ls1 blazer - S-10 Forum
post #1 of 163 Old 08-27-2012, 02:28 PM Thread Starter
t_ank's Avatar
User is: t_ank is offline
ls1 blazer
well im starting to slowly gather parts for blazer i purchased in july. So i decide ill start a project log so i have it as time goes on and share my time spent on it with others. I found this blazer for sale 3 years ago at the time the money wasnt there but i wish i could have owned it. Well one day in july i got the bug to get back in the car scene and i wanted a good platfrom that was a little different so i went on craigslist. I found the blazer again on 12 miles away and the money was there so i went to look at it the next day and left with it !
so far its been nothing but good to me and plans for the winter shall be fun but i wanted to start working on it now a little bit. So my buddy paints so i pulled my corners and marker lights and smoked them and doing the tails next weekend. i want to get into performance more then looks so i started looking for axles because the 10 bolt 7.5 open diff w 3.08s isnt the best to have behind a ls1. so i did some reading and went with a 8.8 lsd w 3.73 and disc brakes out of a explorer.
plans are for the moment
8.8 installed
cam
springs
stall
vette wheels
i keep going back n forth if i want to turbo it which i really do or just motor i guess we will see where money is this winter.
ill keep it updated and pics as i go.
i have the 8.8 now and the axles out, the old studs removed, the new holes marked for the chevy bolt pattern, new studs,conversion u joint, u bolts ordered should be here tomorrow. then i just have to get the brake lines and rotors and pads and put it all together and stall it. work been slow so should happen fairly quick.
im sure you guys have seen this before i bought it off a guy that posted on here and seen it on cl and purchased it
heres a pic of the blazer
t_ank is offline
post #2 of 163 Old 08-27-2012, 05:11 PM
User is: Carraudio is offline
Re: ls1 blazer
Looks nice I like the 2 doors like that.
post #3 of 163 Old 08-27-2012, 08:13 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
Thanks
t_ank is offline
post #4 of 163 Old 08-27-2012, 09:21 PM
keepin it freshhh
Slowlowandbangin's Avatar
User is: Slowlowandbangin is offline
Re: ls1 blazer
looks good, good luck
post #5 of 163 Old 08-28-2012, 12:59 AM Thread Starter
t_ank's Avatar
Re: ls1 blazer
thanks man i scrolled thru your looks good as well.
im trying to figure out what drop i have on mine now.
i want to go lower but dont want to notch it? 4/5 gotta be notched?
t_ank is offline
post #6 of 163 Old 08-28-2012, 02:28 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
as promised...
pic #1 8.8 rear axle disc brakes 3.73 lsd getting it cleaned up for paint
pic #2 the insides =)
pic #3 new wheels studs drill bit u joint and driveshaft flange
pic #4 axle shafts with ford studs removed and chevy lug pattern marked
pic #5 little something im going to start making the bracket for soonish ls1 calipers
hoping to get the axles drillled this week waiting on my buddy to go to his garage and use the drill press then get the new studs and axles back in
ID:	127400   Click image for larger version
ID:	127401   Click image for larger version
ID:	127402   Click image for larger version
ID:	127403   Click image for larger version
t_ank is offline
post #7 of 163 Old 09-04-2012, 02:03 AM Thread Starter
t_ank's Avatar
Re: ls1 blazer
well cant figure out how to edit the page was gonna add more and bigger pics i guess ill just start here. if anyone can inform how to edit post thanks in advance.
well i got the 8.8 prepped and painted along with the dust shield and calipers
8.8 swaybar brackets removed
8.8 was ground down and cleaned up and painted
few pictures of the blazer
a little paint drop
before
after
hoping soon to get the djm drop coils and drop leafs. not sure what brand leafs to go with for a smooth ride. options guys?
have alot of plans for this for the winter
first off getting the 8.8 dropped in along with this list
95-97 blazer composite headlights and grill swap
55 watt hids 4500k
djm 3in drop coils
drop leafs maybe bigger blocks (not sure on brand)
ms4 cam
precision dual springs
stall (not sure how big or brand)
electric cut outs
wheel and tires (something with a 7in backspacing because im running the full length 8.8 and want to run so wide ass drag radials in the back hope i dont have a clearance issue with the drop. what do you guys think? like 4in drop in the back can i tuck a 315?)
well thats the plan no order but it will all get done. might also start fab on turbo manifolds if the time and moneys there =)
t_ank is offline
post #8 of 163 Old 09-04-2012, 03:14 AM
littledevil4802's Avatar
User is: littledevil4802 is offline
Send a message via AIM to littledevil4802
Re: ls1 blazer
blazer looks really good. what part of michigan are you from?
