Bought a crew cab S10, and just feeling out the forum. - S-10 Forum
 9Likes
  • 1 Post By BravadaX
  • 1 Post By tytotheler92
  • 1 Post By oldeerslayer
  • 1 Post By Mad Max
  • 1 Post By TeckMonster
  • 1 Post By dime-dozen
  • 1 Post By goes2fast
  • 1 Post By Mostizzle
post #1 of 22 Old 03-29-2018, 11:18 PM Thread Starter
TeckMonster's Avatar
User is: TeckMonster is offline
I'm working on manual swapping my crew cab with parts out of my 99 Blazer.
I've pulled a few parts out of the Blazer already, but I'm going to do the rest in my father's garage. Planning on taking everything over before the weekend.
ID:	302410   Click image for larger version
ID:	302418   Click image for larger version
ID:	302426   Click image for larger version
2002 S10 crew cab (manual swapped).
1996 Jimmy 2 door, 5 speed (Gambler 500 rig)
1999 Blazer ZR2 2 door, 5 speed (RIP).
post #2 of 22 Old 03-29-2018, 11:28 PM
Oozing Machismo
SK 99's Avatar
User is: SK 99 is offline
Re: Bought a crew cab S10, and just feeling out the forum.
Very nice! Manual crew cab, **** yeah.
Welcome
'98 Blazer 2-Door 4x4
'95 S10 Ext Cab 2WD 4.3L 5-spd SOLD
'95 S10 Reg Cab 2WD 2.2L 5-spd SOLD
'00 Xtreme Reg Cab 2.2L auto SOLD
'91 S10 Long Bed 2WD 4.3L 5-spd SOLD
SK 99 is offline
post #3 of 22 Old 03-29-2018, 11:37 PM Thread Starter
Thank you. I've still got a fair bit of work ahead of me, but I should have it finished within a couple of weeks.
post #4 of 22 Old 03-30-2018, 08:41 AM
oldeerslayer's Avatar
Glad to see someone giving it a try.
Hope the wiring doesn't end up being a problem. That always seems to be what bites anyone doing major changes on the later models.
post #5 of 22 Old 03-30-2018, 09:32 PM Thread Starter
I've done a few manual swaps (not on a Blazer/S10), and on my most modern car (99 Volvo V70 T5) I used the manual ECU and engine bay wiring harness to get it done. I'll most likely be doing the same with this one depending on how it goes.
post #6 of 22 Old 03-30-2018, 11:14 PM
B4U Task Force
Rhotpursuit's Avatar
Moved to Members Projects.
Apple Red 96 SS
post #7 of 22 Old 03-31-2018, 07:45 AM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Nice! Iíve done a couple S10 manual swaps. The clutch master hole is 1&7/8Ē hole saw. line it up in the centering dimple,and cut slow from under the hood making sure to only go through the first layer of metal. All the notches to lock the master in are already on the lower layer.
On the floor hole I drilled the boot screw holes from underneath the truck. you can see their placement from underneath,..pretty much dead center of the circular holes in the under layer..attached the boot inside the truck,and traced the hole with it. Cutting the main hole is tuff to get clean tho! At least it is for me. the floor pan is really thick! I use the same hole saw I made the clutch master hole with to do the 4 corners,then a sawzall to cut it out the rest of the way...still doesnít look as pretty as Iíd like. Very curious to see how others tackle it!
TeckMonster likes this.
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #8 of 22 Old 03-31-2018, 10:24 AM
Harley's Avatar
User is: Harley is offline
That's how I've done it too, but I cut the straight lines a bit small and use a grinder, roloc wheels, and finally files to ease it into shape.
I don't have a great picture though and this was relocating the hole for my T56, but same concept.
Harley is offline
post #9 of 22 Old 03-31-2018, 12:00 PM Thread Starter
Nice! I’ve done a couple S10 manual swaps. The clutch master hole is 1&7/8” hole saw. line it up in the centering dimple,and cut slow from under the hood.
Thanks! Loads of great information you shared. I was also planning on using a Sawzall. After some quick researching, I'll probably get this carbide tipped blade.
https://www.amazon.com/dp/B00NO8331S..._186VAb94QXRXQ
I'll use a grinder to touch up the hole if it doesn't come out very good.
Thanks for the feedback guys!
post #10 of 22 Old 03-31-2018, 02:28 PM
BravadaX's Avatar
I like the finer tooth/shorter blades for sheet metal. I use those when I cut up frames when I scrap my part trucks.
Thereís some real knowledgeable guys on here about all facets of these trucks from repair to customization. Iím more of a repair to stock individual,lol. Iíve got around a dozen of these s10ís,and have had many more over the years. Unfortunately Iím limited with my 4wd experience,because I mostly deal with the 2wd trucks. I do own several 4wd,the identical crewcab ZR5 as the one you have pictured too!...donít really like it that much,wife drives it. donít like how heavy it feels,and blazer like itís ridd is. Due to the wheel base It feels just like a wide turning version of my 4wd blazer to me. That 5 speed would definitely improve the driving experience.
With all the fab experience and equipment you have Iíd figured youíd have a bad azz cutter! Yeah,I cleaned mine up too the same way with a angle grinder&file.
BravadaX is offline
post #11 of 22 Old 03-31-2018, 03:35 PM Thread Starter
I was thinking about making it 2WD to save on weight (6 speed would be nice too). Currently it does feels like a land yacht compared to the Blazer, I'm hopping the manual swap will help. I'm also looking at doing a 5.3 swap, but I'd need to save a little for that. I'm also thinking about getting a Bravada for parts, possibly using the AWD (I want 2WD or AWD, I don't really do any off-roading), I also want the 120mph gauge cluster, Bose sound system (depending on how good it is), and maybe the front seats (might put Volvo seats in it).
