03 noma - Page 3 - S-10 Forum
 2Likes
post #101 of 121 Old 01-04-2019, 09:17 PM Thread Starter
Tossing my bowling balls
killerc998's Avatar
User is: killerc998 is offline
Been awhile since I posted here. Still messing with the truck. Got a nfamous 5 link to go on with new viair 444c compressors. Also came in to a new motor for the truck. It's a 4.8l out of a 2001 Silverado harness, all accessories, ecu. I got the headers (speed engineering, motor mounts (dirty dingo), f body oil pan (that thing is heavy), the windage tray, dip stick/tube, oil pick up.
<------When I got money. When I got no money----->
03 noma
LS Swap Questions
post #102 of 121 Old 03-30-2019, 11:05 PM Thread Starter
killerc998's Avatar
Did a little work to truck. 03 noma-p_20190329_221148_vhdr_auto_1554001202086.jpg old set up/static rear.03 noma-p_20190330_165940_vhdr_auto_1554001259770.jpg gas tank cross member mounted, and rear link mount/rear cross member mounted, 03 noma-p_20190330_154507_vhdr_auto_1554001348701.jpg lifted front gas tank mount,03 noma-p_20190329_221128_vhdr_auto_1554001402526.jpg bed and camper shell in front yard, making house look like a red necks place.
03 noma
LS Swap Questions
post #103 of 121 Old 03-30-2019, 11:08 PM Thread Starter
killerc998's Avatar
Parts to the new air ride.03 noma-p_20190329_225258_vhdr_auto_1554001636190.jpg03 noma-p_20190329_224959_vhdr_auto_1554001658841.jpg
03 noma
LS Swap Questions
post #104 of 121 Old 03-31-2019, 09:21 PM Thread Starter
killerc998's Avatar
Did a little more work today, got upper bag mount mounted. Had to cut spare tire/shock mount cross member out. When I was test fitting/measuring to find upper bag mount location, I found the bolts sent for the bushings wouldn't fit. Keith over at Nfamus is sending the correct stuff. They had a run of bad bushing sleeves sent to them. Got leafs pulled off, and mounts on rear end cut off and cleaned. 03 noma-p_20190331_103655_vhdr_auto_1554081664738.jpg03 noma-p_20190331_160416_vhdr_auto_1554081632680.jpg
03 noma
LS Swap Questions
post #105 of 121 Old 04-02-2019, 08:06 AM Thread Starter
killerc998's Avatar
Pulled interior, old air suspension wiring, right inner fender, and a.c. Fan box. Got the heater only fan box installed. Will be doing sheet metal fenders also. Might have to relocate batteries to the bed.03 noma-p_20190401_215255_vhdr_auto_1554206555723.jpg03 noma-p_20190401_215234_vhdr_auto_1554206612966.jpg03 noma-p_20190401_215222_vhdr_auto_1554206648338.jpg03 noma-p_20190401_222234_vhdr_auto_1554206685247.jpg
03 noma
LS Swap Questions
post #106 of 121 Old 04-03-2019, 10:31 PM Thread Starter
killerc998's Avatar
No real up date. But tack welded supports on the end of frame. Also replaced stock bolts from Nfamus cuz they seem short. I like 3 threads showing after tightened.03 noma-p_20190403_211745_vhdr_auto_1554344887077.jpg03 noma-p_20190403_211739_vhdr_auto_1554344929246.jpg03 noma-p_20190403_211802_vhdr_auto_1554344971196.jpg stock bolt.03 noma-p_20190403_211813_vhdr_auto_1554345028196.jpg replacement bolt. It's a little long.
03 noma
LS Swap Questions
post #107 of 121 Old 04-04-2019, 09:38 PM Thread Starter
killerc998's Avatar
Got the rear end cleaned and pinion angle set. No pic of angle set. But transmission side is 2, rear end is -2 03 noma-p_20190404_134113_vhdr_auto_1554428030183.jpg
Got rear notch tacked in. Will get better pics posted tomorrow of notch.03 noma-imagejpeg_1_1554428426056.jpg
03 noma
LS Swap Questions
post #108 of 121 Old 04-05-2019, 07:36 AM
nfamus10's Avatar
User is: nfamus10 is offline
Re: 03 noma
Few more pics I snapped. Hopefully we can get the notches fully welded this weekend.
<<<<<<<<<<<Partners in Crime Inc.>>>>>>>>>>>>>>>>>>>
https://www.s10forum.com/forum/f30/pa...me-inc-795393/
$$$$$$$$$$$Project El Cheapo$$$$$$$$$$$$$$$
https://www.s10forum.com/forum/f30/ch...6-dime-500352/
It will get done when it gets done...
