86' s15 ext cab v8 corner carver, 56k beware - S-10 Forum
 1Likes
post #1 of 527 Old 08-14-2011, 10:58 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
User is: hi_im_sean is offline
i just noticed the projects section lol, it should be at the top of the page, not the bottom. i already have this in the v8 section, but this seems more appropriate, so ill be updating it here now.
i am keeping a photo journal on photo bucket that can be found here:
http://s222.photobucket.com/albums/d...sean/s15%20v8/
i pulled the motor/trans out about 3 years ago (2.8/700r4), was driving it around until then, lifted with 32x11.50s. built the motor about a 1.5 year ago and its been sitting on the stand, poor thing. the tranny is from someone who owed my dad a favor, just a rebuilt late model 700r4, i have a corvette servo for it and a tci lockup kit, nothing fancy there. pounded the firewall in when i yanked the motor(probably not enough), removed my horrible body lift from the days of being 17, and installed the larger fuel tank (20 gal?).
recently: i got the whole suspension from a 96, including front brakes, but no rear axle for $100, a prothane full kit, some por-15, chassis black and caliper paint, and all the prep chemicals. i needed stock spindles and shackles because it has 2" lift spindles and shackles id like to revert to stock, so i thought $100 was a steal, and i can take my time to paint the parts and not have the truck on jack stands. i have been working on the cluster, and wiring of the whole truck, im an electronics nut, so that part was fun for me. i cut up the evap housing for valve cover clearance. i had removed it a long time ago, maybe 2 years, i had the evap core on the front seat for all of that time, well, it got stolen recntly. went to reassemble, and it was gone! still waiting on my ebay replacement.
i dont want to hear it from you 305 stroker haters, but:
30 over stroked 305=335
vortec L31 heads in stock form, the 1.94 version cast# 12558062
94 truck block, kb hyperutectics, 9.3:1
full arp
comp 256h-12 w/ magnum roller tips 1.52:1
mallory unilite with mech and vacuum advance, it was free, was going to use hei
holley 4160
patriot shorties
blah blah blah, ask if you need to know more, nothing crazy just a nice little torqy stroker
old pic, but its fully dressed now, just need to install the oil filter adapter and shes ready to drop in
stroker clearancing
most of an s10 suspension
the rest, with a tranny
97 grand cherokee steering shaft, the colum end doesnt fit, i didnt read the jeep steering shaft thread well enough. i have a 92 cherokee shaft now as well i need to get a picture of it, its a direct replacement for the first gen s10/15. the joints and rubber damper are worn out to bad to use though, but the shaft material will work as a key to make that beautiful grand cherokee shaft work with first gen s10 colum, more on that when i attempt it.
naked control arms, proper use of sockets and extensions, and stuborn bushings
evap housing jtr valve cover clearance thingy, used rivets and some really good adhesive used in motorcyle case halves to seal it all up.
i think we all know what that is
everything unnecessary removed, and the rest labeled and separated, got a huge convoluted tubing kit, oh joy
decided to clean the cowl, i recommend you do this, the driver side wasnt draining, caught it in time, beside you find some neat stuff sometimes. i found some old bottle caps and a nice pen.
what a champ, orginal 2.8 and 700r4, seriously
teaser
street rod artic whites
exploding cluster
whats that diamond plate for?
made a template to see how it would all fit, once i decided it would all be symmetrical i came up with some mathematical assistance
cut out old gauge faces
thats what its for...
milling off the diamonds around the perimeter so the bezel sits flush, and clearnace for the column. the joys of owning a mill.
boring the holes
gauges mounted, i have the holes for the turn signals drilled now, and the turn signal lenses cut out, need to mount them and update pics
i may use the brake and brights lenses as well, may not
more to come....
post #2 of 527 Old 08-14-2011, 10:59 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: 86' s15 ext cab v8 corner carver, 56k beware
what it used to look like. i didnt have a digi cam back then, so i am taking a pic of a pic.
went camping in nov up north, snowy. had 32x11.50-15's 2WD, was kind of pointless. 3" body lift, 3/2 spindle/shackle kit, heavily trimmed fenders and inner wells. the fenders will get replaced eventually along with the wells, need to get the dam thing running first.
