replacement coolant tank - S-10 Forum
post #1 of 16 Old 08-16-2018, 03:54 PM Thread Starter
User is: dime-dozen is offline
03 4.3
suggestions for replacement coolant tank
Ive already been thru the Dorman crap(2 failures in as many months,surprised??)
only Delco one I see is black and $70
anyone have good luck with another brand thats not just a reboxed Dorman?
post #2 of 16 Old 08-16-2018, 08:29 PM
B4U Task Force
Rhotpursuit's Avatar
Re: replacement coolant tank
Spectra...$30
https://www.rockauto.com/en/moreinfo...412031&jsn=446
Apple Red 96 SS
post #3 of 16 Old 08-16-2018, 10:02 PM Thread Starter
saw those also but was afraid it was just a Dorman rebox
post #4 of 16 Old 08-17-2018, 12:20 AM
oldeerslayer's Avatar
You could also pick up one at a JY. Clean the outside with lacquer thinner and use a little dish detergent and some tiny gravel to clean the inside. You want gravel not much bigger than sand and shake it from every angle to remove the crud inside. Might take a couple tries if you're real particular about the appearance, but they will clean up pretty good.
Just did my 99 last week while doing a flush.
post #5 of 16 Old 08-17-2018, 12:36 AM
Harley's Avatar
User is: Harley is offline
I'm storing those tricks away for the next time I'm cleaning one out. Thanks!
Harley is offline
post #6 of 16 Old 08-17-2018, 08:18 AM Thread Starter
thanks but want new
may have to go thru the cap that falls off seams that leak,boltholes made in wrong location Dorman product
Harley Ive always used jack chain for cleaning out stuff like that,alot easier to get out.
post #7 of 16 Old 08-20-2018, 05:40 AM
dlundblad's Avatar
User is: dlundblad is offline
If you have problems with new aftermarket and don't want to pay $70 for new OE, I'd just find a nice used OE at a junkyard.
I used a whole bottle of Prestone engine flush in my reservoir when I flushed out the cooling system. Had it in there for a few days while the rest of the system had distilled water. Looks spotless now and my truck saw plenty of PO neglect.
1997 Chevy Blazer 4x4
4D- Silver-150k-BFG KO2's
4L60e-NV233 (3 button t case)
post #8 of 16 Old 08-29-2018, 03:26 AM
jayyk31's Avatar
User is: jayyk31 is offline
NOS OE on Ebay
-NEW DAILY. '86 Blazer 54k miles!!!
https://www.s10forum.com/forum/f20/my-new-gem-815417/
'92 EXTENDED Cab 408 LSx t56 Magnum!!!
Build thread-
https://www.s10forum.com/forum/f213/l...56-n-a-665850/
-2000 RCSB 2.2 5 speed.... SOLD!!!
jayyk31 is offline
post #9 of 16 Old 08-29-2018, 08:19 AM
Part# 12380202
But since there is no picture is it the replacement one that Delco also offers which is black?
https://www.ebay.com/itm/GM-OEM-Radi...MAAOSwXXxZRBu6
post #10 of 16 Old 08-30-2018, 08:58 AM Thread Starter
yea the Delco I saw on RA was black
I got a spectra at $40 shipped
says made in Vietnam
My 01 (Im the original owner) still looks like new inside,pink,just how I like it.
Its all these 2nd owner ones that PO didnt change the coolant.Grrrr
post #11 of 16 Old 08-30-2018, 02:46 PM
Took my senior class trip there in 1967.
Not a big fan of their products.
It'll be 50 years next month since I got out.
Of both the hospital and the service.
Maybe time to stop looking back.
post #12 of 16 Old 08-30-2018, 03:14 PM Thread Starter
they never punched my ticket
buddy of mine drew #002
he enlisted in USAF instead
post #13 of 16 Old 08-31-2018, 07:53 AM
Same thing I did, but then in basic I volunteered for Pararescue.
Being young and dumb.
Not sure if I totally regret doing it.
Did some good, some bad.
post #14 of 16 Old 09-08-2018, 11:09 AM Thread Starter
going thru some old records that were in old safe the other day I found a tattered selective service card
for 1972. Number was 169..... very close
I remember another year was #269. Dont know why I saved that card after all these years
now we are totally off track
got the tank in looks like it fits a little better than the dorman.
On the Dormans I had to put foam under them because they arent shaped right on the underside.Also need to put loctite on mount bolts and snug them finger tight as they will crack if you tighten down like a factory one.
post #15 of 16 Old 09-09-2018, 10:22 AM
Post Whore
chevymec's Avatar
User is: chevymec is offline
Gotta say, I have had a Dorman or Napa tank for a few years and no problems. I guess it is true they are hit and miss. I've had a few other Dorman parts no good, more most have been ok.
1997 SS---Built and Blown... almost
My build thread... https://www.s10forum.com/forum/f30/pr...ecs-ss-513887/
chevymec is offline
post #16 of 16 Old 09-10-2018, 02:33 AM
That's Dorman's biggest issue. No QC. You never know until you try their parts if they're any good. Even if you buy 2 at the same time and place.
As big a company as they are you'd think someone in marketing would be watching the internet chatter and be aware that there is an issue seriously effecting their rep.
