I've lost count - 1988 GMC S-15 Base - S-10 Forum
 22Likes
  • 1 Post By tytotheler92
  • 1 Post By heeter_33
  • 4 Post By tytotheler92
  • 2 Post By tytotheler92
post #1 of 45 Old 01-29-2018, 11:59 PM Thread Starter
Maybe later.
tytotheler92's Avatar
Another one.
Won this on eBay for $500.
1988 GMC S-15 Base Sierra Trim w/ 160k. Iron Duke/5 Speed. Hasn't been registered since....2002.
Didn't run, actually engine was locked up. Some kerosene took care of that. Fuel Pump, Tank, and later a new ECU made it run. (Along with general tune up, water pump, radiator, fluid changes, filters, blah blah blah for a vehicle that hasn't run in 16 years.)
Brought it home.
Even came with a window sticker.
One of many reasons why it didn't run.
Broke some stuff.
Dropped the rear 5 inches and did general axle maintenance (Seals, fluid, ect)
She runs.
W.E.G. likes this.
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
post #2 of 45 Old 01-30-2018, 10:46 AM
1987 S10 4x4
old-blue's Avatar
User is: old-blue is offline
Re: I've lost count - 1988 GMC S-15 Base
Looks solid - great rescue! Opening up that old fuel tank must have knocked you over with the smell. Nice to see the original window sticker. $11,443 in 2017 dollars is $23,805.
old-blue is offline
post #3 of 45 Old 01-30-2018, 10:50 AM
In charge of the big door
tajohns34's Avatar
User is: tajohns34 is offline
Tyler, I think you have a problem.
Q: How many people can you fit in one Honda?
A: Well, the Bible said that all 12 disciples were in one Accord.
>-----<My Build thread>-----<
>-----<Facebook>-----<
>-----<Instagram>-----<
post #4 of 45 Old 01-30-2018, 12:10 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Nice. Looks pretty solid.
TelAmeriCorp
post #5 of 45 Old 01-30-2018, 12:14 PM Thread Starter
Maybe later.
Thanks everyone! I do have a problem lol.
The truck is really solid actually. Patina is in style right now anyways so I figure when itís done itíll turn some heads.
1985 S10 Blazer 4WD
post #6 of 45 Old 01-30-2018, 12:58 PM
tajohns34's Avatar
I would love to get a decent first gen and static drop it as a daily.
post #7 of 45 Old 01-30-2018, 01:16 PM
I don't feel tardy
joedoh's Avatar
User is: joedoh is offline
nice find!
how did you use kerosene? I deal in sludgey motors all the time and the way I heard to do it was to pull the plugs and fill the engine completely up with kerosene, like cylinders and crankcase and heads just full, and let it sit, then drain, refill with oil, crank over a couple times to empty cylinders, reinstall plugs and run.
joedoh is offline
post #8 of 45 Old 01-30-2018, 10:00 PM Thread Starter
Maybe later.
Originally Posted by joedoh View Post
nice find!
Dumped it down the spark plug holes and rolled it back in gear.
Then attempted to start it lol. It was flooding it self the entire time so the insides are probably like brand new with all the gas it used to clean and lubricate. LOL
Basically the ECM was commanding the injector to be fully open the entire time. After doing alot of wire load testing, I'm like alright it's gotta be the ECM. It was. Put that in and it started right up.
Its been sitting for 16 years because of a $50 ecm. lol.
But OMG electronics are scary.
1985 S10 Blazer 4WD
post #9 of 45 Old 02-01-2018, 06:28 PM
User is: W.E.G. is offline
Well done!
W.E.G. is offline
post #10 of 45 Old 02-05-2018, 04:05 PM
Finished!
92ST's Avatar
User is: 92ST is offline
Awesome! What are your plans for it?
92ST is offline
post #11 of 45 Old 02-05-2018, 09:50 PM Thread Starter
Maybe later.
Hopefully drive it one day. Lol
I need to throw the front suspension on it and get it out of the garage. Lol
Once Iím done with it all it should be 4/5 on 15Ē GMC rally wheels.
1985 S10 Blazer 4WD
post #12 of 45 Old 02-06-2018, 10:30 PM Thread Starter
Maybe later.
Few more updates.
The list of things I've done to this truck so far is endless and I'm still not 100% there with the way it runs. Seems to run perfectly with the O2 sensor unplugged, but just OK with it plugged in. I may just wait until its drivable to with it more.
Little dookie looks nice. I can't wait to detail the engine bay.
Found a few minty junk yard items.
Bit of a tease.
IhaveNoPantsOn likes this.
1985 S10 Blazer 4WD
post #13 of 45 Old 02-14-2018, 06:44 PM Thread Starter
Maybe later.
This thing is angering.
It suddenly started running like crap again. Received a Code 53 which means the PCM is sensing voltage under 10v or over 17. Neither of which is happening.
Getting the replacement PCM warrantied, hopefully that resolves the issue and I got a dud PCM.
Some pics and a video.
ID:	298649   Click image for larger version
ID:	298657   Click image for larger version
1985 S10 Blazer 4WD
post #14 of 45 Old 02-15-2018, 04:45 PM
heeter_33's Avatar
User is: heeter_33 is offline
Some pictures work and some pictures don't, and I want to see pictures!