how it looks 10 minutes ago
got my $48 ebay evap core
installed with the moded cover
check these connections, chances are they are nasty
removing as much wiring and lines as i can to por15 the frame
removed some of the suspension to check it out, it all looks reusable, i am going to replace the ball joints and just replace the boots on the rest
my core for a zq8 box
these came with my $100 suspension find. all 4 are in working condition, are they anything good?
this will be fun...
thats sarcasm by the way
removed the speedo cable, im using an electric sender, and an auto calibrating gauge. free to anyone who needs it, just paying shipping.
i plan on getting the cluster done today, hopefully ill gte some more pics of that
post #3 of 527 Old 08-14-2011, 11:00 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
entered my combo in dyno2003 vs a stock vortec 305 that would have come in a half-ton., didnt quite reach the 1000hp mark
gauge cluster is done, im happy with it.
lamps lit, the brights indicator looks a little dim, but im fine with that as its the only one that would remain on for extended periods and i dont want it glaring at me.
8hrs of hard labor to get these clean, still needs a little more. i wish i had a sand blaster.
mic-ing rotors for runout, theyre pretty dam straight
i discovered that i was missing my x-member, so i went to the junk yard to get a new one and ended up getting a bunch of goodies. some interior pieces that were broken, some ac vents that dont require a "shim" in the form of a biz card to stay pointed at you, vacuum canister,the smaller battery tray from a 4.3l blazer, rubber mounts for the radiator, and some small trim stuff
finally found one of these
jeep steering shafts
pressing the bushing in
this was interesting
por15
decided to use their caliper paint. it loosk good, but i wont use it again, its really hard to use with a brush, and it only come is a can. it goes on sooo thick and doesnt flow that well, so its hard to get a nice finish and not have runs, takes a few coats and a lot of labor, but it goes a long way. id say the little can will do 4-6 calipers
2nd coat, its drying right now, will need at least 1 more
post #4 of 527 Old 08-14-2011, 11:01 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
im diggin the chassis coat.
3rd coat on the calipers dried and hardware reinstalled
finally made the plug wires, plugged up some holes in the block and intake, still need a water pump fitting, timing flag, air filter and water neck to top it off, need an extension for my oil press sender, it hits the manifold. i also need to find a good way to attach a return srping, the BTO TV kit blocks off the spring eye in the holley linkage. i test fitted the accessories but didnt leave em on for a pic, that engine stand is getting worked out, and it scares me, but it looked great!
BTO TV and throttle cable kit. made a bushing to adpat the ball stud fromt he lokar throttle cable kit to the gaping hole in the linkage. check out the adjustable
TV cam.
installed my vette servo, speedo gears and sender
post #5 of 527 Old 08-14-2011, 11:03 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
the timing tab didnt fit
all better
wiring pic
i broke out the ruler and calipers and measured all my springs to figure out what i got. just posting this info in case someone else can use it.
86 extended cab 2.8 coils- equivelant to the moog 5662
http://www.moog-suspension-parts.com...prod=MOOG-5662
actual measurements were: 0.747" coil diamter, 7 coils, couldnt measure anything else, they are installed on the truck. 748lb/in spring with 1690lbs load capacity. must have only come one the ext cabs or blazer with a v6 from what i can tell. its the stiffest stock gbody spring gm used if im not mistaken.
96 standard cab 4.3 coils- equivelant to the moog 5664
http://www.moog-suspension-parts.com...prod=MOOG-5664
actual measurements were: 0.745" coil diamter, 7 coils, free height right at 13". 707lb/in spring with 1863 lbs load capacity, interesting that this srping holds more than the 5662
leafs- both leafs packs have 3 leafs plus an overload, they are both 2.5" wide and have a pad thickness of 1 5/8". it was hard to measure on the truck, so the ext cab pad thickness might be 1 1/2". either way according to the spring king, they are the same rate, the 1350lb versions.
