2001 LS Xtreme - Radio Install Questions (IM SORRY) - S-10 Forum
post #1 of 10 Old 03-27-2019, 10:14 AM Thread Starter
User is: Mkulrey13 is offline
Exclamation 2001 LS Xtreme - Radio Install Questions (IM SORRY)
Okay, I have a 2001 LS Xtreme that i am looking to put a Double Din Radio in. I know the dash kit I am going to use but i am unsure about a harness. Do I need anything special in the harness department for the Security PASSLOCK or whatever this truck has? Anyone have a specific harness they used and it worked? I am not new to installing such things but i want to make sure i have the correct harness before i even start tearing this thing apart.
post #2 of 10 Old 03-27-2019, 01:46 PM
oldeerslayer's Avatar
Re: 2001 LS Xtreme - Radio Install Questions (IM SORRY)
Swapping radios won't effect Passlock (vehicle anti theft). Shouldn't be an issue with Theftloc (radio anti theft) as long as it was turned off in both radios before the swap.
Are you going to be installing a GM or aftermarket DD? What radio does your truck have now?
I looked a Crutchfields website and found this tidbit;
There are two potential harnesses listed for the 2001 S-10, depending on whether it was a single cab, extended cab, with or without the 3rd door, or had the 'RDS' feature.
Might want to give them a call. 1-844-563-7013
post #3 of 10 Old 03-27-2019, 04:12 PM Thread Starter
It has the stock 1.5 Din Radio. i am putting in an aftermarket DD. 2001 Extended with 3rd door. Mine does not have RDS. My radio displays nothing but the station numbers.
post #4 of 10 Old 03-27-2019, 04:18 PM Thread Starter
Would this be the harness I would need? Nothing special?
Name:	3-27-2019 4-16-43 PM.jpg
post #5 of 10 Old 03-27-2019, 10:36 PM
That's the correct harness to plug into your existing radio harness to avoid hacking up the OE wiring. I just looked it up in Metra's catalog.
http://www.metraonline.com/products
The mounting kit is Metra 95-3027. It's fairly new and works good. Here's the lowest price I could find for it $28. Some places are getting $60;
https://www.ebay.com/itm/Metra-95-30...ss!53582!US!-1
Have you read this?
https://www.s10forum.com/forum/f27/2...on-kit-847637/
post #6 of 10 Old 03-28-2019, 12:26 AM
Old Fart
goes2fast's Avatar
User is: goes2fast is offline
If you can find an 02-03 bezel you will have a nice install that will look factory.
Too Much Horsepower is ALMOST ENOUGH!
"I have a car-sickness. I need to be checked into the HENRY Ford Clinic." -Tim "The Tool Man" Taylor
post #7 of 10 Old 03-28-2019, 06:06 AM
Did I misunderstand that long thread? I thought that if you used an aftermarket radio you still needed the Metra trim ring???
post #8 of 10 Old 03-28-2019, 07:49 AM Thread Starter
Have you read this?
Thank you. Yes I did read that. I got the dash kit from that thread. Do you happen to know what antenna adapter i need or just the basic one as well?
Thought about it but I think the new Dash kit looks good enough to me, Finding a 02-03 bezel seems to be tricky around here anyhow. I may paint match the dash kit to the truck.
post #9 of 10 Old 03-28-2019, 10:28 AM
User is: dime-dozen is online now
please post pics after the install of painted kit.
be sure and wipe with lacquer thinner and use bulldog before paint
post #10 of 10 Old 04-16-2019, 10:03 AM Thread Starter
All installed. Never got around to painting the trim just yet. Also at some point i will be getting a different head unit. Just needed cheap bluetooth for now.
ID:	316201   Click image for larger version
Similar Threads
1999 s10 cb radio ceiling install question 21mbald1999 Interior Styling 5 03-26-2018 06:07 PM
2001 S10 LS.....New Here.. Suspension Questions Cisneroz209 Steering & General Suspension 3 02-18-2018 10:38 AM
How do you program remote for 2001 chevy s10 xtreme with manual windows and locks? Dr001982 Electrical / Lighting 14 02-12-2018 08:31 PM
install 2001 radio in a 1996? carnutbill Sound and Security 0 11-25-2016 09:40 PM
2001 Xtreme xcab Timewarp Trucks For Sale 1 08-19-2016 11:38 PM