I'm trying to make a fuel efficient comfortable truck I can take on trips while towing a car.
post #12 of 22 Old 03-31-2018, 03:49 PM
Harley's Avatar
I trypically use the bridgeport for straight lines on brackets and such. I don't think the Blazer body will fit on that haha
I also have a plasma, but haven't used it enough to get consistently good cuts. I mostly pull it out for rough cutting or slicing things apart quickly. I could probably make some wood templates on the mill to help steady the shape of what I'm cutting, but will still have to work on keeping the distance from the metal consistent as well as the tip clean.
I started using files only a couple years ago, but was kicking myself for not trying them out sooner. I've been impressed with how well I can straighten lines out with them as well as finessing corners, etc. As long as I take my time and am patient with myself. That last bit is the hardest for sure.
Harley is offline
post #13 of 22 Old 04-02-2018, 08:55 AM
Maybe later.
tytotheler92's Avatar
Awesome!!!!
Nice Crew Cab and good plans!
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
post #14 of 22 Old 04-02-2018, 11:10 AM
Can't tell you how a Bose system is in a Bravada, but all of us C4 Corvette owners hated it.
I replaced the whole system. You have to because you can't replace just part of it. Mine had individual amps on each speaker. They go out continually and are ridiculously expensive when they do. Bose makes a decent home sound system. Just don't move it while it's on. Problem in a vehicle is they used the same components and it is constantly moving.
The old saying is, "No highs, no lows, must be Bose".
post #15 of 22 Old 04-02-2018, 11:39 PM Thread Starter
Awesome!!!!
Thanks.
Hmm. I was hopping it would sound more akin to my buddies 07 Silverado. I knew I was going to have to replace everything (was going to swap over the whole dash, and door panels). I'll most likely build my own system then, but I need to get this manual swap done first.
post #16 of 22 Old 04-02-2018, 11:55 PM
If it's a late 02 you might want to retain the 2 din parts. Early 02's were the 1.5 din.
Most 1.5 dins end up with a single din head unit and look cheap.
post #17 of 22 Old 04-03-2018, 07:47 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is online now
Some suggestions:
Harley... I use the plasma to cut straight lines by tacking or clamping a straight edge to the material being cut. Then I just run the stinger along the straight edge. Works pretty well.
The last time I relocated a floor shift opening, I used a long punch to dimple the 4 corners above the shifter opening from under the truck.
I then took a sharpie and marked the rectangle to cut out on the interior floor. I made straight lines as a pattern and straightened out the opening.
The final step was a cut off wheel to cut out the opening.
The fit was perfect.
I cut a piece of old hood to fill the old shifter hole.
Tmonster... I give you a lot of credit. A totally ambitious project!
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
post #18 of 22 Old 05-26-2019, 03:26 AM Thread Starter
I've tried a couple times to make a new topic on here going through my swap, but the dang thing is so long that something keeps happen and then pictures break, or I end up loosing everything, so I've made a post about it on a forum I know better. That forum isn't for automotive related topics so I'm hopping sharing a link to it won't cause some sort of problem because I do want to share that I got it done successfully, and manual 4 door S10s were never sold here in the US, so I wasn't sure how hard it would be, but it turned out to be supper easy, and I'd like people to know that. If sharing this link does cause a problem feel free to PM me.
My completed 5 speed manual (NV3500) swap post.
https://forum.level1techs.com/t/teck...oor-s10/143353
For those that are iffy about clicking on random links I'll throw some pictures on here.
Ah, just figured out what's going on, I'm exceeding the max file limit. Wish I would have caught that before I wasted 3 hours making a super detailed post with lots of pictures. RIP
Anyways I uploaded what I could, the whole post is in the link above.
ID:	317077   Click image for larger version
ID:	317079   Click image for larger version
ID:	317081   Click image for larger version
ID:	317083   Click image for larger version
Harley likes this.
post #19 of 22 Old 05-26-2019, 11:19 AM
User is: dime-dozen is offline
TM, Im using a Bose system out of a TrailBlazer SS.
Radio,amp,XM,VCIM,Onstar.
For those that say the Bose is crap,come sit in mine,bring the earplugs.
Ive also got a JL audio sub and amp tapped into the Bose subwoofer output.
Speaker upgrades are needed for distortion free full volume.Im sure I could get better but am happy with the Infinity Kappas front and rear(all 6 channels)
post #20 of 22 Old 05-26-2019, 12:16 PM
Old Fart
goes2fast's Avatar
User is: goes2fast is offline
Thanks for the update, it would have been nice if you would have posted as you went along. Where does the 5.3 swap stand?
Too Much Horsepower is ALMOST ENOUGH!
"I have a car-sickness. I need to be checked into the HENRY Ford Clinic." -Tim "The Tool Man" Taylor
post #21 of 22 Old 05-26-2019, 04:18 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
The Bose system in my crappy old Bravada ripped. CD's did skip on occasion but I chalked that up to our sweet roads and the fact that the old compact discs aren't as shiny as they used to be.
The truck turned out awesome dude.
TelAmeriCorp
post #22 of 22 Old 05-26-2019, 08:28 PM Thread Starter
Yeah, I guess I should have posted as I went. Oh well, it's in the past now. I'll try to give more regular updates on the LS swap.
The 5.3 swap will probably start happening in a mouth or two. I already bought a fully loaded 2001 Suburban LT for $650 with a shot transmission. Hopefully I can sell some stuff off of it to get the motor well under $500, but everything is in pretty bad shape, so I donno.
Here's a video about on the Suburban that I though I wouldn't ever post, but you know what YOLO! lol
I'll try to make more and much better videos when I start the LS swap.
goes2fast likes this.