1rst gen
http://thesuspensionking.com/catalog...jimmy_rear.php
2nd gen
the only differnce is that the 96 spring has 3/4" more arch and the ext cab spring's overload leaf is arched whereas the stnd cab overload leaf is flat. the arched overload comes into play sooner in the suspension stroke and would be harsher, thats how they support the extra weight of the extended cab, thanks for the harsh ride gm.
im still not sure which springs im going to use, but theres all the info. my goal is to make the truck sit level with my 2" drop spindles and one of those 2 coils along with one of those 2 leaf packs with the overlaod and maybe the 3rd leaf removed. any one have any input?
post #6 of 527 Old 08-14-2011, 11:03 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
i got the speedway control arms, all that work to the stock ones for nothing. i read a lot of posts where people said they wernt symmetrical and that you couldnt use 2 right sides, despite people trying to tell them otherwise. i couldnt find a pic that showed that the ball joint mounting plate was welded in the center of the tubing, a few people said they welded the plate to the top or bottom of the tubing, making the rights and lefts different. heres some pics that i hope will end all that. got the zq8 bumbstops and proforged tall bjs as well.
mouting plate centered, tubing straight, symmetrical
crosshaft flanges centered, symmetrical
tall bj
ZQ8 bumpstops vs stock
some info about the control arms that i couldnt find, maybe someone can use in the future: the aluminum crosshafts ride directly on the steel tubing, they are circliped and put togther then wleded. you cannot remove the crosshaft. the shaft spins easily by hand and has no slop... yet some people said they look like shit and the welds suck. i think the welds are great quality, the paint is a little cheap and will flake off easily it seems. theyre $42 each, nuff said
post #7 of 527 Old 08-14-2011, 11:04 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
heres a pic of the aforementioned key i made:
and what ive been doing lately with the rear suspension.
chevy flared the stock bushings, i had to get medieval on them with a grinder, chisel and bfh.
and of course, when does a leaf bolt actually come out without a fuss? i tried to be nice
goodbye 3rd leaf
so it turns out there are some slight differences between some leaf springs on the s10s, even if they are the same rate, size, etc. some of the later model springs have a 2" front spring eye. every s10 from 82 to 96 used 1.5" eyes front and rear. of course you learn these thing too late. energy is the only supplier for the 2" bushing and i have to spend $80 just to get 4 pieces of poly. i think not. made some adapters on the ol lathe.
making my own grease able bolts
i bought a cobalt bit for this project, well it gave out by the 9th out of 12 holes, i completely obliterated it, but it didnt snap. so i figured hell, i can finish the 2 and a half holes i have left with my HF tin coated drill bits. it snapped almost instanly, was a brand new bit. cobalt or better only with grade 8 bolts! thats a ruined bolt, i have 1 extra luckily.
disassembled leaf. going to try to have em all togethr and painted/bushed by the weekend
post #8 of 527 Old 08-14-2011, 02:47 PM
needs a cheeseburger
tohoopty's Avatar
User is: tohoopty is offline
looking real good.keep it up
tohoopty is offline
post #9 of 527 Old 08-14-2011, 03:50 PM
00 Xtreme
PTXtreme's Avatar
User is: PTXtreme is offline
incredible attention to detail!
PTXtreme is offline
post #10 of 527 Old 08-14-2011, 04:26 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
thanks guys!
been getting the leafs cleaned and back together all morning, made 3.5 degree angle blocks last night on the mill. pics in a few
post #11 of 527 Old 08-15-2011, 12:02 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
machining of the angle blocks
roughing to size
flipped and then the angle is set
holes drilled and counter sunk
pressed the adapters in, they went in nice and tight, i went 0.030" oversize
my assembly rig, the clamps were to get some of the arch out of the spring so there wasnt a gap between it and the angle block.
painted, bushed, greased, done
post #12 of 527 Old 08-15-2011, 12:02 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
double post
post #13 of 527 Old 08-15-2011, 01:35 AM
84blaze's Avatar
User is: 84blaze is offline
84blaze is offline
post #14 of 527 Old 08-16-2011, 11:41 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
im going to try and get it into the garage to work on it this weekend. anyone ever taken the bed off with an engine crane?
had to go get some of these so i could move my truck around.
i also cleaned up the firewall breakout right in front of the fuse panel, and decoded it. i made a pretty drawing for everyone, hopefully someone will get some use out of it. schematics as well. (this stuff applies to an 86ish s15 truck with a 2.8 and 700r4, if you have a blazer, a 4cylinder, or 88 and newer, a lot of colors and wiring changes, 2nd gen isnt even close)
the colors correspond to the actual wire color in my truck, a few were different from what the schematic shows.
further explanation of each wire
A1-TCC 12V. torque converter control. this is 12V lockup for the TC, it comes from your brake switch, and goes to the tranny.
