How-To: 4.3l A/C Bypass - S-10 Forum
 1Likes
  • 1 Post By JustAnSS
post #1 of 23 Old 12-18-2010, 01:36 PM Thread Starter
Parts Dude
Vulture's Avatar
User is: Vulture is offline
Lightbulb How-To: 4.3l A/C Bypass
So if your luck is anything like mine, your A/C clutch goes out at the most inoppurtune time; like Thanksgiving Eve. When the clutch bearing goes out, the belt will no longer turn freely, thus rendering your Dime useless. After searching and finding no A/C bypass information on the forums, I found my own solution. Hopefully this will help some other dime drivers out there.
This was tested on a 2001 Jimmy 4.3L with the stock CS130D alternator. This should work on all 2nd Generation 4.3L motors.
You will need a 6 rib, 84 inch belt, here are some part numbers:
NAPA- NBH 25-060840 or PBH 6K840
Advance Auto- Dayco 5060840
Carquest- K060840 or K8406
This belt is fairly common, appearing on 2005 and up F150s with 4.6l & 5.4l motors; Chargers, 300's & Magnums with the 2.7l V6, and the 2.0l Focus from 05-07.
Step 1: Remove the idler pulley.
Step 2: Route the belt around the crank & water pump normally. The belt will go straight from the power steering pump to the alternator, bypassing the A/C and idler pulley. You WILL need to pull the tensioner back as far as it will go: the belt will stretch a little after a day or two.
Step 3: You're done!
Now, with the stock alternator, do NOT use an 85 inch belt. It slips and doesn't provide enough power to the accessories. I imagine you would need the 85 inch if you have done the AD244 alternator conversion however. I didn't do the conversion until after I fixed the A/C, so I can't verify that it would work. If anyone can verify, shoot me a PM, and I'll update this.
2001 Jimmy 2dr 2wd- AD244 upgrade
Vulture is offline
post #2 of 23 Old 06-26-2012, 03:55 PM
User is: stvpttrsn is offline
Re: How-To: 4.3l A/C Bypass
Anyone have this type of advice on a first gen(89 S-10 blazer 4.3)? I would like to do this mod temporarily til I can fix the a/c clutch. I would guess it may be a size other than 84 in, but would appreciate some input. Thnx
post #3 of 23 Old 06-26-2012, 11:58 PM
i need a paint job
s106banger's Avatar
User is: s106banger is offline
Send a message via AIM to s106banger
check out the syclone website, lots of guys bypass the a/c over there.
1997 S10 266ci V6-turbo. 4l80e. 8.8. 23lbs.
[email protected]
526rwhp 531ftlbs on a mustang dyno @20lbs.
build thread-https://www.s10forum.com/forum/f11/no...r-more-481754/
2002 S10 2.2-DD 80% ZQ8 clone "TuTu Powa" w/efans. 98rwhp 111ftlbs!
post #4 of 23 Old 07-31-2012, 10:25 PM
neex
User is: neex is offline
not hijacking the thread just spreading the word.... making sure everyone knew that for around $30 you can get an AC bypass pulley with the stocker belt. I'm running this way till my parts hit. Here's the part#..... Motormite 34152
Great thread and thanks!
A.
neex is offline
post #5 of 23 Old 08-28-2012, 05:52 PM Thread Starter
Parts Dude
Vulture's Avatar
A.
That Motormite number fits the First-Gen 4.3L: up to 1995. Dorman number for 2nd-Gens is 34175
Vulture is offline
post #6 of 23 Old 08-28-2012, 06:05 PM
User is: sphere478 is offline
I dont see how you would be able to bypass the ac on a 89 4.3 without a bypass pully
post #7 of 23 Old 08-28-2012, 06:25 PM Thread Starter
Parts Dude
Vulture's Avatar
Dunno, don't have one lying around to experiment on. If I ever figure it out, I'll post it here.
Vulture is offline
post #8 of 23 Old 10-10-2012, 01:46 AM
Mafia Customz
mafiacustomz's Avatar
User is: mafiacustomz is offline
Send a message via Yahoo to mafiacustomz
Here you go Drive-Rite V-Ribbed Belt Part No. 940K6 that is a 89 4.3l v6 w/o ac belt and the belt routing is on the dayco website 6-72 i hope this info helps.
S.E.S.
post #9 of 23 Old 10-28-2012, 12:48 AM
User is: Sluh is offline
sorry, but no. It would not work.