---body drop thread---
https://www.s10forum.com/forum/showthread.php?t=245523
nfamus10 is offline
post #109 of 121 Old 04-15-2019, 09:08 PM Thread Starter
killerc998's Avatar
Got a little more work done. The sleeves fur the bushings came in, so got the 5 link welded in. Tomorrow if I get off in time going to cut in to the cab for drive shaft. And weld the notch to spot cut out. Need to dehump the lower control arm a bit more. Bags rub a little. 03 noma-p_20190415_155356_vhdr_auto_1555376788864.jpg old sleeve not fitting bolt. new sleeves installed, bolt fits.03 noma-p_20190415_155404_vhdr_auto_1555376846180.jpg 03 noma-p_20190415_155314_vhdr_auto_1555376818046.jpg03 noma-p_20190412_162953_vhdr_auto_1555376733641.jpg03 noma-p_20190415_160322_vhdr_auto_1555376889835.jpg
03 noma
LS Swap Questions
post #110 of 121 Old 04-15-2019, 09:12 PM Thread Starter
killerc998's Avatar
03 noma-p_20190415_164749_vhdr_auto_1555376950795.jpg grants welds getting better. 03 noma-p_20190415_155305_vhdr_auto_1555376981589.jpg Grant doing some welding. 03 noma-p_20190415_181046_vhdr_auto_1555377019999.jpg03 noma-p_20190415_181527_vhdr_auto_1555377063656.jpg03 noma-p_20190415_181547_vhdr_auto_1555377094580.jpg
03 noma
LS Swap Questions
post #111 of 121 Old 04-17-2019, 10:21 AM Thread Starter
killerc998's Avatar
A little more stuff. Notched lower link bar mounts. Use a step not to get the rounded tom the cutoff wheel and flap disk. Got bags mocked in to see how far it will lay. Got driveshaft clearance cuts done in cab. Ran out of welding wire. Grabbing more after work.03 noma-p_20190416_155523_vhdr_auto_1555510530869.jpg03 noma-p_20190416_160806_vhdr_auto_1555510632064.jpg03 noma-p_20190416_160811_vhdr_auto_1555510681858.jpg03 noma-p_20190416_161307_vhdr_auto_1555510731160.jpg03 noma-p_20190416_155528_vhdr_auto_1555510819119.jpg
03 noma
LS Swap Questions
post #112 of 121 Old 04-17-2019, 10:24 AM Thread Starter
killerc998's Avatar
03 noma-p_20190416_155537_vhdr_auto_1555510938351.jpg03 noma-p_20190416_161258_vhdr_auto_1555511000924.jpg
I will be running stock size equivalent tire, and not body dropped. Should lay just fine.
03 noma
LS Swap Questions
post #113 of 121 Old 04-17-2019, 10:28 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Re: 03 noma
Poor truck.
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #114 of 121 Old 04-18-2019, 10:39 PM Thread Starter
killerc998's Avatar
Poor truck?
03 noma
LS Swap Questions
post #115 of 121 Old 04-19-2019, 11:53 AM
BravadaX's Avatar
Re: 03 noma
Yeah,Iíve gotten a hold of two trucks done like this over the years. Usually nothing is left I modified except the things that need modifications like that anemic 2.2. So I gut the power train,and scrap everything else...most of the time theyíre the same color too,..primer grey
I feel say the same thing tho when I buy them,and take it to my house. It has a very low chance of returning to the road again...Iím usually the last owner of an S10. I have a stack of titles from the ones that gave their life to feed the fleet..
BravadaX is offline
post #116 of 121 Old 04-19-2019, 03:24 PM Thread Starter
killerc998's Avatar
Ah. Trucks not going anywhere. Will get done and be driven. I don't see the point of owning something not on the road.
03 noma
LS Swap Questions
post #117 of 121 Old 04-19-2019, 04:03 PM
I'm super serial
manbearpig's Avatar
User is: manbearpig is online now
Re: 03 noma
Looks good so far. You going to body drop it?
post #118 of 121 Old 04-19-2019, 08:14 PM Thread Starter
killerc998's Avatar
Nope, no body drop. Will be driven most the time. Will also stay with 15 or 16 old school boyds/eagles/centerlines/weld wheels/primes/American racing/ budnicks/etc... The 15"eagles I had just sold. They had the wrong offset for the rear.
03 noma
LS Swap Questions
post #119 of 121 Old 04-19-2019, 09:25 PM
BravadaX's Avatar
Re: 03 noma
Not driving your car is like not ****** your girl to keep the ***** tight for the next guy..nah,..wear that **** out!
I get these trucks at or near the end of their lives. They’re old now..beat,been through multiple owners. when I get my hands on an S-series it was me,or the junkyard. I salvage the ones I can,but most of the time it’s too late,and they’re just too far gone to bring back without sacrificing others...or themselves for others..heavy damage,blown motors,..just ragged out.
BravadaX is offline
post #120 of 121 Old 04-19-2019, 09:39 PM Thread Starter
killerc998's Avatar
Me and a buddy grab those up also for a few hundred and part them out. I'm the second owner to this one and put more then half the miles on it.
BravadaX likes this.
03 noma
LS Swap Questions
post #121 of 121 Old 04-23-2019, 10:15 AM Thread Starter
killerc998's Avatar
Re: 03 noma
Still working, got the lower control arms notched a little more. Front end put together. Mocking up where the valves are going to go. Ordered a new 5 gallon aluminum air tank. Need to make a mount for that, figure out where I'm mounting the compressors. Once that is figured out I will paint the 5 link and button up the rear end.
03 noma
LS Swap Questions
