Project: Ablues10's Resurrection - S-10 Forum
post #1 of 80 Old 07-31-2008, 02:09 AM Thread Starter
Working on aircraft
ablues10's Avatar
User is: ablues10 is offline
My overall goal with this is to rebuild the engine, and get it ready to accept the hydrogen fuel cell thing that I built, clean up all the grease and oil, powdercoat some stuff, redo the wiring, and tub the drivers side. I will also be doing some gasket matching, porting, and polishing.
Here is what I am working with:
Replacing the timing chain and gears:
Something is wrong here lol:
Its nasty under here:
The reason for my engine being torn down. #2 is off a little, in turn its causing a misfire on all cylinders.
Gasket pieces:
pics more pics ^ project pics
ablues10 is offline
post #2 of 80 Old 07-31-2008, 02:20 AM Thread Starter
Working on aircraft
ablues10's Avatar
Re: Project: Clean, cut, rebuild, and save some damn cash.
On to the head:
This is how wide everything needs to be:
This before any mods:
The gasket:
Before pics:
Its going bye bye!:
During and after pics:
Valve cover (Powdercoated with metal flake):
First exhaust port:
Its closer than that now that its polished:
Cleaned the valves (before and after):
Finshed and needed to be tested then powdercoated (chrome):
This is how my truck looks currently:
ablues10 is offline
post #3 of 80 Old 07-31-2008, 02:39 AM
Sweet lemonade.
MurderedS10's Avatar
User is: MurderedS10 is offline
Send a message via AIM to MurderedS10
i say may as well take the fenderwells out while your in there. looks pretty good if you ask me.
post #4 of 80 Old 08-02-2008, 02:35 AM Thread Starter
Working on aircraft
ablues10's Avatar
Did some powercoating and painting. I got the head back from the machine shop, I had hem glass bead it, then I painted it.
ablues10 is offline
post #5 of 80 Old 08-07-2008, 01:16 AM Thread Starter
Working on aircraft
ablues10's Avatar
I finished pulling the motor today. I went to unbolt the exhaust and found this:
Anyways. I started disassembly.
Im starting inital combat with some foaming degreaser.
Nasty pistons:
Good looking clutch! This has been in since Jan. :
ablues10 is offline
post #6 of 80 Old 08-07-2008, 03:45 AM
2lowan2slow's Avatar
User is: 2lowan2slow is offline
holy [email protected]#$ cuz i need to get over there...sorry i couldent make it today
post #7 of 80 Old 08-26-2008, 04:25 AM
406sbc th400
slowrider1983's Avatar
User is: slowrider1983 is offline
Send a message via Yahoo to slowrider1983
were did you get that clutch? what year is your truck
post #8 of 80 Old 10-14-2008, 12:02 AM Thread Starter
Working on aircraft
ablues10's Avatar
Holy shit! I have not updated this i forever. Progress pics:
ablues10 is offline
post #9 of 80 Old 10-14-2008, 12:04 AM Thread Starter
Working on aircraft
ablues10's Avatar
I had it build by a race shop here in Springfield. It costs 180.00 for just the disc and it holds up to 700HP My truck is a 98
ablues10 is offline
post #10 of 80 Old 10-14-2008, 04:58 PM
V8 with bags
V8Blaze's Avatar
User is: V8Blaze is offline
Send a message via AIM to V8Blaze Send a message via Yahoo to V8Blaze
those rims/tires look huge, what size are they. Engine looks nice. Just a rebuilt with a little head work or more. Either way looks good
V8Blaze is offline
post #11 of 80 Old 10-14-2008, 05:34 PM
S10wannabee's Avatar
User is: S10wannabee is offline
nice work you did on the engine..
your blowerbox looks good!
just an european Bagged-S10
my project
https://www.s10forum.com/forum/f30/s1...roject-353755/
post #12 of 80 Old 10-14-2008, 05:53 PM
is out cruisin...
low98's Avatar
User is: low98 is offline
Send a message via AIM to low98
awesome detail on the engine man...GL with gettin the rest all back together
low98 is offline
post #13 of 80 Old 10-15-2008, 02:54 AM Thread Starter
Working on aircraft
ablues10's Avatar
Thanks! Their 20's (235/40/zr20). I completely rebuilt the engine and rewired the aftermarket stuff in the dash and did some head work. I powdercoated/ painted/ polished everything under the hood.
Thanks! The blowerbox is almost done and it will be powdercoated black. I am using a Chrysler a/c system lol.
It should be less than 2 weeks!
I did a little more today. Every power wire has been stepped up to a minimum of 4 ga. All main grounds are 4 ga. The engine to frame is 1/0, the main batteries are 1/0ga, and the alternator charge wires are 1/0 ga. I did some more work to the speaker box and its gonna be sick!
ablues10 is offline
post #14 of 80 Old 10-22-2008, 12:46 PM Thread Starter
Working on aircraft
ablues10's Avatar
Computer and fuse box are wired up.