RangerWeaver likes this.
1985 S10 2.8
2010 Cobalt SS
1972 Honda CB100
post #15 of 45 Old 02-15-2018, 09:59 PM Thread Starter
Maybe later.
I know, I'm not going to bother with hosting anymore. It's useless.
I will attach photos from now on.
1985 S10 Blazer 4WD
post #16 of 45 Old 02-15-2018, 10:39 PM
Chopper! Sic balls!
Mostizzle's Avatar
I think the interface is a bit more difficult than PB but I switched to flickr.
TelAmeriCorp
post #17 of 45 Old 02-26-2018, 01:41 AM Thread Starter
Maybe later.
Well, it's running. It's driving. And it's slammed.
Drove it some, put a full tank of gas in it for the first time in 16 years. lol.
ID:	299842   Click image for larger version
ID:	299850   Click image for larger version
ID:	299858   Click image for larger version
ID:	299866   Click image for larger version
1985 S10 Blazer 4WD
post #18 of 45 Old 02-26-2018, 01:45 AM Thread Starter
Maybe later.
I need to order the JTR extended cab driveline correction kit, 3" blocks and notch the frame.
I might order 2" blocks...half in might be all it needs. Right now it's approximately 5/6. DJM Springs, Belltech Street Performance shocks and it really rides and handles GREAT.
ID:	299882   Click image for larger version
ID:	299890   Click image for larger version
ID:	299898   Click image for larger version
1985 S10 Blazer 4WD
post #19 of 45 Old 02-26-2018, 01:48 AM Thread Starter
Maybe later.
Few things need worked out however.
Trans leaks from something.
It's too low to use my existing jack.
Need to remove frame rear bump stop
Alignment
Tensioner
Fix Temp Gauge
JTR Rear Hardware
But yeah, otherwise it's ready to break again! LOL.
1985 S10 Blazer 4WD
post #20 of 45 Old 02-26-2018, 04:31 PM
Chopper! Sic balls!
Mostizzle's Avatar
Looks sweet.
TelAmeriCorp
post #21 of 45 Old 02-26-2018, 09:18 PM
Harley's Avatar
User is: Harley is offline
That's definitely a great eBay score.
I have that JTR extended cab driveline kit. Just pulled it out the other day to snap pictures and list for sale if you're interested.
Harley is offline
post #22 of 45 Old 02-26-2018, 09:51 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Tyler ...
got the S10 disease...
Looking bargainish - if you don't empty your bank account on it.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #23 of 45 Old 03-01-2018, 03:11 PM Thread Starter
Maybe later.
Let me know! My email is [email protected].
1985 S10 Blazer 4WD
post #24 of 45 Old 03-01-2018, 03:14 PM Thread Starter
Maybe later.
Originally Posted by Mostizzle View Post
Looks sweet.
Thanks!
Originally Posted by Mad Max View Post
Tyler ...
Yep! And...well...I have basically been throwing money at it and it's not over yet. lol.
1985 S10 Blazer 4WD
post #25 of 45 Old 04-02-2018, 02:38 AM
I don't feel tardy
joedoh's Avatar
late to say it but that looks outstanding. nothing better than a lowered stock truck in my book.
joedoh is offline
post #26 of 45 Old 04-02-2018, 08:36 AM Thread Starter
Maybe later.
Thanks man!
Here's some recent pictures of it. Put about 250 miles on it and have only used half a tank. LOL.
Got a new valve cover and the FelPro metal core gasket since mine is leaking already.
ID:	302610   Click image for larger version
ID:	302618   Click image for larger version
ID:	302626   Click image for larger version
ID:	302634   Click image for larger version
1985 S10 Blazer 4WD
post #27 of 45 Old 04-05-2018, 12:44 AM Thread Starter
Maybe later.
More whoring.
Also, look at how big the colorado looks! And it's honestly tiny next to modern fullsizes now!
ID:	303074   Click image for larger version
ID:	303082   Click image for larger version
ID:	303090   Click image for larger version
JayinMI likes this.
1985 S10 Blazer 4WD
post #28 of 45 Old 04-05-2018, 01:29 AM
User is: Windy City is offline
Yea itís crazy how big trucks have gotten! The new Coloradoís are as big as my dads old 2000 Silverado 1500.
I just bought a 2500 hd and I need a friggin ladder to get in it, unfortunately it is too tall making it difficult to actually work out of the bed. All the manufacturers are making them this big
Sent from my iPhone using Tapatalk
post #29 of 45 Old 04-22-2018, 12:18 AM Thread Starter
Maybe later.
Exactly!
So, I ripped the interior out and redid it. Headliner turned out great.
Took it on a 1 hour interstate trip and didn't have any issues.
ID:	304898   Click image for larger version
ID:	304906   Click image for larger version
ID:	304914   Click image for larger version
ID:	304922   Click image for larger version
JayinMI and IhaveNoPantsOn like this.
1985 S10 Blazer 4WD
post #30 of 45 Old 05-01-2018, 01:41 PM Thread Starter
Maybe later.
