98 Sonoma project - S-10 Forum
 1Likes
  • 1 Post By BravadaX
post #1 of 13 Old 05-13-2019, 06:49 PM Thread Starter
User is: Mike13chevy is offline
98 Sonoma project
Hey guys. Figure I’ll post in here since I’m not a new member but I don’t post much. Girlfriend Picked me up a 98 gmc Sonoma reg cab short bed 5spd 2.2 has100k. To replace my 2000 s10 extended cab 4.3L 5 spd that got totaled on me. Unfortunately. Sad day. Anyway Sweet little Sonoma clean no rust or rot. Was a crank no start deal. Started tearing into it. Turns out to be a bad headgasket. Pulled it apart checked the head turns out to be to out of spec to resurface. So that’s where I am with the truck now. Any recommendations for where to get a reman head from ? Thanks guys I’ll post some pictures. Hopefully I can get it on the road soon so I can start doing other stuff to it lol.
post #2 of 13 Old 05-13-2019, 06:55 PM Thread Starter
A few pictures
ID:	316747   Click image for larger version
ID:	316751   Click image for larger version
post #3 of 13 Old 05-13-2019, 07:30 PM
time to get cereal
Re: 98 Sonoma project
I got mine from Cylinder Heads International: https://www.headsonly.com/
If you want something upgraded from stock, check http://www.chevycavalierworld.com
post #4 of 13 Old 05-14-2019, 07:11 PM Thread Starter
Thanks for the info!!
post #5 of 13 Old 05-14-2019, 07:17 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Man are you gonna be disappointed with that 2.2 if you where used to driving a 4.3 truck!
Looks sharp tho!
oldeerslayer likes this.
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #6 of 13 Old 05-15-2019, 11:35 AM Thread Starter
Thank you for the info!
post #7 of 13 Old 05-15-2019, 11:37 AM Thread Starter
Yes I am lol just trying to get it on the road drive it around a little while I save up and collect parts for a v8 swap
post #8 of 13 Old 05-15-2019, 11:43 AM Thread Starter
Surprisingly the body is clean and frame. Prefect candidate for a nice little project street / track toy.
post #9 of 13 Old 06-02-2019, 09:59 PM Thread Starter
Alright guys got a remained head from rock auto. Plus a few other parts to finish up the job. Everything went back together beautifully. Bleed the coolant system. Went to push the clutch in won’t let put it into gear. Clutch won’t disengage. Checked the clutch master dry. Looks like the slave is leaking have a nice mess around the bell housing. Tired every bleeding process out there to get it to work no luck. Have to pull the trans now. That’s where I am now. Almost ready for the road lol
post #10 of 13 Old 06-04-2019, 09:51 AM Thread Starter
Any good tips on bleeding the clutch system ?
post #11 of 13 Old 06-04-2019, 10:09 AM
B4U Task Force
Rhotpursuit's Avatar
There are a lot of threads lately on clutch bleeding. IIRC, you can get both master, slave, and lines, all assembled and pre bled for under $100.
Edit...$116 from Rockauto.
https://www.rockauto.com/en/moreinfo...sn=437&jsn=437
Apple Red 96 SS
post #12 of 13 Old 06-04-2019, 08:25 PM
BravadaX's Avatar
Don’t bleed it like brakes...let it gravity bleed. Cap off,bleeder open.keeping it full the whole time...do not touch the pedal. once it’s gravity bled through,tighten the bleeder,then Pump it gently in short pumps about half way down,not all the way to the floor,..release it,then gravity bleed..do not open the bleeder open when you push the pedal down! A couple of gravity bleeds is all it should need..,then with the bleeder tight you can travel it to the floor,and test clutch operation.
I pull these trucks apart regularly..this is how I do it. If you bleed it like brakes it’ll never feel right,and you risk damaging the clutch master by pushing it’s piston past it’s normal area of travel,and damaging an internal seal...that was a common mistake on old Honda’s back in the day after replacing their crappy rear calipers,..common mistake on these trucks when replacing the clutch as well.
BravadaX is offline
post #13 of 13 Old 06-04-2019, 08:59 PM Thread Starter
Awesome thanks for the tips guys !!
Similar Threads
New project 92 sonoma Evonik Member Projects 30 05-01-2019 01:48 PM
Reg Cab 2WD Manual S10 / Sonoma Project reviewer S10 / Sonoma 2 12-25-2016 12:22 PM
91 sonoma extcab gt clone project transam197781 S10 / S15 11 05-20-2016 01:11 PM