92 reg. cab-lowered 5/4-sold
95 std cab- bagged about to be bodied
www.airedup.com
post #9 of 163 Old 09-04-2012, 09:39 AM
sonomanator's Avatar
User is: sonomanator is offline
Re: ls1 blazer
Hey I drive this blazer nice little truck
edited this 12/2013 but i wont be back for years.
post #10 of 163 Old 09-04-2012, 12:59 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
lapeer i see your from warren
t_ank is offline
post #11 of 163 Old 09-04-2012, 02:48 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
thanks man
96 blazer ls1/ls6 intake/sanderson shorties/2.5 h pipe/borla
t_ank is offline
post #12 of 163 Old 09-04-2012, 04:54 PM
I has s475
Tuckin15's's Avatar
User is: Tuckin15's is offline
Re: ls1 blazer
Another guy from MI nice! I saw this blazer on craigslist also about a week after i picked up my 5.3 ext cab.
post #13 of 163 Old 09-04-2012, 05:17 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
thanks man. where abouts you located?
yea i have had it for a lil while a guy on here had it but i seen it on cl and knew the guy that did everything to it on another forum
t_ank is offline
post #14 of 163 Old 09-04-2012, 05:22 PM
I has s475
Tuckin15's's Avatar
Re: ls1 blazer
I live in Spring lake, Get_Low and i are Good friends.
post #15 of 163 Old 09-04-2012, 06:55 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Re: ls1 blazer
I recall seeing this on CL too. Nice Blazer.
post #16 of 163 Old 09-04-2012, 08:06 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
thanks mostizzle
well tuckin15 all have to cruise sometime
how you like that 5.3? you need to put a ls1 intake on it
t_ank is offline
post #17 of 163 Old 09-04-2012, 10:17 PM
I has s475
Tuckin15's's Avatar
Re: ls1 blazer
Originally Posted by t_ank View Post
thanks mostizzle
Yea for sure I'm stationed in Texas right now im in the army but i should be home sometime next summer.
I love the 5.3. I'll be going to the fast 102 intake with a bigger throttle body and get the heads done next winter. If your gonna run a car style intake i would run the LS6 the Ls1 is a poor car intake i hate to say it but the 5.3 truck intake makes more power and torque than the ls1 intake does.
post #18 of 163 Old 09-04-2012, 10:55 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
opps i might to say ls6 intake not one yea they dont flow to good i have a ls6 intake on my ls1. but i was also this winter looking into a fast intake
t_ank is offline
post #19 of 163 Old 09-04-2012, 11:05 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
picked up these tt2s 17x9.5 17x11
painted my work truck wheels today
t_ank is offline
post #20 of 163 Old 09-05-2012, 04:22 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
what ya guys think? im undecided if i like them
t_ank is offline
post #21 of 163 Old 09-05-2012, 07:20 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
rears mocked up on 8.8 =)
t_ank is offline
post #22 of 163 Old 09-05-2012, 09:30 PM
goin broke but n style
S15vortecpwr's Avatar
Re: ls1 blazer
I like both wheels personally.
but to me the TT2's look better.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #23 of 163 Old 09-05-2012, 10:17 PM
Sold :'(
s10xtremist's Avatar
User is: s10xtremist is offline
Re: ls1 blazer
I say the TT2s are better because of form and function. You need traction with that V8, and the 11" rear wheels will allow a much wider tire than the 8" wide Xtreme wheels.
Getting better with every failure
[SIGPIC][/SIGPIC]
Project threads:
Punching bag
Unicorn XJ
post #24 of 163 Old 09-05-2012, 10:37 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
thanks guys i like them just need to get the truck down more.
yes the 11in rear and 315 drag radial she will be nice lol
t_ank is offline
post #25 of 163 Old 09-05-2012, 11:05 PM
Sold :'(
Re: ls1 blazer
I don't have V8 power yet, but I ditched my 20x8.5 for some 18x9.5 for better ride quality and more contact patch.
[SIGPIC][/SIGPIC]
Project threads:
Punching bag
Unicorn XJ
post #26 of 163 Old 09-05-2012, 11:51 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
i read that in one of your post good to hear i was my rear was 18x11 but the 17s works love your truck tho looks super clean
t_ank is offline
post #27 of 163 Old 09-06-2012, 12:48 AM
Re: ls1 blazer
I like the tt's but like u said you need to lower it more to much of a gap or throw something that will fill the wheel well better.
www.airedup.com
post #28 of 163 Old 09-06-2012, 07:40 AM Thread Starter
t_ank's Avatar
Re: ls1 blazer
yea it will happen so i do seasonal work and its about over with so money been tight due to other bills
t_ank is offline
post #29 of 163 Old 09-06-2012, 09:25 AM
I has s475
Tuckin15's's Avatar
Re: ls1 blazer
Yea keep some fatties in back i'm running a 245/60/15 and my truck doesn't hook for anything. I'm looking on going to a 10 inch wide rear wheel.
post #30 of 163 Old 09-06-2012, 10:09 AM
84blaze's Avatar
User is: 84blaze is offline
Re: ls1 blazer
Will you be shortening your new rear end to allow the TT2's to tuck once you lower it?