A2- alternator indicator, brown wire from the alternator to the alternator indicator in the cluster
A3- wiper motor low speed
B1- TCC grnd. goes to the ECM and the ALDL (cruise component) to complete the circuit and put the TC into lockup
B2- 12V ignition switched, from ign. fuse to 510ohm resistor for alternator excitation, also goes to the contacts of the AC relay to power the compressor clutch, and to a random oil pressure switch on the v6 models
B3- wiper motor park switch
C1- +coil, coil power, large pink wire directly from the ignition switch
C2- ecm 12V, ignition switched 12V from ECM1 fuse, main ecm power
D1- Alt. fuse, the large red wire to the alternator with the fusable link, powers most of the interior of the truck
D2- oil pressure, comes from the oil pressure gauge, goes to one of the oil pressure senders
E1-fuel pump relay, this is just a signal wire to the ecm for the fuel pump and to serve as a junction block.
E2- water temp, comes from the water temp gauge, goes to a temp sender
F1-main 12V, large red. goes to the firewall mounted distribution post that the alternator connects to, supplies power to the fuse panel and most of the truck
F2- CEL, 2 wires connect here, a green/wht and a yellow. one goes to the "oil" relay, and the other to a water temp switch, either one will set off the check gauges lamp.
G1- ECM B, constant power to the ecm from the fuse panel
G3- wiper motor park switch, the other one
H1- starter crank, 12V from the ignition switch in crank position to the starter solenoid
H2- ecm crank, crank signal to the ecm
H3- wiper motor high speed
L4- brake pressure switch, comes from the brake lamp, goes to the pressure switch located on the top of the master cylinder
L5- head lights, forgot to see which were high and low beams
M5- head lights, other
N4- front park lights
N6- right front turn signal
O4- windshield washer motor
P5- horn
P6- left front turn signal
1-6 are missing from the schematic, as are a few of the above, i just labeled them for reference. the 1-6 connector harness goes to the rear of the truck
1- left rear turn signal
2- fuel gauge, fuel sender to the gauge
3- reverse lights
4- right rear turn signal
5- fuel pump 12V, internally connects to E1, so it really comes from the fuel pump relay contact
6- running and licence plate lamps
enjoy
post #15 of 527 Old 08-19-2011, 10:22 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
removed my wheel spacers today, had em on there to help fit the 32x11.50s years ago. for sale, $100 for the 4, plus shipping
have 14 3" body lift blocks and 8 of the bolts as well if anyone is interested, $30
post #16 of 527 Old 08-19-2011, 11:09 PM
GM
GM's Avatar
User is: GM is offline
Send a message via AIM to GM
Very cool build so far man. Everything is looking great.
GM is offline
post #17 of 527 Old 08-20-2011, 01:38 PM
Square-body crazy
J@mes's Avatar
User is: [email protected] is offline
Send a message via AIM to J@mes Send a message via MSN to J@mes Send a message via Yahoo to J@mes
Holy crap. I wish i had your garage. I really like the gauge setup
'91 s10 pickup/4.3 v6/5 speed (Fully bagged on 20/22's. Just a stock truck.. ) <---- My sunday afternoon cruiser
'93 s10 pickup/2.8 v6/5 speed/3.42 gears (Lifted 3/2 1/4" on 235/75/15's. Additional suspension soon,and 2" body. (Traded )
My build thread
'92 s10 pickup/2.5 I4/5 speed/No power features (Future daily)
post #18 of 527 Old 08-20-2011, 07:39 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
thanks guys
post #19 of 527 Old 08-20-2011, 08:44 PM
User is: SBBlazer is offline
Excellant progress, love the attention to detail. Do you have any info on the electronic speedo adaptor you're using on the trans?
SBBlazer is offline
post #20 of 527 Old 08-20-2011, 09:26 PM
benster's Avatar
User is: benster is offline
nice project and as everyone said, very good attention to details. from your title i'm guessing you're planning on making a race track truck. keep at it, my project is pretty similar to your except it doesn't look as good .
for your question about the adapter, autometer website has a super good explanation for it. it's pretty expensive too at about 130$, plus 250 more or less for the speedo.
1983 sonoma GT
355 SBC 300-325HP, th350 2600 stall
8.5" rear, 3.08 and zq8 power steering
85 camaro RS rims, 15"....upgrade!!
