, and the Bravada cover will fit also.
post #39 of 61 Old 06-28-2019, 08:36 PM Thread Starter
New Member
Shane Cary's Avatar
I have a Sonoma and oddly enough there is 4 or 5 bravada in 1 junkyard here by me. They have 2 white ones. I just want to get the envoy to clean up the front a little more. The line between the factory white part and factory grey part would still be there even if I paint my original bumper cover. I'm not in a huge hurry for the bumper cover so I will check the yards in Phoenix when I get back there again.
post #40 of 61 Old 06-28-2019, 08:37 PM Thread Starter
New Member
Shane Cary's Avatar
Pretty sure the cost to ship to Pennsylvania would make it impractical to ship. I appreciate the heads up though
post #41 of 61 Old 06-28-2019, 08:41 PM Thread Starter
New Member
Shane Cary's Avatar
I failed reading your post fully. I did find a fully painted Sonoma cover locally and may go that route. They want 50 for the cover and support even though I dont need the support. It's been sitting for a while and has that nasty green moss looking stuff on it. Needs painting for sure. I used a wet rag and tried to scrub it off before I pulled it. That stuff needs to be sanded off I think. Again I'm not a body guy so i have no clue. I pay my boss to do the paint and body work
post #42 of 61 Old 06-28-2019, 08:44 PM
time to get cereal
manbearpig's Avatar
The fully painted one does not have a line in it.
post #43 of 61 Old 06-28-2019, 08:49 PM Thread Starter
New Member
Shane Cary's Avatar
Correct. I noticed that when I found the white one yesterday. I got so excited until I saw the green stuff. I may just go with the all painted one. I just wish they didnt have the flat spot for the plate. I know I'm being picky but I hate too many lines. It's part of the reason I'm getting the roll pan welded in. Hiding the seams
post #44 of 61 Old 06-28-2019, 08:55 PM
time to get cereal
manbearpig's Avatar
Perfect place to cut out for your intercooler.
post #45 of 61 Old 06-28-2019, 08:56 PM Thread Starter
New Member
Shane Cary's Avatar
True. I like that idea
post #46 of 61 Old 06-29-2019, 07:57 PM Thread Starter
New Member
Shane Cary's Avatar
I got the tailgate handle relocate installed and my boss welded the plate and started the bodywork on the tailgate.
I didnt get nearly as much done as I wanted the last 2 days. Maybe I can get the rest done next time I'm home.
post #47 of 61 Old 07-01-2019, 02:00 PM Thread Starter
New Member
Shane Cary's Avatar
While running through the local junkyard last week I found a few bravadas with good leather seats that were power. I know my truck doesn't have the harness for power seats. Seems Chevy didnt make 1 body harness to cover all models/options. So without being able to look for another 2 weeks I'm guessing I need the power seats and body harness but it's never that simple.
Anyone know what is involved in retrofitting power seats, windows and locks into these trucks?
post #48 of 61 Old 07-01-2019, 06:23 PM
Chopper! Sic balls!
Mostizzle's Avatar
It's a 2 wire hook up unless they're power seats with memory. You can tap into the hot wire for the aux power or cig lighter. If you do a forum search for "adding power seats" you'll find a bunch of info.
post #49 of 61 Old 07-01-2019, 06:45 PM
B4U Task Force
Instructions are in my Bravada seat thread...
Apple Red 96 SS
post #50 of 61 Old 07-06-2019, 09:30 PM Thread Starter
New Member
Shane Cary's Avatar
My boss/friend sent me a picture of my tailgate all painted. According to FedEx my mirrors will be in on Tuesday and he will paint those white also. Went with the m3 style mirrors. I'm tired of looking at dumbo ears hanging on my doors.
You may post new threads
You may post replies