Sluh is offline
post #10 of 23 Old 11-27-2012, 10:32 PM
User is: rudedog50 is offline
Hi guy's or gal's. I'm a newbie her so I hope I'm not stepping on any toes or doing something wrong. After reading through the posts here I settled on going with the Non a/c belt and additional pulley.
I used the following parts and it is a perfect fit.
K060870 (6k870) belt from O'reilly's
38008 Gates Ribbed Pulley from O'reillys
Bolt and hardware pulled from the normal smooth pulley @ the junk yard.
Bolted new pulley into hole on a/c bracket. Installed belt. Good to go.
post #11 of 23 Old 11-29-2012, 08:57 AM Thread Starter
Parts Dude
Vulture's Avatar
Glad to hear you found a solution. Is yours a 1st or 2nd Gen motor?
Vulture is offline
post #12 of 23 Old 03-10-2013, 04:46 PM
The Dave Inc.
xxosiris9xx's Avatar
User is: xxosiris9xx is offline
I just went to Advanced/autozone and got the pulley for a non a/c s10 and a belt for a non a/c s-10 when i ditched the compressor on my bd
Dave|2003 Bodydropped S10 "Pneumatic" SOLD|2000 Sierra 1500 Daily Driver
post #13 of 23 Old 03-10-2013, 07:37 PM
JustAnSS's Avatar
User is: JustAnSS is offline
This would be the best setup IMO. It's a good idea to have an idler pulley to keep some tension on the belt.
enterdimension likes this.
JustAnSS is offline
post #14 of 23 Old 05-17-2013, 12:35 PM
User is: ochar is offline
Just wondering....can you leave the idler pulley on? And if so, what size belt would that require?
Thanks in advance.
ochar is offline
post #15 of 23 Old 05-21-2013, 09:22 PM Thread Starter
Parts Dude
Vulture's Avatar
On 2nd Gen "W" motors, no. If the "w/ AC" idler pulley were left on, the belt would hit the bottom of the A/C clutch pulley. Supposedly if you run the non A/C idler and belt, you could do it, but this might necessitate removal of the compressor. This kludge was designed to operate on an emergency basis with the A/C compressor still mounted. I operated my Jimmy as a daily driver for 2-3 weeks in this configuration with no problems.
Vulture is offline
post #16 of 23 Old 01-04-2014, 10:48 AM
Caffe's Avatar
User is: Caffe is offline
This guide was a real help. Thanks. Did it myself after reading here...
Thanks again!
Runqvist.se | '96 S10 Ext Cab V6 4x4 Daily Driver
Caffe is offline
post #17 of 23 Old 07-04-2014, 01:39 PM
Strife's Avatar
User is: Strife is offline
Not big on bringing up old threads but I, today, installed one of these belts.
Don't let the tensioner get the best of ya, it had to go more than 90 degrees for me before it went on but it fits great!
Thanks OP. ��
Strife is offline
post #18 of 23 Old 07-04-2014, 02:57 PM Thread Starter
Parts Dude
Vulture's Avatar
No problem. That belt tensioner needs to get cranked almost to the stop to get the belt on.
Vulture is offline
post #19 of 23 Old 07-20-2014, 05:32 PM
LeMons Racer
User is: rlhammon is offline
Is this for a 1st gen 4.3L? My vin shows "Z", and my AC is on the top left and Alt is top right.
I tried the shorter (84" belt) as listed in this thread... no luck, it was still too long with the AC out. I just returned that belt and picked up the Dorman pulley liisted here to try that, as Advanced Auto found that it the correct part for our truck. Hoping to try it out shortly as I'm currently no longer near the truck.
rlhammon is offline
post #20 of 23 Old 07-22-2014, 06:25 PM Thread Starter
Parts Dude
Vulture's Avatar
This is for the 2nd Gen 4.3L, W's & X's. If anyone get's proven belt numbers for the 1st Gen's let me know.
Vulture is offline
post #21 of 23 Old 11-02-2014, 06:06 PM
User is: pwilkie141 is offline
NAPA- NBH 25-060840 worked for my 01 noma
post #22 of 23 Old 11-10-2014, 08:11 PM Thread Starter
Parts Dude
Vulture's Avatar
Excellent! Welcome to the forum BTW.
Vulture is offline
post #23 of 23 Old 11-22-2014, 12:58 PM
User is: sevanlevan is offline
I got the idler pulley (L.A.Auto Parts)but turned the dust jacket around and used it as a spacer.It seems to be working ok.
You may post new threads
You may post replies