84blaze is offline
post #31 of 163 Old 09-06-2012, 12:15 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
yeai have 245 now lol blow those off all day long
t_ank is offline
post #32 of 163 Old 09-06-2012, 12:18 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
im not gonna go that low to tuck them
i dont know what im going with these axle i cant find anyone to redrill the chevy lug pattern im about to say screw it and run a 7.5 or 8.5
t_ank is offline
post #33 of 163 Old 09-06-2012, 12:25 PM
A work in progress...
jasond's Avatar
User is: jasond is offline
Re: ls1 blazer
The tt2's will look really good with moar low. I really like the color, is it a factory code?
jasond is offline
post #34 of 163 Old 09-06-2012, 04:06 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
thank you hopefully within the next month the axle will be done and in along with more low low . color is sunburst metallic orange 2008 hhr.
sending the axles out to be drilled by moser 65 bucks cant beat that.
t_ank is offline
post #35 of 163 Old 09-06-2012, 10:52 PM
Sold :'(
Re: ls1 blazer
I don't know the backspacing of the 17s nor how the rear fender lip is on a Blazer. But, I had to roll the lips of mine to fit the 18x9.5s. With my drop, the tire is almost going under the fender. The tires go a couple inches into the well during driving, and I have plenty of clearance.
[SIGPIC][/SIGPIC]
Project threads:
Punching bag
Unicorn XJ
post #36 of 163 Old 09-06-2012, 11:02 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
thhey are going to sit flush pretty much i think i dont know we will see when its all said and done. but im not going to slap it i dont think
t_ank is offline
post #37 of 163 Old 09-07-2012, 04:50 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
http://www.summitracing.com/parts/DJM-CS2321-3/
these work good with my 2 bt ds? with the v8?
t_ank is offline
post #38 of 163 Old 09-07-2012, 05:40 PM
ELTC
Gimp's Avatar
User is: Gimp is offline
Re: ls1 blazer
clean Blazer man. saw it in the classifieds..like the additions so far looks great moar low and with the wheels. would be sick if you cut your grille shell out to fit the phantom insert
def subscribed
2003 GMC Sierra 6/8
1989 Chevy S10 V8 5/6
Gimp is offline
post #39 of 163 Old 09-07-2012, 09:50 PM
Chopper! Sic balls!
Mostizzle's Avatar
Re: ls1 blazer
If you drop it 5" in the front the lower control arms are going to bottom out on the frame over bumps and it'll most likely ride like ass in the front. Just a heads up.
post #40 of 163 Old 09-07-2012, 09:59 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
well i already pulled the 1in spacers on the driver side and going to do the other side tomorrow. i hope it doesnt ride like shit but we will see.
just dont get why my blazer seems so high compare to others. i have so much wheel gap. ill be 5in in the front tomrrow ill post pics then.
t_ank is offline
post #41 of 163 Old 09-07-2012, 10:01 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
def subscribed
thanks man im working on the low part of it just isnt working out. maybe i need a bigger rim like 18 with some tires and it will clear up my wheel gap. bit im not that huge fan of that grill i like mine.
t_ank is offline
post #42 of 163 Old 09-07-2012, 10:21 PM
BOYD's Avatar
User is: BOYD is offline
Re: ls1 blazer
man looks good mine is a 96 to i need to do that ls1 in mine keep it up
BOYD is offline
post #43 of 163 Old 09-07-2012, 10:28 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
thanks boyd
t_ank is offline
post #44 of 163 Old 09-08-2012, 12:04 AM
S - I - C
DROPTSBLAZE's Avatar
User is: DROPTSBLAZE is offline
Send a message via AIM to DROPTSBLAZE
Re: ls1 blazer
When I read the thread title I was hoping to see a 1st gen Blazer in here.
It looks good, though. You're going to have a lot of fun driving it when it's done.
'91 Mazda B2200 - LT1 swap
'00 S-10 ex cab 4.8l LS swap
post #45 of 163 Old 09-08-2012, 12:53 PM
I has s475
Tuckin15's's Avatar
Re: ls1 blazer
U need some 98 1/2 + dumbo mirrors.
post #46 of 163 Old 09-08-2012, 10:32 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
lol sorry man. but the swaps is already done. just going to beef up the ls1. just not sure if i want to go motor or force induction
t_ank is offline
post #47 of 163 Old 09-08-2012, 10:35 PM Thread Starter
t_ank's Avatar
Re: ls1 blazer
why is that sir? references?
well i pulled the 1in spacers out so now im 5in low in the front. very happy to have this done and didnt buy any new parts. damn spacer and index wasnt right. now have to lower the rear a lil bit. pics tomorrow
t_ank is offline
post #48 of 163 Old 09-08-2012, 10:50 PM
I has s475
Tuckin15's's Avatar
Re: ls1 blazer
Cause there sick lolol the 94-97 mirrors are pooooo
post #49 of 163 Old 09-09-2012, 09:44 AM
User is: MARS2878 is offline
Re: ls1 blazer
Truck looks good.
Any underhood pics?
MARS2878 is offline
post #50 of 163 Old 09-09-2012, 11:35 AM Thread Starter
t_ank's Avatar
Re: ls1 blazer
ill add them to my list then lol
t_ank is offline
You may post new threads
You may post replies