Audi A6 Projectors for my HID fog lights
3 Fans to keep the amp cool
Test fit the box
Painted the mirrors
ablues10 is offline
post #15 of 80 Old 10-22-2008, 01:47 PM
Used Midget Dealer!!!!
blackxtreme99's Avatar
User is: blackxtreme99 is offline
Looks good.
post #16 of 80 Old 11-03-2008, 10:09 PM Thread Starter
Working on aircraft
ablues10's Avatar
Update!
Fuse box is wired and mounted. I hope to start it in a day or 2. Fenders are on for good. No more removing them lol.
ablues10 is offline
post #17 of 80 Old 11-25-2008, 10:50 AM Thread Starter
Working on aircraft
ablues10's Avatar
Woo!!! I started this bitch yesterday! Now I can put the front end together. I have to tighten up some stuff and then it will be on to the interior!
ablues10 is offline
post #18 of 80 Old 11-25-2008, 11:55 AM
Drop and Destroy
hghtchtnr's Avatar
User is: hghtchtnr is offline
Send a message via AIM to hghtchtnr
bad ass truck, i hope my engine looks that clean. did u powdercoat or paint the intake manifold?
post #19 of 80 Old 11-25-2008, 12:45 PM Thread Starter
Working on aircraft
ablues10's Avatar
No, the intake manifold is spray painted with high temp engine paint.
ablues10 is offline
post #20 of 80 Old 11-25-2008, 01:16 PM
AcrophobiA
layinlow88's Avatar
User is: layinlow88 is offline
looks awesome man!
did you ever get around to tubbing the firewall??
Get With it,
Brandt
post #21 of 80 Old 11-25-2008, 07:22 PM Thread Starter
Working on aircraft
ablues10's Avatar
Originally Posted by layinlow88 View Post
looks awesome man!
Yup! Got it all done! Thanks for your help!
ablues10 is offline
post #22 of 80 Old 12-04-2008, 10:11 PM Thread Starter
Working on aircraft
ablues10's Avatar
Update. Water in oil, burns water, cant figure it out, head is off again, sending head to machine shop.
ablues10 is offline
post #23 of 80 Old 12-05-2008, 02:54 PM
I Only have A GED!!!
pappie1's Avatar
User is: pappie1 is offline
Send a message via Yahoo to pappie1
Clean truck! Love the motor
BTW 509th FTW
pappie1 is offline
post #24 of 80 Old 01-16-2009, 12:38 AM
nimrod8560's Avatar
User is: nimrod8560 is offline
Send a message via AIM to nimrod8560 Send a message via Yahoo to nimrod8560
Updates?
1982 Mercedes Benz - 240D, AT - 225k - FS: $1000 obo
1997 Prelude - H22A4, AT- wrecked 7/30/07 113k - SOLD
2000 S10 - 4.3L, 4L60E, 2wd - wrecked 12/20/09 102k - SOLD
2001 Prelude - H22A4, AT - 81k
post #25 of 80 Old 01-16-2009, 01:28 AM Thread Starter
Working on aircraft
ablues10's Avatar
The valve cover is back on. I had to pull the head to put in new headbolts.
The whole frame is now black and the bars are all in. When it warms up a lil more, I will get back out there.
Here are the bars the silver is the base for the blue powdercoat.
ablues10 is offline
post #26 of 80 Old 01-16-2009, 01:31 AM Thread Starter
Working on aircraft
ablues10's Avatar
Plans are to move the valves where the jump seat used to be and run lines so it will dump outside the cab. Then put my 2 batteries where the gas tank used to be. Then get the rest of the motor back together.
I had my wisdom teeth pulled a lil while back, so that impeded progress a lil bit.
ablues10 is offline
post #27 of 80 Old 01-16-2009, 02:03 AM
Woody22's Avatar
User is: Woody22 is offline
Send a message via AIM to Woody22
hell ya! looks good
Brad
-88 s-15 scsb. 350/700r4. 8.5 blazer rear. 15" baby moons!
Woody22 is offline
post #28 of 80 Old 01-16-2009, 08:01 AM
nice progress you made,
did you found out what caused the waterburning/leaking???
my project
post #29 of 80 Old 01-16-2009, 11:48 AM Thread Starter
Working on aircraft
ablues10's Avatar
I havent started it back up yet but I think it was a combo of stuff. I had 16ga sheet metal for a block off plate for the egr valve and that is now 1/4in. Then I think reusing the headbolts caused it. I have new headbolts now.
ablues10 is offline
post #30 of 80 Old 01-17-2009, 03:22 AM
Rollin' SoLow
BAGGED1999SDIME's Avatar
User is: BAGGED1999SDIME is offline
careful with the fuse box there thats where i put mine and the semi infront of me lost a re tread and it tore it apart and i had a nice engine fire
DRAG AT ALLLLLL COSTS
post #31 of 80 Old 07-09-2009, 01:20 AM Thread Starter
Working on aircraft
ablues10's Avatar
Its been 6 months since the update. I got the seats re-upholstered, flood dynamated, new black carpet, OH! and it runs! My problem was that the 3 &4 injectors were backed out cause the rail wasnt bolted in.