"if you like how your truck looks, why care what others think about it?"
benster is offline
post #21 of 527 Old 08-20-2011, 09:42 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
not sure what exactly you want to know, but its a 16 pulse per rev hall effect encoder (magnetically triggered switch basically), 7/8-18 thread, should fit any gm OD tranny, definately 700 and 200r4. they come with a square drive key that mimics the speedo cable and just plugs into the speedo gears exactly like the cable does. they have em for any tranny really. the gauge kit came with it, summit carries a few different flavors for fords and mopars as well.
http://www.summitracing.com/parts/AT...s/?prefilter=0
thanks for all the comments, im glad someone beside me notices the details
post #22 of 527 Old 08-20-2011, 09:46 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
it will be on the road course at my local tracks but it will be street legal as well. kinda of the all in one truck: dirt bike and camping hauler, spare DD, weekend race truck. i need to get some 5 points and relocate the battery, i know a guy who used to flag for nasa, hes trying to straighten me out so i pass tech the first time.
summit is repackaging the autometer senders, or something very close for $60 (i had both in my hand at one point, sent one back), as long as you dont need the extension for mechanical speedo with data acquisition.
post #23 of 527 Old 08-21-2011, 12:27 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
a little more electrical decoding for tonight
this is the cluster connector and its connections
and more explanations:
the numbers on the diagram correspond to what is on the connector itself, see the below pic. the wire colors, again, are what are actually in my truck, 2 were different from the schematic, number 11 is brwn/wht, the schematic just says plain brown, and 5 is wht/grn, schematic just says dark green.
the number at the end of each description in the pic is the number that the wire corresponds to on the schematics posted above, of course they are different, thanks gm.
1- switched 12V from IGN fuse, only powers the gas gauge
2- oil pressure gauge, from oil sender, through firewall connection D2
3- switched 12V from IGN fuse, powers h20, oil pressure and voltage gauges only
4- water temp gauge, from water temp sensor, i think this comes from the ecm through the dash, or through a firewall connector i havnt looked at yet, it may also just tie in with the check gauges indicator, which is run off a water temp sensor
5- right turn signal indicator, comes from the column switch
6- high beam indicator, come from the brights switch
7- alternator/battery indicator, come from the alternator, through firewall connection A2
8- brake indicator, 2 wires, one comes from the pressure switch on the master through firewall connection L4, the other comes from the parking/E brake.
9- check gauges indicator, from water temp switch, through
10- up shift indicator, from ecm, manual tranny only
11- service engine soon, from ecm
12- 12V supply for all ground switched indicators, which includes: SES, up shift, check gauges, brake, and battery
13- N/C
14- cluster illumination dimmer voltage, from dimmer control
15- seat belt indicator
16- ground
17- left turn signal indicator, comes from the column switch
18- fuel level, from the sending unit in the tank, through firewall connection 2
post #24 of 527 Old 08-21-2011, 05:24 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
cleaned the interior and cleaned the bed, hosed it out, scrubbed it clean. it was disgusting, my dad used it as a trash can for a year while it sat at our old shop, then it sat for 2 more years, nice. removed all the bed bolts, then i realized i had no place to put the bed, so i started on the front end instead,lol.
got the whole front end apart this morning, found a bent bumper bracket, explains the bumper attitude. fixed that and started cleaning the frame.
ground out the original weld, bent back and rewelded the bracket
cleaning the frame
post #25 of 527 Old 08-24-2011, 08:56 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
at v8s10.org we are having a debate on shorties vs long tubes. i already have shorties and they dont like those over there. opinions?
i got my shift kit in today, i really should be doing the frame but couldnt help myself, its too hot anyway.
transgo 700-2-3, installing in auto mode, also have the tci lockup kit and tvmadeez sping to install
improvising, clearing out the brake master and lines for removal, more frame brushing, i smelled rust for hours after a wire brush session
post #26 of 527 Old 08-24-2011, 10:58 PM
Wondersmith
StirFrey's Avatar
User is: StirFrey is offline
looks great dood! keep up the good work, ill definitely be following this
It isn't a death wish. It's about living.
-95 Noma (see thread >) - 2.2 5-speed https://www.s10forum.com/forum/f30/pr...sinoma-433674/
StirFrey is offline
post #27 of 527 Old 08-25-2011, 01:11 AM
Flame It ALL
Stewzer55's Avatar
User is: Stewzer55 is offline
Sweet build, Like StirFrey, I too will be watching this.