Some Ajax, dish soap, buffing compound, 3000 grit and some wax later annnnndddddd....
We have something gooooodddd.
ID:	305826   Click image for larger version
ID:	305834   Click image for larger version
ID:	305842   Click image for larger version
ID:	305850   Click image for larger version
IhaveNoPantsOn and 92ST like this.
1985 S10 Blazer 4WD
post #31 of 45 Old 05-01-2018, 01:41 PM Thread Starter
Maybe later.
It's really good.
Got some new tires, cleaned up the wheels, and removed the sticky pad around the bed from the cap
IhaveNoPantsOn and emmett2455 like this.
1985 S10 Blazer 4WD
post #32 of 45 Old 05-10-2018, 04:43 PM Thread Starter
Maybe later.
Picked up a transmission for this. It's out of a newer truck, so it's not mechanical speedo, but I should be able to get it to work with a tailshaft swap.
Also, made a harness to run a cheap BT HU in the glove box while retaining the stock EQ HU in the dash.
ID:	306682   Click image for larger version
ID:	306690   Click image for larger version
ID:	306698   Click image for larger version
1985 S10 Blazer 4WD
post #33 of 45 Old 05-10-2018, 06:36 PM
Boozebag
Mad Max's Avatar
Tyto -
From what I have understood, the speedo issue is not just a simple tail shaft swap.
From what I've seen, the mechanical speedo connection is in a different location on the tail shaft. The mods I have seen included welding the e pickup hole shut and relocating the hole for the cable drive forward. You then need to locate the bevel gear in the right spot on the output shaft.
I have that clean 82 long bed with a 5 speed e speedo tranny. Someone swapped the fiver for a 4 speed that was in it.
I looked into it, it's close to 300 pesos to correct the issue (tail mod).
I'm probably going to buy a GPS speedo generator and connect the cable speedo to it.
No worries about gear or transmission ratios.
It's about $150 IIRC.
Truck is looking bonkers. The fade is way cool.
Cleaned and dropped really well.
Wait... isn't an 88 electronic speedo?
S10 addiction:
Mad Max is offline
post #34 of 45 Old 05-10-2018, 06:43 PM
Boozebag
Mad Max's Avatar
Sorry for the 2x.
Check it out:
https://www.speedhut.com/Speedbox.html
Thanks to jwvess
S10 addiction:
Mad Max is offline
post #35 of 45 Old 05-10-2018, 10:22 PM
RangerWeaver's Avatar
User is: RangerWeaver is offline
kinda want to do this to my S10 now... but I don't think it would look as nice on the second gen body style
post #36 of 45 Old 05-25-2018, 09:35 AM Thread Starter
Maybe later.
Tyto -
It's a mechanical speedo, which is weird because it seems like some trucks were electric at this point.
That Speedhut speedo converter is SWEET, and I should be able to reuse that signal for a Rostra cruise setup later on. Thank you!!
1985 S10 Blazer 4WD
post #37 of 45 Old 05-25-2018, 09:36 AM Thread Starter
Maybe later.
You can really screw with single stage and still end up with a nice end product.
Base/clear, it's much harder. I would just do a compound from aggressive to polish.
1985 S10 Blazer 4WD
post #38 of 45 Old 05-25-2018, 09:40 AM Thread Starter
Maybe later.
So I lowered the back another inch, and then rebuilt the doors.
New window runs, clips, sound deadening, and new sweeps.
Shuts like a bank vault now.
ID:	308106   Click image for larger version
ID:	308114   Click image for larger version
1985 S10 Blazer 4WD
post #39 of 45 Old 05-25-2018, 09:41 AM Thread Starter
Maybe later.
This is a pretty cool picture too.
1985 S10 Blazer 4WD
post #40 of 45 Old 05-25-2018, 12:11 PM
LOOK AT MY NIPPLES!
IhaveNoPantsOn's Avatar
User is: IhaveNoPantsOn is offline
Uugghhhhh...that pic makes me happy in the pants.
S-10's - because they're cheap and easy, and I'm poor and lazy
RIP Scotty 'Gimp' Oliver 6/6/84 - 5/31/16
MyTruckHasNoPantsOn!
Junkyard Gem
post #41 of 45 Old 05-25-2018, 02:20 PM
B4U Task Force
Rhotpursuit's Avatar
Maker up your mind....do you have pants on or not?...lol
Apple Red 96 SS
post #42 of 45 Old 05-25-2018, 02:38 PM Thread Starter
Maybe later.
I've met up with him twice, he does. lol.
1985 S10 Blazer 4WD
post #43 of 45 Old 05-25-2018, 05:44 PM
LOOK AT MY NIPPLES!
Itís true My username is a lie!!!
Junkyard Gem
post #44 of 45 Old 05-25-2018, 06:05 PM
B4U Task Force
Well that's a relief...
Apple Red 96 SS
post #45 of 45 Old 06-25-2018, 12:39 AM Thread Starter
Maybe later.
More pics.
ID:	310121   Click image for larger version
ID:	310123   Click image for larger version
ID:	310125   Click image for larger version
1985 S10 Blazer 4WD