I am going back home in a week, more progress to come soon.
ablues10 is offline
post #32 of 80 Old 07-09-2009, 01:26 AM
adamkilgore7's Avatar
User is: adamkilgore7 is offline
i love those seats
post #33 of 80 Old 07-09-2009, 03:19 PM
Hoods are overrated
sadexcuse4s10's Avatar
User is: sadexcuse4s10 is offline
Send a message via AIM to sadexcuse4s10
nice work man, love the motor
Project '86 *Shame to Fame* FOR SALE, wife expecting baby. No engine or trans.
'93 Honda XR650L rebuild
post #34 of 80 Old 07-09-2009, 05:58 PM Thread Starter
Working on aircraft
ablues10's Avatar
Thank you. I have been tossing around the idea or turboing it while I have the cash.
ablues10 is offline
post #35 of 80 Old 07-12-2009, 08:56 PM Thread Starter
Working on aircraft
ablues10's Avatar
I am going to buy a set of Alpine type-x components in the next 3 days. That should sound nice.
ablues10 is offline
post #36 of 80 Old 07-14-2009, 05:00 PM Thread Starter
Working on aircraft
ablues10's Avatar
Progress!
Carpet is in, also look at the shifter!
I plan on cleaning up the overspray and chroming the vents. Everything else is just a lil dusty.
ablues10 is offline
post #37 of 80 Old 07-15-2009, 01:15 AM Thread Starter
Working on aircraft
ablues10's Avatar
More pics!
Oh, that shifter is one of these:
ablues10 is offline
post #38 of 80 Old 07-17-2009, 09:55 AM Thread Starter
Working on aircraft
ablues10's Avatar
Ordered a new pillar pod, 8mm sparkplug wires, and some drilled and slotted rotors. Should be here in a week.
ablues10 is offline
post #39 of 80 Old 07-17-2009, 10:12 AM
nice progress, those seat look comfy..
that shifter you've made is actually kinda cool!! i like it!
my project
post #40 of 80 Old 07-17-2009, 10:38 AM Thread Starter
Working on aircraft
ablues10's Avatar
Thanks!
ablues10 is offline
post #41 of 80 Old 07-25-2009, 03:02 PM Thread Starter
Working on aircraft
ablues10's Avatar
Mo shit. Got the drilled and slotted rotors in.
Started wiring up the alarm and poppers.
ablues10 is offline
post #42 of 80 Old 07-25-2009, 03:34 PM
BarelyGettinBy's Avatar
User is: BarelyGettinBy is offline
Looking great
post #43 of 80 Old 07-25-2009, 05:42 PM
sold the dime :(
rbryant4's Avatar
User is: rbryant4 is offline
dunno if i missed it. but what is up with ur dash grab bar on pass side?
08 silverado- 4/7 drop, 24" hoyo H10B
rbryant4 is offline
post #44 of 80 Old 07-26-2009, 11:30 AM Thread Starter
Working on aircraft
ablues10's Avatar
Its made from steel. It needs to be powdercoated. I wrapped some foam around it for now.
ablues10 is offline
post #45 of 80 Old 08-07-2009, 01:00 AM Thread Starter
Working on aircraft
ablues10's Avatar
Re: Project: Ablues10's Resurrection
I blew my radiator today....
ablues10 is offline
post #46 of 80 Old 08-07-2009, 01:52 AM
GM
GM's Avatar
User is: GM is offline
Send a message via AIM to GM
Great build thread man. Love the original tear down and the build back up is so clean. Do you still want to turbo it?
GM is offline
post #47 of 80 Old 08-10-2009, 12:21 AM Thread Starter
Working on aircraft
ablues10's Avatar
Thanks man. I just want to get it running right first. If it runs like shit then I will swap a V-8 and call it done.
ablues10 is offline
post #48 of 80 Old 08-20-2009, 01:35 AM Thread Starter
Working on aircraft
ablues10's Avatar
This truck hates me. I sheered off one of my link bar ends trying to adjust it. I also had a bad power steering pump leak. Thats fixed tho.
ablues10 is offline
post #49 of 80 Old 08-20-2009, 08:50 AM
B4U Task Force
Rhotpursuit's Avatar
Hey...at least the wipers work...
Apple Red 96 SS
post #50 of 80 Old 08-20-2009, 12:35 PM Thread Starter
Working on aircraft
ablues10's Avatar
LMAO, actually.... the wiring is a little messed up lol
ablues10 is offline