1999 Chevrolet S10 4.3 5 Speed Longbed
1992 Oldsmobile Custom Cruiser Save the Whales
1988 Chevrolet R30 SRW Cab and Chassis Project Ellie May
post #28 of 527 Old 08-25-2011, 08:38 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
thanks guys.
i discovered last night i dont have the right size int/rev valve, will have to order, tranny is on hold until it comes in and its taking up my bench space! 2nd part from the left in the 2nd to last pic above.
post #29 of 527 Old 08-28-2011, 02:17 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
this morning i got the reprogramming kit installed, TCI lockup kit installed, and BTO TV spring.
i used the transgo 700-2-3 kit, i hear its the best kit for the 700r4, but the directions suck and are really vague, and you dont use like half the kit, i dont like paying for things i dont need. either way i figured it out, would have been a peice of cake if the instructions werent so mysterious, i didnt install the orange 3-4 spring.
modified separator plate, its funny about half of the holes were already enlarged by someone before me, but it didnt have any sort of kit installed
new and old TV
lock up kit
various plugs
filter is installed,i just need to install the int/rev valve when it gets here and bolt her up
post #30 of 527 Old 09-04-2011, 02:58 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
this weeks progress-
i trimmed the tranny ears the other night and made some room for the bed today, started on the rear of the frame.
also drew up my TCC wiring
solo bed removal
tucked away, my garage is soooo full
removing the rear bump stops, i plan to replace them with some modified zq8 front bump stops that mount with a stud
post #31 of 527 Old 09-04-2011, 03:13 PM
FirstPiece's Avatar
User is: FirstPiece is offline
Man im loving that gauge cluster, Wish I could make a setup like that, but I have noway near the knowledge and equipment.
Trucks looking good and I love how detailed you are with your posts, cant wait to see more.
post #32 of 527 Old 09-04-2011, 06:07 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
thanks firstpiece. everyone comments on the cluster, its funny, i wonder if id get any responses if i didnt do it that way
got started wire wheeling the rear, removed the tank, i sanded down the welds from the bump stop brackets, then it got too hot out and i cleaned up and stopped.
post #33 of 527 Old 09-04-2011, 09:19 PM
FirstPiece's Avatar
Lol well its probably cause the only real way to spruce up the stock cluster without chopping it up like you did, is just some white lay over. I bet if you started selling them youd have a big market lol.
post #34 of 527 Old 09-04-2011, 09:32 PM
FuhReelChevy's Avatar
User is: FuhReelChevy is offline
I would definetly pay to have a cluster like that in my 96 dime. Very nice!
Work In Progress..
https://www.s10forum.com/forum/f30/my-gina-477141/
Originally Posted by Hamstar View Post
Growing up I drove beaters... I was ashamed my first day of high school until this guy picked on my ride and I bet him $20 that I could do stuff with my car that he couldn't.
He took me up on it, and I keyed mine.
post #35 of 527 Old 09-04-2011, 10:37 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
and thats exactly why i did it, i had no choice! the stock cluster sucks
but like i said earlier, it was a real pita the way i did it, on a mill. a production piece would be stamped or punched out with a stamping machine.
post #36 of 527 Old 09-04-2011, 11:06 PM
98layinframe's Avatar
User is: 98layinframe is offline
Send a message via AIM to 98layinframe
definitely interested to see this build! Looks good so far, so jealous of the lack of rust you boys out west have to deal with.
post #37 of 527 Old 09-04-2011, 11:08 PM
Blue-X
yz85608's Avatar
User is: yz85608 is offline
Is that a mini cnc mill?
Shawn
Blue Xtreme
Xtremely Stock
yz85608 is offline
post #38 of 527 Old 09-05-2011, 12:00 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
ive worked on a few "east" cars, you knew one when it came in at the shop i worked at, all i have to say is **** that.
the frame is just surface rust, comes right off with a wire brush, with the wire wheel on the grinder you get to metal instantly, the body has no rust at all. im the 2nd owner of this truck, its never left the state.
post #39 of 527 Old 09-05-2011, 12:07 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
its not cnc, although i plan on converting it to cnc eventually. it will require making motor mounts, attaching motors and some motor controllers, and hooking up a computer through a breakout board... can only afford one project at a time. as far as mini, id say its the step up from mini, the minis you can pick up and move by yourself and are tiny, mine weighs 300lbs, and i use the engine crane. but yes it is small, my working envelope is about 18x7". the big floor standing models that weigh 3000lbs have a 30x12 ish envelope and a true mini is about 12x5 for comparison.
http://www.grizzly.com/products/Dril...th-Stand/G0704
post #40 of 527 Old 09-05-2011, 12:50 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
heres a video of the diamond plate panel being created on the mill
post #41 of 527 Old 09-21-2011, 06:29 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
havnt got a lot done lately. have been to busy doing this instead:
i had a relapse lol
got sick this weekend as well so only got a little done during last week.
got everything off the frame, and i mean everything except for the fuel lines. anyone remove em before? they look like a pain to pull out and an even bigger pain to re install where they come through the boxed sections of the frame, but they had to get in there somehow.
rear brake line in a safe spot for now
rear harness all coiled up
i also replaced the fuel pump with a new one just to be safe, the original one has sat for years, and for $40, ill just play it safe. i had to adapt the sending unit that came with the autometer gauges to the stock pump assy because the ohm range is different. auto meter didnt have a kit that has the 90/0 ohm gauge /sender that would have worked with the stock sender, and my stock sender was bad anyway.
the "bolt" holes for the stock sender and autometer sender almost line up perfectly
stock sender removed, i had to notch the bottom right hole on the mounting plate of the fuel pump assy to get the autometer sender to mount and to get the right angle on it, since the mounting point isnt centered in the tank, and so i get proper readings on my gauge.
all done
post #42 of 527 Old 09-21-2011, 06:43 PM
littledevil4802's Avatar
User is: littledevil4802 is offline
Send a message via AIM to littledevil4802
looks good. I'll be watching this one.
92 reg. cab-lowered 5/4-sold
95 std cab- bagged about to be bodied
www.airedup.com
post #43 of 527 Old 09-21-2011, 09:35 PM
suicide_star's Avatar
User is: suicide_star is offline
Wow. This is an awesome build and your posts/pics are so detailed and even helpful with my project. Thanks for being so thorough and your project looks like it's going to turn out awesome.
post #44 of 527 Old 09-22-2011, 08:33 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
thanks guys. i wrote this so that others can get something out of it or maybe even reproduce what ive done. glad i could help.
post #45 of 527 Old 09-22-2011, 01:45 PM
Lifted 2wd & Bodied 4x4
layinbody31's Avatar
GREAT attention to detail which makes this an amazing build so far
I was lovin that pic of all the dirtbike tires in the bed, and I'm glad you posted up the riding video as well! You're a man after my own heart... minitrucks, dirtbikes, and making your own parts with mills/lathes/etc. I just wish one of my builds could be on this caliber someday!
Keep it up man!
autoxs10 likes this.
layinbody31 is offline
post #46 of 527 Old 09-22-2011, 09:44 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
thanks for the comps layin
the tires were all my worn out ones from the last year. its a huge fine if you try to throw them in the trash, have to take them to a special recycle place. so i save em up till i have enough to make a trip.
plenty more video too, check out my youtube channel
http://www.youtube.com/user/dsrtrdr?feature=mhee
and if you want to get crazy i have at least 100 videos here
http://contour.com/users/hi_im_sean
post #47 of 527 Old 09-22-2011, 09:53 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
had to share this, hot lap at the mx track
http://contour.com/stories/destry-is...raiser-at-gs-9
post #48 of 527 Old 09-30-2011, 05:19 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
i am going the short water pump route, but decided to make my own pulley.
this gives about 2" more clearance between the pump and radiator for the electric fans and for servicing
blank on the left orriginal pulley for long pump on the right, power tool underneath
and ive decided im going to install a "5 point" roll bar. im going to buy an 8 point kit and make it my way. i will use plates as flanges between the frame and body so i can remove he body still, and i wont be going into the bed. might not meet regs, but i will never go to 11.49, not in this truck, its more for the wifes worrying and possible autocross.
started gutting, notice all of that rust that doesnt exist, ill remind you that its an 86
post #49 of 527 Old 10-03-2011, 12:49 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
got the pulley done this morning
inside bore finished
flipped around to turn and face
quick turning vid
threw it on the mill, drilled the holes, done, still needs paint
post #50 of 527 Old 10-04-2011, 12:42 PM
Very nice work! I'm jealous of your lathe
